how do i play wii games from a usb stick??? help
  • Keithuk
    • 2264
    #31
    Well I don't know what you've done as the wads I told you to install will not upgrade a 3.2E to 4.1E only a system update will do that to 4.3E then you would have to softmod it again.
    If it sees the games on the drive but takes minutes to load them what the make an model of the drive, I hope it isn't a USB powered drive?
    If after trying to load it goes back to USB Loader GX and shows 12 Wii channels thats because it can't find or read the drive so it adds the channels in place of games.
    What are you using to add these games to the drive?
    USB Compatibility List
    USB Devices Compatibility List
    Keith
    2010 Golf GTD (170)
    • derbyed
      • Jul 2010
      • 23
      #32
      I am using a 16 gig flash drive and I transferred the game via Wii backup manager.. On the loader on the bottom lefthand side it says load games I click on that and another box opens and it says loading and a countdown which says 12 mins or so....The only thing I have done is everything you told me about I have not upgraded it ..so it did it on something I've loaded re mmm and the ios's
      • Keithuk
        • 2264
        #33
        Well as I've said I can't see anything wrong with your last sysCheck the only query I had was the first one showed 3.2E and the last one 4.1E which to me its done a system update. Now if you have let the Wii do a system update it would now be 4.3E. There are apps I think that will update your Wii to a newer version, make sure you know what every app does in the apps folder.
        I don't know what more to suggest as I've added 4 wbfs games in the wbfs folder on a NTFS formatted 4GB USB flash drive. I put it in the Wii and ran USB Loader GX and all 4 games showed and they played. I would seriously look at getting a bigger mains powerd HDD to add your games onto.
        You could try formatting it NTFS then add the games on it. The later USB Loaders support NTFS drives.
        Keith
        2010 Golf GTD (170)
        • coppertopneo
          • Feb 2013
          need little help
          I have been reading your response to other people, and it has helped me modd my wii. I do have one problem. i can play all wii games fine. But when i try to play windwaker GameCube on my wii. it will not work. I used the ModMii program. What files do i need and programs? thanks
          I have tryed useing other tuts, but there downloads are in different language and missing the miso and the wad files, thanks for help in advance
          • Keithuk
            • 2264
            #35
            Welcome to DK.
            I can't really tell you about GameCube games as I don't use them. Before we start guessing whats wrong with your Wii we need to see a sysCheck19 report as instructed in that link to make sure you have all the correct IOS's installed.
            Whats happened to DK over the past few days no part of the forum has shown up, have it been down for maintenance?
            Update:
            I've found out why DK wasn't showing. http://www.digital-kaos.co.uk/forums...oblems-321034/
            Keith
            2010 Golf GTD (170)
            • AmethystSpark
              • Aug 2013
              Hey I'm also having trouble. I downloaded a couple games to my 32gb flash drive and I believe usb loader has read that it's there but I have no idea how to find and install those games. Any help would be appreciated. I have mmm with the cios wads and whatnot so no worries there.
              • Keithuk
                • 2264
                #37
                Welcome to DK.
                Well you must have read other post on here.
                Post a sysCheck19 report as instructed in that link so I can see which IOS's you've installed.
                Keith
                2010 Golf GTD (170)
                • rmagnus
                  • Jul 2013
                  • 6
                  #38
                  thank you!
                  this info is great!
                  • rmagnus
                    • Jul 2013
                    • 6
                    #39
                    Hello!
                    When I try to install IOS236 it says that it was not completed.
                    Here is my syscheck.
                    PLEASE HELP!
                    THANK YOU
                    sysCheck v2.1.0b17 by Double_A and R2-D2199
                    ...runs on IOS58 (rev 6176).
                    Region: NTSC-U
                    System Menu 4.3U (v513)
                    Drive date: 2008.12.18
                    Homebrew Channel 1.0.0 running on IOS58
                    Hollywood v0x21
                    Console ID: 139377307
                    Boot2 v4
                    Found 93 titles.
                    Found 47 IOS on this console. 17 of them are stub.
                    IOS3 (rev 65280): Stub
                    IOS4 (rev 65280): Stub
                    IOS9 (rev 1034): No Patches
                    IOS10 (rev 768): Stub
                    IOS11 (rev 256): Stub
                    IOS12 (rev 526): No Patches
                    IOS13 (rev 1032): No Patches
                    IOS14 (rev 1032): No Patches
                    IOS15 (rev 1032): No Patches
                    IOS16 (rev 512): Stub
                    IOS17 (rev 1032): No Patches
                    IOS20 (rev 256): Stub
                    IOS21 (rev 1039): No Patches
                    IOS22 (rev 1294): No Patches
                    IOS28 (rev 1807): No Patches
                    IOS30 (rev 2816): Stub
                    IOS31 (rev 3608): No Patches
                    IOS33 (rev 3608): No Patches
                    IOS34 (rev 3608): No Patches
                    IOS35 (rev 3608): No Patches
                    IOS36 (rev 3608): No Patches
                    IOS37 (rev 5663): No Patches
                    IOS38 (rev 4124): No Patches
                    IOS40 (rev 3072): Stub
                    IOS41 (rev 3607): No Patches
                    IOS43 (rev 3607): No Patches
                    IOS45 (rev 3607): No Patches
                    IOS46 (rev 3607): No Patches
                    IOS48 (rev 4124): No Patches
                    IOS50 (rev 5120): Stub
                    IOS51 (rev 4864): Stub
                    IOS52 (rev 5888): Stub
                    IOS53 (rev 5663): No Patches
                    IOS55 (rev 5663): No Patches
                    IOS56 (rev 5662): No Patches
                    IOS57 (rev 5919): No Patches
                    IOS58 (rev 6176): USB 2.0
                    IOS60 (rev 6400): Stub
                    IOS61 (rev 5662): No Patches
                    IOS62 (rev 6430): No Patches
                    IOS70 (rev 6912): Stub
                    IOS80 (rev 6944): No Patches
                    IOS222 (rev 65280): Stub
                    IOS223 (rev 65280): Stub
                    IOS249 (rev 65280): Stub
                    IOS250 (rev 65280): Stub
                    IOS254 (rev 65281): BootMii
                    BC v6
                    MIOS v10
                    Report generated on 2013/08/30.
                    • Keithuk
                      • 2264
                      #40
                      Thats a typical Wii thats only been softmodded with 17 IOS's that are Stub.
                      Now you have sysCheck.csv on the root of the SD card from your sysCheck.
                      This has been posted many times on here if you browse?
                      Download ModMii6.2.7 and run it from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
                      ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and install all 7 wads when you install the other wads.
                      Put the SD card back in the Wii and run Homebrew. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
                      Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
                      Download PriiLoader 0.7 add it to the SD card and run it from Homewbrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
                      If you have to update to 4.3 then the Shopping Channel may work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21 with Multi Mod Manager
                      Do another sysCheck to make sure everything installed correctly and post that.
                      Keith
                      2010 Golf GTD (170)
                      • rmagnus
                        • Jul 2013
                        • 6
                        #41
                        Wow! that was quick! you are the man!
                        Is there a problem running modmii under XP? It just crashes saying:
                        ModMii Launcher has encountered a problem and needs to close. We are sorry for the inconvenience
                        Should I use another computer? I only have one at home
                        Rodolfo
                        • rmagnus
                          • Jul 2013
                          • 6
                          #42
                          Nevermind...... sorry..... I did not copy all the files..... now I will follow your instructions.....
                          • Keithuk
                            • 2264
                            #43
                            No ModMii works on all Windows versions with a web connection providing you extract all files to a folder and run Modmi.exe.
                            Keith
                            2010 Golf GTD (170)
                            • rmagnus
                              • Jul 2013
                              • 6
                              #44
                              I INSIST.....YOU ARE THE MAN!!!!!
                              I got my usb loader working. THANK YOU!!!!!
                              how do I add the usb loader to the wii menu?
                              I have little kids that I dont want to mess with the homebrew channel........ BTW can I delete all the apps that appear now next to the USB loader like priiloader? Or are they needed?
                              THANK YOU AGAIN......Rod
                              Here is my report.....
                              sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
                              Region: NTSC-U
                              Priiloader installed
                              Homebrew Channel 1.1.0 running on IOS58
                              HomebrewFilter ist nicht installiert
                              Hollywood v0x21
                              Boot2 v4
                              Found 102 titles.
                              Found 55 IOS on this console. 5 of them are stub.
                              IOS11 (rev 16174): Trucha Bug, NAND Access
                              IOS20 (rev 16174): Trucha Bug, NAND Access
                              IOS30 (rev 16174): Trucha Bug, NAND Access
                              IOS40 (rev 16174): Trucha Bug, NAND Access
                              IOS50 (rev 16174): Trucha Bug, NAND Access
                              IOS52 (rev 16174): Trucha Bug, NAND Access
                              IOS60 (rev 16174): Trucha Bug, NAND Access
                              IOS70 (rev 16174): Trucha Bug, NAND Access
                              IOS80 (rev 16174): Trucha Bug, NAND Access
                              IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
                              IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
                              IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
                              IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
                              IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
                              IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                              IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
                              IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                              IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                              IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                              IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                              IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                              BC v6
                              MIOS v10
                              Rod
                              • Keithuk
                                • 2264
                                #45
                                I assume your using USB Loader GX 3.0? Yes you can download the forwarder wad USB Loader GX-UNEO_Forwarder_5_1_AHBPROT.wad and add it to the wad folder on the SD card and install it with MMM.
                                Do you mean apps on the SD card?
                                You will need Multi Mod Manager (MMM) to install any wads, did you update the Shopping Channel with my RVL-Shopping-21, but after that you can delete it. The Forecast Channel and News Channel aren't available any more and you can't remove them from Channels so you may as well select them and press 'A' & 'B' buttons and drag them to the right.
                                You need to leave USB Loader GX else it won't work. The Forwarder Channel is like a Windows short-cut to USB Loader GX on the SD card.
                                If you delete PriiLoader of the SD card check that it still works because there are ini files that it uses. Turn off the Wii Hold the Reset button as the Wii it starting up.
                                You can delete other apps so the kids don't mess with them but keep a backup on your computer. There are other apps you can add to the SD card WiiEarth is like Google Earth. Playstats is an app that shows you how many time each game has been played and for how long. Rokoban is like the Sokoban game where you push blocks into a finish area. Mahjongg Wii is a Mahjongg game, very good. There are loads of games you can add to the SD card Wii Games
                                There is Configurable USB Loader and WiiFlow if you want to try those as each USB Loader has different features, they also have Forwarder Channels.
                                The way to thank me for helping you out Rod is click the Thanks button under each post thats helped you.
                                Keith
                                2010 Golf GTD (170)
