usb loader gx loaded and on screen on wii
homebrew bubbles
Post a new sysCheck to make sure everything is installed as it should be?Then you need to find a suitable mains powered USD external hard drive.
USB Compatibility List
USB Devices Compatibility List - WikiTemp
Is your drive compatiible, self powered USB drives aren't recommended even though they are cheap and powered from the USB port.
How have you formatted the drive and what games have you added to it and by which means?
An external drive will only work in the USB port nearest the bottom/edge it depends if its flat or vertical.Keith
2010 Golf GTD (170)Comment
. just did syscheck.
sysCheck v2.1.0b17 by Double_A and R2-D2199
...runs on IOS58 (rev 6176).
Region: PAL
System Menu 4.3E (v514)
Priiloader installed
Could not detect the drive date!
Homebrew Channel 1.0.0 running on IOS58
Hollywood v0x11
Console ID: 69547270
Boot2 v4
Found 83 titles.
Found 53 IOS on this console. 4 of them are stub.
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 16174): Trucha Bug, NAND Access
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1032): No Patches
IOS20 (rev 16174): Trucha Bug, NAND Access
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 16174): Trucha Bug, NAND Access
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 16174): Trucha Bug, NAND Access
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 16174): Trucha Bug, NAND Access
IOS51 (rev 4864): Stub
IOS52 (rev 16174): Trucha Bug, NAND Access
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 16174): Trucha Bug, NAND Access
IOS61 (rev 5662): No Patches
IOS70 (rev 16174): Trucha Bug, NAND Access
IOS80 (rev 16174): Trucha Bug, NAND Access
IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2012/08/31.
Report generated on 2012/08/31.Comment
i been trying to help pudzy privately...
all his games are iso's in individual folders on a ntfs drive..
is there any easy way he can sort it out?Comment
Yes mate use wiibackup manager to extract them all into pc as wbfs as they are smaller in that format then format hd to fat 32 and transfer them back. Only way to do it safely. Or partition the hdd and put first partition as fat 32 (hoping the games don't get split between partitions) then use wiibackup manager to to transfer iso's to fat 32 partition (if they are still there) they will be changed from iso to wbfs automatically. If you go for first option which I would recommend you will then be able to drag and drop the whole wbfs folder that will be created on pc.If that sounds to complicated just copy them to another drive on pc as the iso files they are then format wii drive to fat 32 and add the games using wiibackup manager.Comment
aye, that's the only way i could see to do it m8..
his wii drive is full so i don't know if he would have the room on another drive...
i have the same "backups " as him, easier to clone my drive..Comment
Don't forget if you pull them of the drive as wbfs files he will only need about half the space they are taking up nowComment
So will Wii Backup Manager extract and save files of a wbfs drive as a wbfs file?
I've tried converting iso to wbfs with Wii Game Converter GXS but the wbfs file isn't as small as the original wbfs.Keith
