D2X v7 cios pack and install instructions
  • Keithuk
    • 2264
    #121
    Welcome to DK.
    Which Wii version are you using?
    Originally posted by the1percent
    When I load wiiflow the remote shuts down. Vi am hoping his pack will do the trick. Also need to find 236 as I'm pretty sure it's not patched on my Wii.
    You can get IOS236, you could try a sysCheck to see if any other wads are missing?
    Keith
    2010 Golf GTD (170)
    • MACMII
      • May 2012
      can you install usb loader on emu nand?
      • Keithuk
        • 2264
        #123
        Welcome to DK.
        I'm not sure as I haven't tried that but you'll need Digital Kaos - Downloads - d2x v8 Final wad pack
        Keith
        2010 Golf GTD (170)
        • happy_highlander
          • 3535
          #124
          No, for sneek emu nand use joyflow if you must use a loader but they don't work very well as emu nand is designed to use original unmodified system ios not custom ios designed for usb loaders
          • dumptruck
            • Jun 2012
            will this work for usb loader and wiflo?? all ver.
            • happy_highlander
              • 3535
              #126
              Look up!!!!!!!
              • 22446688
                • Jun 2012
                i'll try this, thanks!
                • buzz2099
                  • Aug 2012
                  Thanks for the files!
                  • mac9572
                    • Aug 2012
                    muchas gracias, espero poder bajarlo
                    thanks you very much
                    • JimmyBest
                      • Oct 2012
                      I cannot get The Last Story to work on my Wii. Is D2X v7 required for it to work?
                      • Keithuk
                        • 2264
                        #131
                        Welcome to DK.
                        When I tried The Last Story it said is needs a 60Hz screen so you don't change the Wii settings you change the game settings to Force PAL60Hz. Does it show any message or just won't run.
                        There are a few games that show the message needs a 60Hz screen. Boom Street, Super Smash Bros Brawl. Project Zero 2 Wii Edition says it need 60Hz but when you change settings it still shows the same message you have to Force NTSC then it works. That one took a bit of Googling to get that game working.
                        I'm not sure if it will only work with d2x because I've had d2x v8.0 final pack installed for a while. It won't hurt to install these wads.
                        Keith
                        2010 Golf GTD (170)
                        • Pepois
                          • Dec 2012
                          Thank you very much!
                          • donutfunky
                            • Feb 2013
                            #133
                            Uninstall US FIX94 d2x v7a5 to restore PAL Wii Forwarders?
                            I know it's an old thread but I'm looking for some help. I remember installing FIX94 d2x v7a5 WAD Pack on my Pal Wii when it came bundled with the US/NTSC version of Skyward Sword.
                            Turning my Wii on for the first time in almost 18 months, I now remember it broke all of my home screen game forwarders where it just causes a Stack Dump after 30 seconds in cloader 3.1. Does anyone know how to remove these so I can restore my channel forwarders, preferably without resoftmodding my Wii and starting again from scratch.
                            Thanks in advance.
                            df
                            • donutfunky
                              • Feb 2013
                              #134
                              And to add more clarity, I use the latest version of USBLoaderGX and have updated all of my iOS versions using PimpMyWii.
                              • happy_highlander
                                • 3535
                                #135
                                Re: D2X v7 cios pack and install instructions
                                Pimpmywii is your problem. .... use modmii and select update softmod then enter a syscheck csv file you have just created on the sd card in your wii
