USB Loaders on a friends Wii 4.3E
  • Keithuk
    • 2264
    Hi guys.
    I've just softmodded a friends 4.3E (who I only see once a month) the softmod was straight forward but I'm having trouble getting the USB Loaders to install. I softmodded a friends Wii and my Wii both 4.3E a few months ago so I know what files are needed.
    USB Loaders need the cIOS249 to operate now I try to install these with Multi-Mod Manager 13.4 but it fails. I using the same wad files as I did on the other 2 Wiis and those installed. WAD Manager 1.7 does sweet FA you select IOS249 press A and it just sits there doing nothing the same goes for cIOSX_rev21-Installer. Yes I'm connected to the Network through my WiFi and router.
    I followed the instructions in Wii USB Loader.
    There are no proper instructions how to run cIOS36_rev9-Installer.dol the only dol on this download. I made a cios folder and renamed that dol to boot.dol bit it still does nothing.
    The other problem I have is I can't install Priiloader 0.7. Its on the SD card and if I run it says IOS 58 rev 6176 at the top which I've installed then it goes through the file varification ok. Then password file not found and settings file deleted. Priiloader doesn't show up when I press the reset button as it does on mine so obviously it hasn't installed. The hacks.ini is in the SD root and hacks_hash.ini is in the Preloader folder.
    Anyone have any suggestions how to get USB Loader GX or the other two USB Loaders?
    Cheers.
    Keith
    2010 Golf GTD (170)
  • ck-ok
    • 2592
    sounds like you dont have a patched ios36.
    have you installed all the wads from the 4.3 tut?
    if not, install them all then you can tweak the mod for your preference.
    • Keithuk
      • 2264
      Cheers CK.
      I presume your talking about your 4.3 mod tut but that only talks about modding a 4.3 it doesn't talk about USB Loaders. I've downloaded all the files in your tut but there is nothing I haven't got already? IOS36 installed its one of those that did with MMM.
      Keith
      2010 Golf GTD (170)
      • ck-ok
        • 2592
        Originally posted by Keithuk
        Cheers CK.
        yes that tut, it will give you all the cios's you need to use a hdd.
        • Keithuk
          • 2264
          Well MMM-61.zip (Multi-Mod Manager) has no cIOS wads.
          4.3 hack files.zip has 5 cIOS files and I've tried to install them all with MMM but they wouldn't.
          So am I missing a download?
          Keith
          2010 Golf GTD (170)
          • ck-ok
            • 2592
            Well MMM-61.zip (Muti-Mod Manager) has no cIOS wads.
            you need to install all of the wads in order with mmm not just cios wads.
            • Keithuk
              • 2264
              Yes I did but the main one for USB Loaders cIOS249[38]-v17.wad wouldn't.
              USB Loader GX have there own web site but there is no suggestion of what wads you need or where to download them from?
              Keith
              2010 Golf GTD (170)
              • ck-ok
                • 2592
                try that wad again might take a couple of atempts
                • Keithuk
                  • 2264
                  I didn't try it once I tried it 3 or 4 times but it still wouldn't install everytime. As I said my friend went back home this afternoon so I would have to ask here to bring it back next time she comes up or email instructions to her husband.
                  I left Multi-Mod Manager 13.4 on the SD card and a couple of games Mahjongg Wii and Rokoban, Mplayer-CE, Wiimc and WiiEarth so she will have something to play with.
                  Keith
                  2010 Golf GTD (170)
                  • Keithuk
                    • 2264
                    Ok I did a sysCheck on my friends Wii and mine a while ago and I had a look to see what the differences were?
                    My friends 4.3E
                    sysCheck v2.1.0b5 by Double_A
                    ...runs on IOS58 (rev 6176).
                    Region: PAL
                    System Menu 4.3E (v514)
                    Homebrew Channel 1.0.8 running on IOS58
                    Hollywood v0x11
                    Console ID: 49892665
                    Boot2 v4
                    Found 106 titles.
                    Found 45 IOS on this console. 16 of them are stub.
                    IOS4 (rev 65280): Stub
                    IOS9 (rev 1034): No Patches
                    IOS10 (rev 768): Stub
                    IOS11 (rev 256): Stub
                    IOS12 (rev 526): No Patches
                    IOS13 (rev 1032): No Patches
                    IOS14 (rev 1032): No Patches
                    IOS15 (rev 1032): No Patches
                    IOS16 (rev 512): Stub
                    IOS17 (rev 1032): No Patches
                    IOS20 (rev 256): Stub
                    IOS21 (rev 1039): No Patches
                    IOS22 (rev 1294): No Patches
                    IOS28 (rev 1807): No Patches
                    IOS30 (rev 2816): Stub
                    IOS31 (rev 3608): No Patches
                    IOS33 (rev 3608): No Patches
                    IOS34 (rev 3608): No Patches
                    IOS35 (rev 3608): No Patches
                    IOS36 (rev 3608): No Patches
                    IOS37 (rev 5663): No Patches
                    IOS38 (rev 4124): No Patches
                    IOS40 (rev 3072): Stub
                    IOS41 (rev 3607): No Patches
                    IOS43 (rev 3607): No Patches
                    IOS45 (rev 3607): No Patches
                    IOS46 (rev 3607): No Patches
                    IOS48 (rev 4124): No Patches
                    IOS50 (rev 5120): Stub
                    IOS51 (rev 4864): Stub
                    IOS52 (rev 5888): Stub
                    IOS53 (rev 5663): No Patches
                    IOS55 (rev 5663): No Patches
                    IOS56 (rev 5662): No Patches
                    IOS57 (rev 5919): No Patches
                    IOS58 (rev 6176): No Patches
                    IOS60 (rev 6400): Stub
                    IOS61 (rev 5662): No Patches
                    IOS70 (rev 6912): Stub
                    IOS80 (rev 6944): No Patches
                    IOS222 (rev 65280): Stub
                    IOS223 (rev 65280): Stub
                    IOS249 (rev 65280): Stub
                    IOS250 (rev 65280): Stub
                    IOS254 (rev 65281): BootMii
                    BC v6
                    MIOS v10
                    Report generated on 2011/09/10.
                    My 4.3E
                    ...runs on IOS249 (rev 20).
                    Region: PAL
                    Hollywood v0x11
                    Console ID: 91742115
                    Boot2 v4
                    Found 134 titles.
                    Found 47 IOS on this console. 15 of them are stub.
                    IOS3 (rev 65280): Stub
                    IOS236[36] (rev 65535): Trucha Bug ES Identify NAND Access
                    IOS249[57] (rev 20): Trucha Bug NAND Access USB 2.0
                    IOS250[57] (rev 65535): Trucha Bug NAND Access USB 2.0
                    BC v6
                    MIOS v10
                    Report generated on 2011/07/25.
                    The only difference is
                    Now I couldn't get IOS236 to install from its seperate installer.
                    I thought you shouldn't install any IOS below 200 and I've never install IOS3.
                    As I said before I couldn't get cIOS249 ot IOS249 to install.
                    I wonder what Found 106 titles and 134 titles means?
                    Any thoughts on these sysChecks?
                    Keith
                    2010 Golf GTD (170)
                    • ck-ok
                      • 2592
                      get yourself mmm 13.4 Home of Multi-Mod-Manager - A multipurpose all-in-1 tool for Wii
                      and select install and patch ios36 once you have a patched ios36 you will be able to install other ios/cios's
                      • Keithuk
                        • 2264
                        Cheers CK but I already use MMM 13.4 as I've said and IOS36-64-3608.wad was one of the wads that did install.
                        Keith
                        2010 Golf GTD (170)
                        • ck-ok
                          • 2592
                          even so try install and patch ios36
                          [Changelog for v 13.4 - Sep 20, 2010]
                          Install & Patch IOS36:
                          - upgraded to support Nintendo's Sep7 IOS updates
                          - installs patched IOS36 as IOS36 & IOS236
                          - IOS36-64-v3608.wad used as base IOS
                          Important Note*
                          If your Wii has a non-working internet connection setup, a bug in Homebrew Channel 1.07 & 1.08 will crash any homebrew apps (including MMM) within seconds after launch. This affects apps launched in AHBPROT mode.
                          To disable AHBPROT mode, delete the "no_ios_reload" line from meta.xml file in MMM apps folder.
                          • ck-ok
                            • 2592
                            looking at your friends syscheck there is no trucha bug installed you cant just install the hb channel then install usb loaders and expect them to work.
                            you need to follow a tutorial and install a the wads in sequence for it to work.
                            try the patch and install ios36 with mmm to get the trucha bug restored or if that dont work try Trucha Bug Restorer 1.14 Original by WiiPower Mod by R2
                            • Keithuk
                              • 2264
                              My friends 4.3E
                              My 4.3E
                              If you look as both IOS36 and IOS58 they are the same on both Wii's. I know you don't just install HBC and the USB Loaders work.
                              I've never installed Trucha Bug Restorer on any Wii.
                              As I said in the other thread with NUS Downloader (NUSD) v1.9 is makes IOS's with different versions now to me the newest version should be better as with any upgrade.
                              So I've made two new wads IOS36-64-v3608.wad and IOS58-64-v6176.wad I will try those when I see her next.
                              Thanks again for your input.
                              Keith
                              2010 Golf GTD (170)
