usb loader gx problem
  • Keithuk
    • 2264
    #91
    If wads don't install the first time with MMM keep trying them until they do, they always install first time for me.
    Please post your sysCheck report as stated in that link Sam.
    Keith
    2010 Golf GTD (170)
    • ck-ok
      • 2592
      #92
      have you actually read any of his other posts or just the last one? he has already posted his syscheck in post 80.
      • Keithuk
        • 2264
        #93
        Sorry CK I do read the replies I must have missed he had posted it later on.
        When you try to run USB Loader GX from HBC it will say needs cIOS222, cIOS249 or cIOS250 as instructed install d2x v7 Final that will install all the necessary wads needed for USB Loaders.
        I see you've post the sysCheck report and as suspected you don't have the d2x v7 wads installed, do that or you will never get USB Loaders to work.
        I noticed it after I posted that, we will have to see if he installs d2x v7.
        Keith
        2010 Golf GTD (170)
        • happy_highlander
          • 3535
          #94
          Originally posted by sam9s
          Not deleting any more ios highlander ... waiting for your specific instructions ....
          I'm on 24 hr call today mate but you don't have ios 36 patched either so you will struggle to install 236. Find an ios 236 installer (some of the other lads may be able to help with this) and use that to patch ios 36 and install 236, then grab the d2x v8 final pack I uploaded and follow the instructions. I'll be about but struggle to give you links from my phone
          • Keithuk
            • 2264
            #95
            Digital Kaos - Downloads - ios 36 v3608
            Though this is IOS36 v3608 which he already has.
            I don't have my sysCheck with me so I can't check which version I use.
            Digital Kaos - Downloads - ios236 v54321 wad
            Install them both with MMM.
            Keith
            2010 Golf GTD (170)
            • happy_highlander
              • 3535
              #96
              That is the version number for ios 36 but it is not patched on his syscheck.......Just had thought though and that is if I'm not mistaken mmm will install a patched ios 36 from the main menu he should then be able to install 236. He may have to reload tho ios 36 to install 236 though as he doesn't have a patched ios 249 to install it into. I may be wrong as my heads mush already and I'm only 10 hours in
              • ck-ok
                • 2592
                #97
                mmm will patch his ios36 and 236
                Install & Patch IOS36:
                - upgraded to support Nintendo's Sep7 IOS updates
                - installs patched IOS36 as IOS36 & IOS236
                - IOS36-64-v3608.wad used as base IOS
                • Keithuk
                  • 2264
                  #98
                  Well I've just had a look at my sysCheck and its the same as his IOS36 (rev 3608): No Patches mines not Patched and everything works on mine.
                  My 236 is IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
                  Keith
                  2010 Golf GTD (170)
                  • sam9s
                    • Mar 2012
                    • 5
                    #99
                    Ok Time to udate, first thanks to all of you for such a details insight in to the Wii Modding. Second, I finally was able to install cIOS 236. The error I was getting -2011 was not because of the file I guess, but because I was not having the correct patcher/installer to install it. I went with mod mii method and just downloaded the cIOS installer, I already had the wad file. With the correct installer the patching went just fine.
                    Once cIOS 236 was installed, I then was easily able to install all other necessay WADs using the mmm tool. Tested wii with a small Wild Wild West shooter wii game and it worked pefectly. Once again thanks to all, specially Highlander ....and CK for providing the Modmii tool.
                    I also did the preloader thingi to prevent the online updates.
                    Just few more things more, .... The GX Usb tool, when loaded, says there is no image to display of the game, in the menu. How can I have the image icons of the games on my HDD.
                    Second is there a way to take a complete backup of the entire wii modded structure so that its kinda easy to do it, if I hve to do it again (for what ever reasons)
                    and lastly, what else can I do now that I have moded and uploaded the USB loader as well, you know just pushing the wii a bit more .... ;-)
                    Regards
                    Sammy
                    • Keithuk
                      • 2264
                      #100
                      I assume you mean Gunslingers - NTSC - SW7EVN great game.
                      When you load USB Loader GX and the game images show the ? image click on the 5th icon on the icon bar at the top. This shows the game image on the left (? mark image or otherwise) and the game lists on the right. Click on any game image even if it shows the ? image and put a tick in all the options then click OK to load them all. Then click on the fan icon on the top icon bar to show all the games on the drive. All these png pictures are stored on the SD card in the config folder.
                      Second is there a way to take a complete backup of the entire wii modded structure so that its kinda easy to do it, if I have to do it again (for what ever reasons)
                      Just make a backup of the SD card now you know which extra wads needed to be installed with MMM.
                      Keith
                      2010 Golf GTD (170)
                      • jasgreen23
                        • Mar 2012
                        Thanks! i needed this.
                        • Computerflake
                          • Mar 2012
                          Man, you guys are good. I've having the same problem so I'm going to try what you recommended.
                          • Keithuk
                            • 2264
                            #103
                            I've just had Mad Dog McCree Gunslinger Pack - NTSC - RQ5E5G and RF/PAL - RQ5X5G
                            [ame="http://www.youtube.com/watch?v=BUJKPqI6ECY"]Mad Dog McCree: Gunslinger Pack (Wii) Review - YouTube[/ame]
                            As it says the gun reload it crap. Why it uses the nunchuck beats me as it does nothing. Plus your gun sound comes from the Wiimote not the TV.
                            Keith
                            2010 Golf GTD (170)
                            • amishone
                              • Mar 2012
                              Awesome forum thus far. Tons of good information here, thanks.
                              • mjbush89
                                • Apr 2012
                                • 8
                                #105
                                im new to hacking the wii i have hbc just watched [ame=http://www.youtube.com/watch?v=pHhGWIs_HEU]Wii 4.3 USB Loader GX - Tutorial Part 1 - YouTube[/ame]
                                is there anything else i should know when hacking the wii??
