I have softmodded my wii before and recently I started to install game channels on my Wii and somehow I installed too many games and I couldn't play my Wii. It would just say delete memory to make space. So I tried it and it didnt work so I had to reformat my Wii and I lost the Homebrew channel. I have a version 4.3 Wii and when I use HackMii it just says no vulnerable IOS found. Please help me, I would love to play all my games again.
Can't get past Hackmii Installer
Tags: None
Well it looks like you've learned the hard way, NEVER format your Wii.I have softmodded my wii before and recently I started to install game channels on my Wii and somehow I installed too many games and I couldn't play my Wii. It would just say delete memory to make space. So I tried it and it didnt work so I had to reformat my Wii and I lost the Homebrew channel. I have a version 4.3 Wii and when I use HackMii it just says no vulnerable IOS found. Please help me, I would love to play all my games again.
If you running short on memory then as you say you have to many channels on your Wii menu or you have to many saved games. Its a bit late now you've formatted but what you should have done is copy unused saved games to the SD card and channels. You can always copy them back if you need to use that game again. There should be a free block count in the bottom right thats how much memory space you have left.
There are channels that use alot of memory if you don't use them move them to the SD card. As you erase or move something you will see this free block count go up.
Have you tried LetterBomb?Keith
2010 Golf GTD (170) -
letterbomb wont work. it sound like you had darkcorp installed before which patches all your ios's try here http://sites.google.com/site/complet...-stuff/fix-hbc for fix.I have softmodded my wii before and recently I started to install game channels on my Wii and somehow I installed too many games and I couldn't play my Wii. It would just say delete memory to make space. So I tried it and it didnt work so I had to reformat my Wii and I lost the Homebrew channel. I have a version 4.3 Wii and when I use HackMii it just says no vulnerable IOS found. Please help me, I would love to play all my games again.sigpicComment
yeah it was pretty dumb of me to do that. I have tried Letterbomb and I tried creating the two Wads with NUS. It didnt work it would just tell me the same thing. I dont know what to do at this point. I did the system check and I would appreciate it if someone can look at it and help me with this issue. Here are the results I got from the system check.
sysCheck v2.1.0b5 by Double_A
?.runs on IOS236 (rev 54321).
Region: NTSC-U
System Menu 4.3U (v513)
Homebrew Channel 1.0.0 running on IOS0
Hollywood v0x11
Console ID: 33902498
Boot2 v4
Found 71 titles
Found 46 IOS on this console. 16 of them are stub.
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11(rev 256): Stub
IOS12 (rev526): No Patches
IOS13 (rev1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1032: No Patches
IOS20 (rev 256): Stub
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 54321): Trucha Bug
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3607): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 54321): Trucha Bug, ES Identify, NAND Access
IOS37 (rev 5663): No Patches
IOS38 (rev 4124):No Patches
IOS40 (rev 3072):Stub
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 5120): Stub
IOS51 (rev 4864): Stub
IOS52 (rev 5888): Stub
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6175): No Patches
IOS60 (rev 6400): Stub
IOS61 (rev 5662): No Patches
IOS70 (rev 6912): Stub
IOS80 (rev 6944): No Patches
IOS222 (rev 65280): Stub
IOS223 (rev 65280): Stub
IOS236 (rev 54321): Trucha BUg, ES Identify, NAND Access
IOS249 (rev65280): Stub
IOS250 (rev65280): Stub
IOS254 (rev 65280): Stub
BCv6
MIOSv10
Report generated on 2012/01/25Comment
When I use YAWMM and install the two WAD files how do I get out of it to go back to click on the app files to get to the hackmii installer. I tried it but it only let me get back to the Wii system menu where I had to go and do the Bathaxx thing.letterbomb wont work. it sound like you had darkcorp installed before which patches all your ios's try here http://sites.google.com/site/complet...-stuff/fix-hbc for fix.Comment
if you manage to install both wads go back to wii main menu then you can install the homebrew channel Introducing: LetterBomb (the letter from heaven)sigpicComment
ok but now I got another problem. When I do the Bathaxx when it loads up the boot.elf file it instantly takes me to the Hackmii installer. How do I get it to stop doing that?if you manage to install both wads go back to wii main menu then you can install the homebrew channel Introducing: LetterBomb (the letter from heaven)Comment
if your using bathaxx then just install the homebrew channel - bootmi and prepare the sd when hackmii installer startssigpicComment
ok format the sd card to fat32
then redo the letterbomb download and try to install againsigpicComment
