Black screen on New DS games on my R4 Upgrade
  • ramz
    • May 2012
    • 9
    Have no idea how to get new games to work on my R4.
    My R4 says: R4
    Upgrade
    Revolution for DS
    (NDSL/NDS)
    R4 cards - Nintendo ds r4 - R4i sdhc Official website
    Do i have a clone R4 and if so how can i patch games to work on it, or is there a new kinda firmware that i can use, I hear about wood whatever that is? I'm a bit of a noob. thx
  • iphonic
    • 244
    I have the same issue the old games work but no new games i even tried the max loader process but still when i switch my ds on it says R4 III revolution for ds v3.11 my old games work but the new games dont it just comes up as a white screen
    • ramz
      • May 2012
      • 9
      I have also tries the MaxCrass method with no joy, the game is a black screen on loading :-( . Guess the only way is to get a new card, anyone any suggestions on the best to buy. i.e. m3i or ackercard etc?
      • barrowmanandrew
        • 3427
        can you post a pic of your card please..
        • iphonic
          • 244
          This is my card and my memory card which is 4gb
          • barrowmanandrew
            • 3427
            official support for that card stop a long time ago.
            unfortunatly i don't think that woods firmware will work on it...
            you might be able to use retrogamefan firmware to update it.
            you will have to google retrogamefan and download the latest version.
            when you open the file you should a text document called "known cards that use dstt fimware"
            this will give a list of known working cards and instructions on how to use.
            Natively Working (Replaces ORIGINAL Firmware) :
            DSTTi Gold - www.ndstti.cn -> Just copy files (Use DSTT_DSTTi folder)
            DSTT-Advance - www.dstt-adv.com -> Just copy files (Use DSTT_DSTTi folder)
            R4Top Revolution - www.r4top.com -> Just copy files (Use DSTT_DSTTi folder)
            R4iTT - www.r4itt.net -> Rename TTMenu.dat to r4.dat (Use DSTT_DSTTi folder)
            R4i V1.45 Revolution - www.ndsiLL.net -> Rename TTMenu.dat to iLL.iL (Use DSTT_DSTTi folder)
            R4i SDHC Upgrade Revolution - r4i-sdhc.com.tw -> Rename TTMenu.dat to iLL.iL (Use DSTT_DSTTi folder)
            R4i Gold Upgrade Revolution v1.4.1 - www.r4igold.cn - > Rename TTMenu.dat to iLL.iL (Use DSTT_DSTTi folder)
            R4i Gold Upgrade Revolution v1.14b - www.r4igold.cn - > Rename 1 copy of TTMenu.dat to R4i.dat (Use DSTT_DSTTi folder)
            R4i SDHC Upgrade Revolution - r4i-dshc.com -> Rename TTMenu.dat to R4i.TP (Use DSTT_DSTTi folder)
            R4i King LL - www.r4-king.com -> Rename TTMenu.dat to R4KING (Use DSTT_DSTTi folder)
            R4i DSi XL - www.r4i-ndsill.com -> Rename 2 copies of TTMenu.dat to iLL.iL and R4i.TP (Use DSTT_DSTTi folder)
            R4V-R4i v2.2 and v2.5 - www.r4-v.com -> Rename 2 copies of TTMenu.dat to iLL.iL and R4i.TP (Use DSTT_DSTTi folder)
            R4 Deluxe v1.20 - www.r4deluxe.com -> Rename TTMenu.dat to _DS_MENU.DAT and then DLDI patch _DS_MENU.DAT (Use DSTT_DSTTi folder)
            [COLOR=Red]THIS ONE [/COLOR]R4IIISDHC v3.07 - www.r4iiisdhc.com -> Rename TTMenu.dat to R4.dat (Use DSTT_DSTTi folder)
            R4i-SDHC 1.41 and v1.42 - www.r4ll-net.com -> Just copyfolder (Use DSTT_DSTTi folder)
            R4SDHC v1.34 - www.r4sdhc.com -> Just copy files (Use R4SDHC folder)
            M3Real/M3Simply/M3iZero - www.m3adapter.com -> Just copy files (Use M3Real_M3iZero folder)
            Working as Dual Boot (Keep your ORIGINAL Firmware)  :
            TTi Upgrade Revolution - www.nds-tti.com -> Rename TTMenu.dat to YSMenu.nds (Use DSTT_DSTTi folder)
            R4 SDHC Upgrade Revolution - www.r4i-sdhc.com (Use R4-SDHC_R4i-SDHC folder)
            R4i SDHC Upgrade Revolution - www.r4i-sdhc.com (Use R4-SDHC_R4i-SDHC folder)
            Supercard DSONE - eng.supercard.sc (Use DSONE_DSONEi folder)
            Supercard DSONEi - eng.supercard.sc (Use DSONE_DSONEi folder)
            R4Top Revolution - www.r4top.com (Use R4-SDHC_R4i-SDHC folder)
            R4i SDHC Upgrade Revolution - www.r4i-sdhc.com.tw (Use R4-SDHC_R4i-SDHC folder)
            R4i SDHC Upgrade Revolution - www.R4i-dshc.com (Use R4-SDHC_R4i-SDHC folder)
            R4DSiXL3D - www.r4dsixl3d.com (Use R4-SDHC_R4i-SDHC folder)
            R4i Advance v2.0 - www.r4i-advance.com (Use R4-SDHC_R4i-SDHC folder)
            R4-IIIi v4.03 and v4.04 - www.r4dsl.net (Use R4-SDHC_R4i-SDHC folder)
            R4i SDHC Revolution v2.07 - www.r4sdhc.com (Use R4-SDHC_R4i-SDHC folder)
            R4i SDHC Revolution - www.r4i.cn (Use R4-SDHC_R4i-SDHC folder)
            R4v-r4i using v1.46 (red PCB, 1.4 'new' sticker) (Use R4-SDHC_R4i-SDHC folder)
            R4v-r4i using v1.41 (red PCB, 1.4 with sticker) (Use R4-SDHC_R4i-SDHC folder)
            R4 Pocket - www.r4ipocket.com (Use R4-SDHC_R4i-SDHC folder)
            R4i Pocket - www.r4ipocket.com (Use R4-SDHC_R4i-SDHC folder)
            R4i-Gold - www.r4i-gold.eu (Use R4-SDHC_R4i-SDHC folder)
            R4i-Gold - www.r4i-gold.com (Use R4-SDHC_R4i-SDHC folder)
            R4iSDHC Revolution - www.r4ita.com (Use R4-SDHC_R4i-SDHC folder)
            R4xDS - www.r4xds.com  (Use R4-SDHC_R4i-SDHC folder)
            R4-III Upgrade Revolution - www.r4iiinew.com (Use R4_Clone folder)
            R4i-SDHC Revolution - www.r4-pro.com (Use R4_Clone folder)
            R4-III Revolution Upgrade - www.r4dsl.net (Use R4_Clone folder)
            N5/i - www.dsn5.com (Use R4_Clone folder)
            R4iNDSiXL - http://r4indsill.com (Use R4_Clone folder)
            I have highlighted the selection that i think has the best chance of working for you...
            before you start messing with the firmware, you should make a backup of your sd card or better still, use a spare sd card.
            wouldnt want to change somethng on sd card and flashcard stop working alltogether...
            • iphonic
              • 244
              Ok much appreciated i will try this out when i get a chance and come back to you with the outcome many thanks as well
              • ramz
                • May 2012
                • 9
                Here is a pic of my card do i need to do the same? thx
                • barrowmanandrew
                  • 3427
                  your card is diffrent...
                  i think you have a couple of options...
                  [COLOR=Red]maybe this one [/COLOR]R4i SDHC Upgrade Revolution - r4i-sdhc.com.tw -> Rename TTMenu.dat to iLL.iL (Use DSTT_DSTTi folder)
                  [COLOR=Red]thsi one maybe [/COLOR]R4i SDHC Upgrade Revolution - www.r4i-sdhc.com (Use R4-SDHC_R4i-SDHC folder)
                  • ramz
                    • May 2012
                    • 9
                    Tried both links you suggested, unfortunately its stuck on the R4 loading screen and doesn't get to the game menu :-( Ive read you can patch games, any step by step guides on doing that are welcome, thx
                    • barrowmanandrew
                      • 3427
                      even the dual boot one? (2nd option)
                      you should at least get the original firmware booted up...
                      tbh, you might be bettter buying a newer card...
                      you will get a decent card for under 20quid, then just use your current sd card...
                      • ramz
                        • May 2012
                        • 9
                        Tried both your highlighted fixes with no joy. I did notice there is a hyphen in the websites you suggested and on my r4 card there isn't a hyphen? I guess a new card is probably the best fix. I want to get Moshi Monster game to work for my daughter. A patch would be welcome too. ;-)
                        • barrowmanandrew
                          • 3427
                          moshi monsters was a right problem rom, most cards struggled with it..
                          there are patched versions out there.... but i dunno if they will work on your card...
                          i'll find a patcehd version for you to try..
                          biab...
                          well the working version was on megaupload lmao...
                          wait till tomoroow, i will see if i can get hold of it..
                          • iphonic
                            • 244
                            Whats the best place to download the latest patched nintendo ds lite roms from?
                            May be the games i have downloaded recently have not been patched right hence the white blank screen on my ds
                            • barrowmanandrew
                              • 3427
                              not all ds roms are patched.
                              the AP measures are generally overcome by firmware updates on the flashcards.
                              this is the reason that picking a good flashcard is essential.
                              i use this site alot.
                              it has a patching tool you can download which willl patch the games that require it.
                              ( if you read the info on individual games , its tells you whether patching is supported)
                              out of interest, are you using a dslite or a dsi?
