Wii Softmod 4.2u USBLoader not working
  • Cbeast
    • Aug 2012
    • 27
    Hi guys,
    This is my first post on this forum, or any forum for that matter. I just can't figure this one out. I had a guy mod my wii for me a while back, my son uses it constantly. Now the USB Loader will not work. It says exception dsi error. Ive tried reading a million threads about it but still nothing. when i go in the homebrew channel it says IOS61 V21.29 and on top 1.0.5. I tried loading a new usbloader on and it says
    USB loader GX needs unstubbed cIOS 222 v4 or 249 v9
    Go get some cios action going and come back and see me.
    1 found
    222 - 0
    249 - 0
    I understand you might need more information and might have to have a lil patience with me, because im new to this, I feel i could mod a wii starting from new pretty easy now
    thanks for your patience in advance.
  • Cbeast
    • Aug 2012
    • 27
    Also anytime i try to install IOS 249 it just freezes, nothing happens.
    • Keithuk
      • 2264
      This is a triple post read your other one. http://www.digital-kaos.co.uk/forums...lp-pls-288819/
      WAD Managers freeze on me use Multi-Mod Manager (MMM)
      Keith
      2010 Golf GTD (170)
      • Cbeast
        • Aug 2012
        • 27
        Sorry, Once i posted that i noticed it probably wasn't in the right section (gaming lounge) I'll try to delete it.
        • Cbeast
          • Aug 2012
          • 27
          Sorry in advance for my experience level. I downloaded MMM from that link you posted but i'm not sure how to install it after that, I put it all on my SD Card and went to Bootmi but black screen. Should i start everything over from scratch, if so, whats my best plan
          • Cbeast
            • Aug 2012
            • 27
            It almost seems like everything i try to install freezes or black screen. Bad memory card maybe? I also tried anytile deleter to get rid of usbloader and put it back on but it gives a lot of errors.
            • Keithuk
              • 2264
              You download Multi-Mod-Manager_v13.4.zip and extract the MMM folder into SD: apps\MMM folder then run it from Homebrew.
              Select WAD Manager and that will default to the wad folder, find the wads you want to install. If you press 'A' it will install all wads in that folder. You can scroll down the wads and press the + button that will put a green tick by that wad select more wads and put a tick next to those then press 'A' to install all selected wads then wait for the message installed correctly after each one. If they don't install try them again.
              After you have install some wads come back out to Homebrew then go along to sysCheck after you've added that to your SD card. Then you will see which wads are installed, post a report as instructed in that link.
              Keith
              2010 Golf GTD (170)
              • Cbeast
                • Aug 2012
                • 27
                Thanks for the quick reply. I will try this when i get home from work. One other wuestion. Do i need internet on the Wii for any of this?
                • Keithuk
                  • 2264
                  You don't need an internet connection to use MMM because it installs the wads of the SD card. You could do with it if your going to use any of the USB Loaders so it can download the game pictures.
                  Do you have a router for your computer? Its easy enough to setup an internet connection just into Wii Settings Internet and let it search for available WiFi connections when it finds your router just type in the security password then it will check if the connection is good, job done.
                  Its a very long process but you could download your own pictures if you know the game ID or name. Wii Boxart
                  Keith
                  2010 Golf GTD (170)
                  • Cbeast
                    • Aug 2012
                    • 27
                    I have internet but no wifi connector for my wii, I would buy one if it was needed to fix it but if not i wont bother. Just wanna get it back up and running. Not even sure why it stopped working, ive never hooked it to the internet before since modded. then my son took it to his sitters and came back with it not working, when i first tried it, it said exception DSI error i searched alot on it but didn't get a fix. So i thought i would try this route
                    • Cbeast
                      • Aug 2012
                      • 27
                      Ok so i did what you said but when i try to install anything it says 1 did not finish, if i click the + on 3 it says 3 did not finish, seems like everything i try to install doesnt work. it says current IOS36 v3351 and when i try to install usbloader again it says error get some iso going and come back and see me, ill try the syscheck next
                      • Cbeast
                        • Aug 2012
                        • 27
                        I wasn't sure what ios to select when runing sys check on ios36 it says
                        syscheck v2.1 0b17 byDouble_A and R2-D2199
                        ..runs on IOS36 (rev3351)
                        Region: NTSC-U
                        system menu 4.2U (v481)
                        Could not detect the drive date!
                        Homebrew channel 1.0.1 running on IOS61
                        Hollywood v0x21
                        Console ID: 132168699no patches
                        Boot2 v4
                        Found 156 titles
                        Found 37IOS on this concole. 13 of them are stub
                        IOS36 (rev 3351):
                        Ill try IOS61 too incase
                        • Cbeast
                          • Aug 2012
                          • 27
                          now syscheck is freezing and acting weird, it's not letting me select IOS anymore, eventually it just runs , looks like it runs all, then says success, do you want to display the report, but i can't do anything. I wont do anything else until i hear from someone on here
                          • Keithuk
                            • 2264
                            When you run sysCheck you just press 'A' to scan for all wads not individual ones.
                            From the bit you've posted its an old Wii that probably been updated to 4.2U some time because Homebrew is running on IOS61 mine is on IOS58. It can't find the Drive date either which is strange.
                            I assume you don't have Priiloader installed?
                            Are you sure this Wii hasn't been chipped?
                            It says 13 of them are stub its the IOS's on stub that you have to fix.
                            My sysCheck I'm running a newer version of Homebrew:
                            sysCheck v2.1.0b18 by Double_A and R2-D2199
                            ...runs on IOS58 (rev 6176).
                            Region: PAL
                            System Menu 4.3E (v514)
                            Drive date: 2008.07.14
                            Homebrew Channel 1.1.0 running on IOS58
                            Hollywood v0x11
                            Console ID: 91742115
                            Boot2 v4
                            Found 175 titles.
                            Found 54 IOS on this console. 5 of them are stub.
                            IOS3 (rev 65280): Stub
                            IOS4 (rev 65280): Stub
                            IOS9 (rev 1034): No Patches
                            IOS10 (rev 768): Stub
                            IOS11 (rev 16174): Trucha Bug, NAND Access
                            IOS12 (rev 526): No Patches
                            IOS13 (rev 1032): No Patches
                            IOS14 (rev 1032): No Patches
                            IOS15 (rev 1032): No Patches
                            IOS16 (rev 512): Stub
                            IOS17 (rev 1032): No Patches
                            IOS20 (rev 16174): Trucha Bug, NAND Access
                            IOS21 (rev 1039): No Patches
                            IOS22 (rev 1294): No Patches
                            IOS28 (rev 1807): No Patches
                            IOS30 (rev 16174): Trucha Bug, NAND Access
                            IOS31 (rev 3608): No Patches
                            IOS33 (rev 3608): No Patches
                            IOS34 (rev 3608): No Patches
                            IOS35 (rev 3608): No Patches
                            IOS36 (rev 3608): No Patches
                            IOS37 (rev 5663): No Patches
                            IOS38 (rev 4124): No Patches
                            IOS40 (rev 16174): Trucha Bug, NAND Access
                            IOS41 (rev 3607): No Patches
                            IOS43 (rev 3607): No Patches
                            IOS45 (rev 3607): No Patches
                            IOS46 (rev 3607): No Patches
                            IOS48 (rev 4124): No Patches
                            IOS50 (rev 16174): Trucha Bug, NAND Access
                            IOS51 (rev 4864): Stub
                            IOS52 (rev 16174): Trucha Bug, NAND Access
                            IOS53 (rev 5663): No Patches
                            IOS55 (rev 5663): No Patches
                            IOS56 (rev 5662): No Patches
                            IOS57 (rev 5919): No Patches
                            IOS58 (rev 6176): USB 2.0
                            IOS60 (rev 16174): Trucha Bug, NAND Access
                            IOS61 (rev 5662): No Patches
                            IOS70 (rev 16174): Trucha Bug, NAND Access
                            IOS80 (rev 16174): Trucha Bug, NAND Access
                            IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
                            IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
                            IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
                            IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
                            IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
                            IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                            IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
                            IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                            IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                            IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                            IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                            IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
                            IOS254 (rev 65281): BootMii
                            BC v6
                            MIOS v10
                            Try and run another full sysCheck.
                            If push comes to shove you could update your Wii to 4.3U and softmod it again, but you will need a web connection to do this.
                            I'm surprise that HH hasn't made a comment in here yet as he is the Wii expert.
                            Keith
                            2010 Golf GTD (170)
                            • Cbeast
                              • Aug 2012
                              • 27
                              Ok. When i get home I will run the full syscheck again if i can. It seemed to be acting weird the second time tho. The first time i could pick between IOS and choose one to run a scan on, the 2nd time i could do anything and it just started scanning all of them, and then when it finished successfully it just sat there. Did not let me press A to view it all. But i will give it another try when i get home. I'm almost positive it's never been on the internet since it was originally modded.
