homebrew bubbles
  • pudzy
    • 206
    homebrew bubbles
    hi lads just d/loaded homebrew to wii, but all i get is bubbles on screen,,, how come any help
  • Keithuk
    • 2264
    You will see the bubbles in Homebrew because you don't have any apps in the apps folder on the SD card.
    Just to prove it add sysCheck on the SD card so it will look like SD: apps\syscheck sub folder. Put is back in the Wii and run Homebrew you should only see sysCheck listed. While it shows sysCheck (NOT RUNNING) just unplug the SD card and it will disappear put it back in and it will show again.
    You could post a report from sysCheck.csv as instructed in that link so we can see that everything else is ok.
    Any app that you add to the SD card must be in the apps folder as a sub folder.
    Keith
    2010 Golf GTD (170)
    • pudzy
      • 206
      ok perfect that worked .. what apps can i or what ones do i need, thanks for reply
      • Keithuk
        • 2264
        So what was your reason for softmodding your Wii?
        The main reason you softmod a Wii is so you can play games of an external USB hard drive. There are 3 main USB Loaders (see my Sig) all these are apps that have their own sub folder in the apps folder. You can install a Forwarder so you run these USB Loaders from the Wii menu not run Homebrew and run them from there.
        Have you installed PriiLoader 0.7?
        There are games you can download that would go into the apps folder. Mahjongg Wii, Rokoban
        Post a sysCheck as instructed in that link so we can see whats in your Wii?
        Keith
        2010 Golf GTD (170)
        • pudzy
          • 206
          LOL, I CAN D/LOAD EM, AND SEE EM ON WII, BUT WONT INSTALL m8, opps sorry about caps
          • pudzy
            • 206
            i downloaded, priloader m8, but when i open it in homebrew it says no description available... ERROR
            • Keithuk
              • 2264
              What do you mean they won't install?
              If you open the Mahjongg_Wii_v0_8.zip you will see there are 3 main files already in a mahjongg folder (not the readme.txt) this mahjongg folder needs to be in the apps folder on the SD card then it will run from Homebrew.
              The Rockoban game isn't downloading at the moment so you can have my copy. Its already in a Rokoban folder so extract it the same way as Mahjongg.
              Keith
              2010 Golf GTD (170)
              • pudzy
                • 206
                Exceptoin (DSI) occurred. then lot of GPR01 NUMBERS, THEN stack dump, group dump... looks like errors.. thats after i click on you Rokoban icon on the wii
                • Keithuk
                  • 2264
                  Sorry I can't help you with those errors but you don't have the bubbles.
                  Keith
                  2010 Golf GTD (170)
                  • pudzy
                    • 206
                    i got the bubbles yes, after i click homebrew icon then start, i get bubbles... crackin m8...
                    • Keithuk
                      • 2264
                      Excuse me but have you been listening to what I've said?
                      You only see bubbles when you click on Homebrew if you don't have any apps in the apps folder on the SD card.
                      Keith
                      2010 Golf GTD (170)
                      • happy_highlander
                        • 3535
                        Good luck m8
                        • pudzy
                          • 206
                          this is system check results..
                          sysCheck v2.1.0b17 by Double_A and R2-D2199
                          ...runs on IOS58 (rev 6176).
                          Region: PAL
                          System Menu 4.3E (v514)
                          Priiloader installed
                          Drive date: 2006.05.26
                          Homebrew Channel 1.0.0 running on IOS58
                          Hollywood v0x11
                          Console ID: 69547270
                          Boot2 v4
                          Found 73 titles.
                          Found 46 IOS on this console. 15 of them are stub.
                          IOS4 (rev 65280): Stub
                          IOS9 (rev 1034): No Patches
                          IOS10 (rev 768): Stub
                          IOS11 (rev 256): Stub
                          IOS12 (rev 526): No Patches
                          IOS13 (rev 1032): No Patches
                          IOS14 (rev 1032): No Patches
                          IOS15 (rev 1032): No Patches
                          IOS16 (rev 512): Stub
                          IOS17 (rev 1032): No Patches
                          IOS20 (rev 256): Stub
                          IOS21 (rev 1039): No Patches
                          IOS22 (rev 1294): No Patches
                          IOS28 (rev 1807): No Patches
                          IOS30 (rev 2816): Stub
                          IOS31 (rev 3608): No Patches
                          IOS33 (rev 3608): No Patches
                          IOS34 (rev 3608): No Patches
                          IOS35 (rev 3608): No Patches
                          IOS36 (rev 3608, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
                          IOS37 (rev 5663): No Patches
                          IOS38 (rev 4124): No Patches
                          IOS40 (rev 3072): Stub
                          IOS41 (rev 3607): No Patches
                          IOS43 (rev 3607): No Patches
                          IOS45 (rev 3607): No Patches
                          IOS46 (rev 3607): No Patches
                          IOS48 (rev 4124): No Patches
                          IOS50 (rev 5120): Stub
                          IOS51 (rev 4864): Stub
                          IOS52 (rev 5888): Stub
                          IOS53 (rev 5663): No Patches
                          IOS55 (rev 5663): No Patches
                          IOS56 (rev 5662): No Patches
                          IOS57 (rev 5919): No Patches
                          IOS58 (rev 6176): USB 2.0
                          IOS60 (rev 6400): Stub
                          IOS61 (rev 5662): No Patches
                          IOS70 (rev 6912): Stub
                          IOS80 (rev 6944): No Patches
                          IOS222 (rev 65280): Stub
                          IOS223 (rev 65280): Stub
                          IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
                          IOS249 (rev 6): Trucha Bug, ES Identify, Flash Access, NAND Access
                          IOS250 (rev 65280): Stub
                          IOS254 (rev 65281): BootMii
                          BC v6
                          MIOS v10
                          Report generated on 2012/08/30.
                          • Keithuk
                            • 2264
                            Ok you need to download Full Cios wad pack extract them all to the SD card and install them all with MMM which is provided.
                            Then you need to find a suitable mains powered USD external hard drive.
                            USB Compatibility List
                            USB Devices Compatibility List - WikiTemp
                            There is a newer version of Homebrew Channel 1.1.0 out when you run Homebrew it may tell you this and allow you to upgrade but your Wii must have a web connection. Get the USB drive up and running first.
                            Keith
                            2010 Golf GTD (170)
                            • pudzy
                              • 206
                              perfect, progress at last,full-cios-wad-pack loaded and on to wii.. i got harddrive 300gb external .
