how do i play wii games from a usb stick??? help
  • rmagnus
    • Jul 2013
    • 6
    #46
    IT IS WORKING NOW! Thanks
    • pham9999
      • Oct 2013
      hey guys
      ok so im in the same boat as total newby where as it wont install ios236 heres my syscheck report though
      sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
      ...runs on IOS58 (rev 6176).
      Region: PAL (original region: AUS)
      System Menu 4.3E (v514)
      Drive date: 2008.07.14
      Homebrew Channel 1.1.0 running on IOS58
      HomebrewFilter ist nicht installiert
      Hollywood v0x11
      Console ID: 85105011
      Boot2 v4
      Found 101 titles.
      Found 47 IOS on this console. 16 of them are stub.
      IOS3 (rev 65280): Stub
      IOS4 (rev 65280): Stub
      IOS9 (rev 1034): No Patches
      IOS10 (rev 768): Stub
      IOS11 (rev 256): Stub
      IOS12 (rev 526): No Patches
      IOS13 (rev 1032): No Patches
      IOS14 (rev 1032): No Patches
      IOS15 (rev 1032): No Patches
      IOS16 (rev 512): Stub
      IOS17 (rev 1032): No Patches
      IOS20 (rev 256): Stub
      IOS21 (rev 1039): No Patches
      IOS22 (rev 1294): No Patches
      IOS28 (rev 1807): No Patches
      IOS30 (rev 2816): Stub
      IOS31 (rev 3608): No Patches
      IOS33 (rev 3608): No Patches
      IOS34 (rev 3608): No Patches
      IOS35 (rev 3608): No Patches
      IOS36 (rev 3608): No Patches
      IOS37 (rev 5663): No Patches
      IOS38 (rev 4124): No Patches
      IOS40 (rev 3072): Stub
      IOS41 (rev 3607): No Patches
      IOS43 (rev 3607): No Patches
      IOS45 (rev 3607): No Patches
      IOS46 (rev 3607): No Patches
      IOS48 (rev 4124): No Patches
      IOS50 (rev 5120): Stub
      IOS51 (rev 4864): Stub
      IOS52 (rev 5888): Stub
      IOS53 (rev 5663): No Patches
      IOS55 (rev 5663): No Patches
      IOS56 (rev 5662): No Patches
      IOS57 (rev 5919): No Patches
      IOS58 (rev 6176): USB 2.0
      IOS60 (rev 6400): Stub
      IOS61 (rev 5662): No Patches
      IOS62 (rev 6430): No Patches
      IOS70 (rev 6912): Stub
      IOS80 (rev 6944): No Patches
      IOS222 (rev 65280): Stub
      IOS223 (rev 65280): Stub
      IOS249 (rev 65280): Stub
      IOS250 (rev 65535): Trucha Bug ES Identify NAND Access USB 2.0
      IOS254 (rev 65281): BootMii
      BC v6
      MIOS v10
      Report generated on 2013/11/02.
      • Keithuk
        • 2264
        #48
        Welcome to DK pham9999.
        As you may have read on here thats a typical sysCheck of a Wii thats only been softmodded as you have 16 IOS's that are Stub.
        Download ModMii6.2.7 and run it from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
        ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and install all 7 wads when you install the other wads.
        Put the SD card back in the Wii and run Homebrew. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
        Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
        Download PriiLoader 0.7 add it to the SD card and run it from Homewbrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
        If you have to update to 4.3 then the Shopping Channel may work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21
        Do another sysCheck to make sure everything installed correctly and post that.
        Then you just have a to find a compatible mains powered USD hard drive to add your games onto and download USB Loader GX 3.0 to run them.
        Keith
        2010 Golf GTD (170)
