Acekard 2i Not working?
  • corejoy
    • Jun 2011
    • 5
    #31
    What is the best website to get the Acekard 2i?
    • barrowmanandrew
      • 3427
      #32
      card or firmware?
      • corejoy
        • Jun 2011
        • 5
        #33
        I've got a sd card so I don't know if I can use it for my ds if I add some files on it
        • barrowmanandrew
          • 3427
          #34
          yes you can use any sd card,
          you can buy acekard here.
          need to put latest akaio firmware on sd card for it to work...
          Digital Kaos - Downloads - akaio 1.8.7
          • corejoy
            • Jun 2011
            • 5
            #35
            After putting akaio firmware on sd card can I add the games directly?
            • barrowmanandrew
              • 3427
              #36
              yes, just copy games to root of sd card
              • corejoy
                • Jun 2011
                • 5
                #37
                Menu?
                It didn't work I get a message menu? on my ds screen
                • barrowmanandrew
                  • 3427
                  #38
                  that means the card cant find the firmware.
                  what do you have on sd card?
                  you should have
                  1. a folder called "_aio"
                  2. a file called "akmenu.nds"
                  3. some games
                  the firmware has to be put on root of sd card, if the _aio folder and akmenu file are put inside a folder, then card won't work.....
                  • corejoy
                    • Jun 2011
                    • 5
                    #39
                    I am going to buy a new acekard as mine is probably fake, the website where I bought it is down.
                    Thank you for all the information!
                    • barrowmanandrew
                      • 3427
                      #40
                      if its a fake acekard then the newer akaio fimrware wont work on it....
                      • SpiralTrance
                        • May 2011
                        • 32
                        #41
                        Ok here's an update.
                        I sent my acekard back and they sent me a replacement. It took about 9 weeks for the replacement to come through and to be honest I thought I wasn't going to hear from the company again and sold my DS XL.
                        Tested the card on my nephews DSL and it works, well almost, loads of 60% of all games though im still having issues with white screens. Some ROMs that I managed to load on the old card wont load so I know it's not the roms.
                        Also on the new Acekard there's no anti-counterfiet number on the back. Does that mean it's a fake?
                        EDIT
                        The reason why the old card wasn't working was because the locking mechanism on the micro SD slot had broken. On the old card there was no mechanism and the micro sd use to just slide in and out.
                        • barrowmanandrew
                          • 3427
                          #42
                          if there is no anti couterfit stciker on it then it will be fake....
                          if roms arent loading then you need to update to latest akaio firmware on sd card
                          you might have a problem with your card being a clone though.
                          some clones wont run on the newer firmware....
                          • SpiralTrance
                            • May 2011
                            • 32
                            #43
                            I've installed akaio 1.8.7 when I tested it so does that mean the card isnt a fake? Is it possible the card could be a refurb? It occured to me the reason it took so long to replace was that the card was sent to china and repaired.
                            • barrowmanandrew
                              • 3427
                              #44
                              i dunoo m8...
                              if you want to risk it you can try doing the 1.4.3 update.
                              Digital Kaos - Downloads - Acekard 2i firmware update for dsi v1.4.3 and 3ds
                              if it works then your can will work on 1.4.3, but they say there is a slim chance of bricking fakes.....
                              • Viveki
                                • Jun 2011
                                • 20
                                #45
                                It's quite easy to distinguish a genuine acekard card from a fake one.Go to the reverse side of the card, there is a anti-fake paper,tear off the paper and you will see the security code. After you get the security code. Login this page: Acekard Anti-Counterfeit Code Check fill in your security code and click check
                                You will see the result as below if your acekard 2i is genuine...BTW, akaio kernel has been updated to 1.8.8
