Wii Softmod Tutorial for noobs like me
  • dell_xps
    • 2558
    #121
    Originally posted by pilgrimkenna
    help ive gone wrong already
    i have created the sd card and modified the bin file as running 3.4
    i put the sd in a could see the twighlight hack which i copied accross, it said something about having to play the game first, so i loaded up the game.
    now when i go to copy the file accross it says its already in the wii memory
    please help
    Play Zelda for a min or so just so you have a save file,then insert the SD card with the twilight hack/ home brew channel etc.
    Now go into the settings, delete the Zelda save file,then go into the SD card menu on the Wii, copy over the PAL hack, now go back and play Zelda, this time when it loads up, you'll see the Twilight hack, click on it, let it load up, once you are into the game walk backwards, this will start the homebrew channel install.
    • pilgrimkenna
      • 23
      #122
      thanks it worked home brew installed, i am trying to install ios16 64 v257 but i can move the cursor but cant select anything im stuck on the scree nn
      • dell_xps
        • 2558
        #123
        Press the + on the wii mote to install that wad and any wad.
        • pilgrimkenna
          • 23
          #124
          hi it installed prod.wad and said it was installed ok now i am on the wad manager screed how do i exit?? also the homebrew channel did not ask for upgrade
          • pilgrimkenna
            • 23
            #125
            hi when installing cios_fix.wad
            i got a ticket error
            wish i never started this now....
            error ret = 2011
            • dell_xps
              • 2558
              #126
              Press home on the remote m8.
              • pilgrimkenna
                • 23
                #127
                hi dell thanks for all your help
                im a bit lost
                i installed the first wad file, went to do the 2nd one and it returns an error message.
                please help!
                • pilgrimkenna
                  • 23
                  #128
                  also the update on the homebrew channel failed for some reason
                  • dell_xps
                    • 2558
                    #129
                    im a bit lost
                    please help!
                    You'll be using the wrong wad manager installer for the second wad, use
                    Custom WM then use the + to install it, thats all your doing wrong m8.
                    • dell_xps
                      • 2558
                      #130
                      dont worry about that.
                      • pilgrimkenna
                        • 23
                        #131
                        how comes i cant get the home brew software to update? it gets to the end then errors
                        • dell_xps
                          • 2558
                          #132
                          Dont know m8, as long as a homebrew channel is installed so you can softmod your wii i wouldnt worry about it yet, in the homebrew channel are you pressing the little icon of the world to update it using wifi ?
                          • pilgrimkenna
                            • 23
                            #133
                            hi that worked, i am currently at the stage of downgarding ios. its taking a while is this normal? i have not even selected the firmware version yet
                            • pilgrimkenna
                              • 23
                              #134
                              hi, i havent bothered to upgrade the home brew software yet as it was giving me an error. when i loaded it auto prompted for update, i just said no so i could carry on with the modding
                              • dell_xps
                                • 2558
                                #135
                                Shouldnt take that long, dowgrading the firmware takes the longest, then install shop takes second longest.
                                Is your Wii properly setup for wifi m8 ?
                                Try another channel on your wireless router if your finding it runs very very slow.
