Can't get past Hackmii Installer
homebrew channel will find any ios for you try following the link again word for word if you dont have a wad folder and apps folder on the sd card anymore just make themsigpicComment
if you still dont get it running use http://www.digital-kaos.co.uk/forums...indows-170234/ install to pc make sure you update it then select h for hackmii solutions it will download you the needed files and create you a tutorialsigpicComment
ok I will try that. Thank youif you still dont get it running use http://www.digital-kaos.co.uk/forums...indows-170234/ install to pc make sure you update it then select h for hackmii solutions it will download you the needed files and create you a tutorialComment
I just tried it right now and it still didnt work. I keep on getting no vulnerable IOS foundif you still dont get it running use http://www.digital-kaos.co.uk/forums...indows-170234/ install to pc make sure you update it then select h for hackmii solutions it will download you the needed files and create you a tutorialComment
christ this is unusual try here Hackmii -FIX: no vulnerable ios, black screen, scam freeze you will need to register same here if that dont get you running then i give upsigpicComment
well I appreciate your help. Thank you for everything. Unfortunately I already tried that and I still had no luck. Thank you though I appreciate itchrist this is unusual try here Hackmii -FIX: no vulnerable ios, black screen, scam freeze you will need to register same here if that dont get you running then i give upComment
