Wii Softmod 4.2u USBLoader not working
  • Cbeast
    • Aug 2012
    • 27
    #16
    It is a 4.2U if that helps anything.
    • Cbeast
      • Aug 2012
      • 27
      #17
      Any chance it could be my memory card making things act weird? Maybe need a new one? I just thought maybe because alot of things i try to install have issues and errors.
      • Cbeast
        • Aug 2012
        • 27
        #18
        Ok, so im home now and ran syscheck (from new memory card to be sure) and its doing the same thing, not like before when i could select IOS, now it sits there for a sec and runs on its on scanning all of them and then says successful do you want to display the report but it doesnt let me press A its like its froze. also, i loaded a different usbloader through HBC and it loaded in showing all my games but when i select one it takes me back to the HBC, so confusing, any help would be great, thanks in advance
        • Cbeast
          • Aug 2012
          • 27
          #19
          Srry, it was because i was using a controller that was #2 instead of one, running the scan again, update in a minute with results
          • Cbeast
            • Aug 2012
            • 27
            #20
            Wii system information
            system menu 4.2 on IOS70
            Console region usa
            video standard ntsc
            If that helps any
            • Cbeast
              • Aug 2012
              • 27
              #21
              sysCheck v2.1.0b17 by Double_A and R2-D2199
              ...runs on IOS36 (rev 3351).
              Region: NTSC-U
              System Menu 4.2U (v481)
              Could not detect the drive date!
              Homebrew Channel 1.0.1 running on IOS61
              Hollywood v0x21
              Console ID: 132168699
              Boot2 v4
              Found 157 titles.
              Found 37 IOS on this console. 13 of them are stub.
              IOS3 (rev 65280): Stub
              IOS4 (rev 65280): Stub
              IOS9 (rev 778): No Patches
              IOS10 (rev 768): Stub
              IOS11 (rev 256): Stub
              IOS12 (rev 269): No Patches
              IOS13 (rev 273): No Patches
              IOS14 (rev 520): No Patches
              IOS15 (rev 523): No Patches
              IOS16 (rev 512): Stub
              IOS17 (rev 775): No Patches
              IOS20 (rev 256): Stub
              IOS21 (rev 782): No Patches
              IOS22 (rev 1037): No Patches
              IOS28 (rev 1550): No Patches
              IOS30 (rev 2816): Stub
              IOS31 (rev 3349): No Patches
              IOS33 (rev 3091): No Patches
              IOS34 (rev 3348): No Patches
              IOS35 (rev 3349): No Patches
              IOS36 (rev 3351): No Patches
              IOS37 (rev 3869): No Patches
              IOS38 (rev 3867): No Patches
              IOS50 (rev 5120): Stub
              IOS51 (rev 4864): Stub
              IOS53 (rev 5406): No Patches
              IOS55 (rev 5406): No Patches
              IOS56 (rev 5405): No Patches
              IOS57 (rev 5661): No Patches
              IOS60 (rev 6400): Stub
              IOS61 (rev 5405): No Patches
              IOS70 (rev 6687): No Patches
              IOS222 (rev 65280): Stub
              IOS223 (rev 65280): Stub
              IOS249 (rev 65280): Stub
              IOS250 (rev 65535): Trucha Bug ES Identify NAND Access USB 2.0
              IOS254 (rev 31338): BootMii
              BC v6
              MIOS v10
              Report generated on 2012/08/28.
              • Keithuk
                • 2264
                #22
                You have alot of the main IOS's missing if your going to use the USB Loaders. Download IOS36 and install it with MMM.
                Then install IOS236 then install IOS58
                Then install all wads in Full Cios wad pack
                Then run sysCheck and post a new report.
                If you don't have PriiLoader 0.7 then you can add that later to block online and disc updates.
                Keith
                2010 Golf GTD (170)
                • Cbeast
                  • Aug 2012
                  • 27
                  #23
                  Thank you, ill work on that now. Appreciate the reply
                  • Cbeast
                    • Aug 2012
                    • 27
                    #24
                    I dont know what im doing wrong but when i try to install it with MMM it says final status 1 did not complete. any ideas? that was on IOS36
                    • Keithuk
                      • 2264
                      #25
                      Well this IOS36 can be a pain download ModMii6.1.5.zip put your sysCheck.csv on the root of a drive its saved typos when you type in its location.
                      When you run ModMii.exe from Windows type in SU which is a SysCheck Update. It asks for the location of your sysCheck.csv file then it will check for any updates. If there are any it will create a COPY_TO_SD_CARD sub folder just copy all the files and folders to the SD card and install all the wads it downloads. Just remove all the existing wads so you don't get confused what to install.
                      WHen I did this a while ago it downloaded a new app IOS236-v5-Mod and a IOS36 wad on the SD card root and that app installed it. I don't know why the app is called IOS236 when it installs IOS36?
                      Keith
                      2010 Golf GTD (170)
                      • Cbeast
                        • Aug 2012
                        • 27
                        #26
                        keith , you are the man. Thanks so much for your help. Really appreciate it. One i downloaded ModMii6.1.5.zip it downloaded 49 files to the copy to sd folder, then things started to happen. I did say 15 did not finish but at least somethings were finishing. Then i installed everything else. I was still having problems loading USBloader (saying get some cIOS action going and come back and see me). I started looking for a CIOS 249 v9+ (cause thats what USBloader asked for) wasn't having luck until i installed cIOS38 Rev 17 which you mentioned earlier. As soon as i installed that, Everything worked. Thanks again for all your help.
                        • Cbeast
                          • Aug 2012
                          • 27
                          #27
                          I might try to Mod another Wii from scratch to see if i can, Can you point me to a good guide?
                          • happy_highlander
                            • 3535
                            #28
                            Use modmii and run the full softmod wizard before you brick your wii. Installing wads all over the place as you have been instructed to do is going to end up in tears m8. The biggest problem you have is the same as a lot of people have been having lately, you have been using bits of different softmods and they are all missing one key ingredient and that is an ios 236 installer which is required to install the d2x cios correctly and usb loader gx which is the most compatible loader for games. Don't install an ios 236 was unless you know what ios it needs to be installed into.
                            • happy_highlander
                              • 3535
                              #29
                              Keith ios 236 Is an enhanced mod of ios 36 and can be installed into 36 if patched, hence the choice to install and patch ios 36 in mmm, but ios 236 can be installed using an installer without having to patch 36 and in turn isn't messing with original system ios to install custom ios into and allows an open door if ninty release another update that blocks ios 36 again so your softmod won't be lost.
                              • Cbeast
                                • Aug 2012
                                • 27
                                #30
                                Thanks HH. So you think i should use Modmi and run a full softmod, even tho its working now? I will if thats best, i would just hate to have it not working again after all that . Let me know. Also is it much of a process?
