Can't get Alien Syndrome to work on WiiFlow
  • usavageiv
    • 36
    I've tried using IOS 202, 222, 223, 224, 247, 248, and using all available different video modes but still get the same problem. The screen scrolls rapidly and in some cases (IOS 222 and certain video modes) the screen is black and white. I've searced all over for a thread about this problem but haven't found one. I would try running it on usb gx but I keep getting a blue screen error with every game I try to load on that one. Starting to think I really messed something up. LOL
  • ck-ok
    • 2592
    click on the wii sign in the bottom l/h corner of the main screen and change the tv settings from 50hz to 60hz or the other way around and see if that sorts it.
    • usavageiv
      • 36
      Perhaps I'm using a different version of wiiflow than you are ck. I don't have that icon in the bottom left of the screen. I can go into the game settings though and to "video mode" and change from "Default, Pal 50, Pal 60, NSTC, Auto Patch, and System". Auto Patch usually works perfectly. In this case I've tried each of the video settings with no luck.
      If this isn't what you were refering to let me know and I'll take another look at it.
      • ck-ok
        • 2592
        no the wii sign on the main menu screen to enter wii settings
        • usavageiv
          • 36
          Wii system menu 4.3u doesn't seem to have any options for changing 50 - 60. Options are as follows:
          Console Nickname
          Calendar
          Screen
          Sound
          Parental Controls
          Sensor Bar
          Internet
          WiiConnect24
          Language
          Country
          Wii System Update
          Format Wii System Memory
          Under WiiMenu option "Screen" the options are as follows:
          Screen Position
          Widescreen Settings
          TV Resolution
          Screen Burn-in Reduction
          Hope this information helps CK. Thanks for your patience.
          • reddevil157
            • 1427
            Wii menu, main screen-bottom left press wii-settings-screen-tv type-50hz
            • usavageiv
              • 36
              Screen Position
              Widescreen Settings
              TV Resolution
              On my system there is no "TV - type" menu option red. I've looked through all the Wii Menu options and don't see anyway to change it from there.
              • ck-ok
                • 2592
                looks like on yours its tv resolution.
                • usavageiv
                  • 36
                  TV Resolution setting only lets me change from 480i (Standard TV) to 480p (HDTV). No settings for 50 - 60hz.
                  • ck-ok
                    • 2592
                    60hz is 480i try changing to that or to 480p
                    • usavageiv
                      • 36
                      Unless you have a 480p (HDTV) connection (HDMI cable) you can not select the 480p option. The system detects the type of cable connected. Any other ideas? LOL
                      • ck-ok
                        • 2592
                        what system menu are you on?
                        • usavageiv
                          • 36
                          Sorry I thought I put that in there. System menu 4.3u.
                          • ck-ok
                            • 2592
                            dont know why you have no option to change tv type
                            all i can suggest is dont patch and force the game in wiiflow settings.
                            if you have priiloader installed switch on all region playing and see if that works.
                            • usavageiv
                              • 36
                              Been there done that. Is there a chance that it's just a bad copy of the game?
