Got a same problem over here. I got USB Loader GX (rev 910 ISO222 (rev 4)) That works fine with my HD. Now i try to install CFG USB loader it says that it cant find my HD any more. How can i fix this?
usb loader cant find HD
My Systemcheck is:
sysCheck v2.1.0b17 by Double_A and R2-D2199
...runs on IOS58 (rev 6175).
Region: PAL
System Menu 4.1E (v450)
Drive date: 2007.02.13
Homebrew Channel 1.0.0 running on IOS61
Hollywood v0x11
Console ID: 116020632
Boot2 v3
Found 156 titles.
Found 44 IOS on this console. 4 of them are stub.
IOS4 (rev 65280): Stub
IOS9 (rev 778): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 256, Info: rev 10): Trucha Bug, ES Identify, Flash Access, NAND Access
IOS12 (rev 269): Trucha Bug
IOS13 (rev 273): Trucha Bug
IOS14 (rev 520): Trucha Bug
IOS15 (rev 523): Trucha Bug
IOS16 (rev 512): Stub
IOS17 (rev 775): Trucha Bug
IOS20 (rev 256, Info: rev 12): Trucha Bug, ES Identify, Flash Access, NAND Access
IOS21 (rev 782): Trucha Bug
IOS22 (rev 1037): Trucha Bug
IOS28 (rev 1550): Trucha Bug
IOS30 (rev 2816): Trucha Bug, ES Identify, Flash Access, NAND Access
IOS31 (rev 3349): Trucha Bug
IOS33 (rev 3091): Trucha Bug
IOS34 (rev 3348): No Patches
IOS35 (rev 3349): Trucha Bug
IOS36 (rev 3351): Trucha Bug, ES Identify, NAND Access
IOS37 (rev 3869): Trucha Bug
IOS38 (rev 3867): Trucha Bug
IOS50 (rev 5120): Trucha Bug
IOS51 (rev 4864): Stub
IOS53 (rev 5406): Trucha Bug
IOS55 (rev 5406): Trucha Bug
IOS56 (rev 5405): Trucha Bug
IOS57 (rev 5661): Trucha Bug
IOS58 (rev 6175): USB 2.0
IOS60 (rev 6400): Trucha Bug
IOS61 (rev 5405): No Patches
IOS70 (rev 6687): Trucha Bug
IOS202[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS236[58] (rev 21, Info: rev 21): Trucha Bug, NAND Access, USB 2.0
IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS254 (rev 31338): BootMii
BC v6
MIOS v10
Report generated on 2012/06/05.Comment
You need to reinstall hbc it is running on ios 61 and all new loaders require it to be running on ios 58. Don't know what softmod guide you followed but don't use it again.Comment
Thx 4 the reply, i update my HBC to the new 58 IOS but i still get the error (RET = -1). You also know how to fix this? USB loader GX still works. But i try to play the game Kirby Return to dreamland. But it freez at the titel screen of the game. I read somewhere that i have to update my USB loader/IOS versions but cant get the last USB loaders working..Comment
ARRRGGG!
i have been having the exact same problem, i seem to be going round in circles, i studied loads before modding the wii, i have followed every instruction to the T, but my WD hdd isnt recognised by USB LOADER GX. i'm at my wits end. arrggg!
Welcome to DK.
What you need to do first is post a sysCheck report as instructed in that link then we can see if you have all the necessary wads installed.
If you have and your using the correct USB socket on the Wii the one nearest the edge then either your USB socket has gone duff or your USB HDD isn't compatible or you have the wrong format on that drive or you haven't loaded the games in the correct format.
How did you format this WD HDD?
If you have a big enough USB flash drive you could put 1 game on and see it that is recognised and shows in GX. If it does then the USB port must be OK then we are back to the WD drive.
Take you pick?Keith
2010 Golf GTD (170)Comment
I had this one before it was due to the partition not being marked as active, you need to mark it as active in order for the Wii to be able to see it.
I'm new here but i have had some experience with Wii's also some hard drives can be problematic so try pluging it in when the usb loader is looking for it
hope it helpsComment
WILL DO.
I will do a system check and post it on here in a day or so, i am getting ready for my brothers wedding tomorrow. thanks for your responce. i formated my hdd with partition magic to FAT32 then used WBFS manager to format it in wbfs, set a primary and active, i am using the bottom usb port as stated.
i am running IOS58 i tryed to load IOS249,222 but says STUB? thankyou again for your reply and i will get back to you as soon as i have done a sys check.
Well the sysCheck will be a better help to us see which wads you have plus we will know which Wii version your using because you don't say.
If you formatted the drive with partition magic to FAT32 why did you use WBFS Manager and format it again? I know WBFS Manager needs to use wbfs format. I use WBFS Manager and everything works on my drive.
As for installing IOS249, IOS222 you may as well install all the wads in Full Cios wad pack that has d2x v8.0 as well but install the other wads before the d2x wads.Keith
