wii ver 4.3e
Why are you looking at downloading games or having a game when you haven't finished the softmod and installed any USB Loaders?
Downloading what?
The Hackmii installer is for softmodding so you trying to softmod it again, for why what have you missed?Keith
2010 Golf GTD (170)Comment
Do you need to rehack your wii or do you already have the homebrew channel on ios 58 ??????
Have you put the correct mac address for your wii in ?????
We don't know what you have already done or are doing
Do you have anything at all from modmiiComment
Had you tried what I said before?
Once its softmoded then we can move on.The first thing you need to do is buy/get a 2GB SD card. I know its a 4.3 which will use larger SDHC cards but you can't softmod with those.
The easiest way to softmod is to use Letterbomb. Just start the Wii up and click on Wii Options bottom left and click on Wii Settings the spanner. Click right to Internet and click on it then click on Console Information. This will show the MAC address for that Wii, write the numbers and letters down as you will need to type this number back in on the Letterbomb site so it will send a message to that Wii.
That site is abit confusing because it says A SD(HC) card with some free space
An SDHC won't softmod a Wii.
Click on the LetterBomb link and it will default to a 4.3E at the top just type in the MAC adress in the boxes. Type in the spam words and click the Cut the Red Wire button to download Letterbomb.zip to your drive.
Extract all files from the zip to the 2GB SD card formatted to FAT32. Put the SD card in the Wii start the Wii up then click on the messages buttom bottom right and scroll back a few days untill you see the red envelope then click on it. The SD card has to be inserted before you see this red envelope so don't click on messages if its not unserted as you won't see the red envelope.
Now the only pain with Letterbomb is it can take a while before the message appears, just keep checking the messages every 10 minutes or so. When I first used Letterbomb I typed the MAC address in and by the time I had put the files on the SD card and stuck it in the Wii I clicked on messages and it was there. The other 2 Wii's I tried to softmod the same way no message appeared for 2 hours. I used my LEGO Indiana Jones - Original Adventures disc with the same SD card and it worked perfectly.
You must use all 3 options once it starts after the copyright screen.
1. Install Homebrew
2. Install BootMii on IOS
3. Prepare SD card - this is so you can do a NAND backup straight after softmodding. NAND backup Don't forget this backup its just in case you do something wrong and you brick your Wii.
That will softmod the Wii only. Then you need to read some threads on adding USB Loaders which wads you need to install with MMMKeith
Happy oldfellow aart from cod
Update hi guys finaly got it softmdded after a few fights with the wii
thanks to a few guys on ere but aww the games i tok a back up off [wink wink]
are aww fine aparet fae cod games it loads u fine then when its just about to run the black screen come up saying loading...
then thats aww it does any pointers guys plz would be great
cios 250 on d2x if you got it from here or modmii but if you got it from elsewhere you just need to make sure the cios has a 56 base e g cios 250(56) d2x v8 this still work on all cod games. While we are at it all mic (singing) games run of cios 223 or 224Update hi guys finaly got it softmdded after a few fights with the wii
then thats aww it does any pointers guys plz would be greatComment
syscheck finaly
sysCheck v2.1.0b11 by Double_A and R2-D2199
...runs on IOS236 (rev 65535).
Region: PAL
System Menu 4.3E (v514)
Priilaoder installed
Homebrew Channel 1.0.0 running on IOS58
Hollywood v0x11
Console ID: 104897391
Boot2 v4
Found 125 titles.
Found 48 IOS on this console. 5 of them are stub.
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 16174): Trucha Bug, NAND Access
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1032): No Patches
IOS20 (rev 16174): Trucha Bug, NAND Access
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 16174): Trucha Bug, NAND Access
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 16174): Trucha Bug, NAND Access
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 16174): Trucha Bug, NAND Access
IOS51 (rev 4864): Stub
IOS52 (rev 16174): Trucha Bug, NAND Access
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 16174): Trucha Bug, NAND Access
IOS61 (rev 5662): No Patches
IOS70 (rev 16174): Trucha Bug, NAND Access
IOS80 (rev 16174): Trucha Bug, NAND Access
IOS202[60] (rev 65535, Info: v5.1): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 65535, Info: v5.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38] (rev 4, Info: v0.1): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: v5.0): Trucha Bug, NAND Access, USB 2.0
IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
IOS249 (rev 65280): Stub
IOS250[57] (rev 21007, Info: d2x-v7final): Trucha Bug, NAND Access, USB 2.0
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2012/07/13.
Again guys sorry for the delay hope this helps for you to clear my cod problem thanks in advanceComment
You cannot play games because cios 249 has been stubbed out. Go to the downloads section and find the full cios pack and download it then install all the wads. Sorry I can't link for you from phone.sysCheck v2.1.0b11 by Double_A and R2-D2199
Region: PAL
Hollywood v0x11
Boot2 v4
Found 125 titles.
BC v6
MIOS v10
