Can i mix a external hard drive with wii games and movies i have wii games already on my external hard drive but my hard drive with movies on is broken can i put movies on the the wii hard drive without me doing anything to it? i just want it to be simple no messing just drag and drop from my computer withoutlosing my games or without putting any more software on to split the harddrive
Mix wii game and movies on hard drive
Tags: None
I did do a Fat32 first but then i wbfs the hard drive, so does this mean i cant put anything else apart from wii games on? would i be able to try it or would it just mess everything up? and lose the games?Comment
that is correct wbfs is for wii games only but you could try this http://www.digital-kaos.co.uk/forums...2-ntfs-229900/ as it says this will convert your wbfs to fat32 without losing dataComment
is it really safe? or is it always the best to make a backup firstComment
I have only tested it on a small drive just to see if it worked and it was fine but I'm not so sure I would like to try it on a couple of hundred gig worth of data without a backup, but then if you are making a backup you can just format the drive without the need for this methodthat is correct wbfs is for wii games only but you could try this http://www.digital-kaos.co.uk/forums...2-ntfs-229900/ as it says this will convert your wbfs to fat32 without losing data
and if the program fails you are a couple of hundred gig lost
and you can start all over again
that's the big problem as no data recovery can read wbfs. When I changed my wbfs to fat 32 I left it overnight to transfer all the games as a backup then used aeseus to format the old wbfs partition, but if you don't have a spare drive big enough for a backup or a spare 9hrs or so then it may be the only optionComment
