USB Loader requires at least cIOS 222 or 245-250
  • din76
    • 6
    #46
    Originally posted by Keithuk
    Well your sysCheck is still the same as you posted in post #40 its a typical Wii thats only been softmodded with 17 stubs which you have to knock down to about 5.
    You need to download ModMii 2.3 and run it from Windows. Now you have the sysCheck.csv file from the sysCheck which will be on the root of the SD card you can choose the SU option from the main menu. Type in the location of sysCheck.csv.
    This will download all files into COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted. ModMii only adds 2 d2x v8.0 wads so install all 7 wads from d2x v8.0 final wad pack after you've added them to the wad folder on the SD card.
    Run IOS236 installer from Homebrew first to install IOS36 into IOS236, you must do this before you install any other wads. Come back out then run Multi-Mod Manager and select WAD Manager and install all wads in that folder. I've posted this method in many threads on here if you read them.
    You can run sysCheck again and post a new sysCheck report afterward installing all the wads.
    Happy New Year.
    Hi Keithuk,
    I have formatted my SD Card. While doing the syscheck again, you had mentioned to "copy the 3 files and put them inside the sdcard/apps folder". And since I have formatted my SD Card, it is empty now.
    May I have the steps to create the SD card contents.
    Once I created the SD card, I will do the sys check followed by ur steps in the latest post.
    Thank You Sir!
    • Keithuk
      • 2264
      #47
      I mentioned copying ALL files after running ModMii and the SU option in the COPY_TO_SD sub folder to the SD card. Also download and add all 7 wads from d2x v8.0 final wad pack to the wad folder on the SD card.
      You can post a new sysCheck report to make sure all the important wads have been installed.
      Then you just Google the USB Loader you want to use, I would recommend USB Loader GX USBLoader_GX_V3_0_AllinOnePackage_IOS249.zip and add it to the SD card. There is a Forwarder wad on there which needs to be installed with MMM so you have USB Loader GX channel.
      Keith
      2010 Golf GTD (170)
      • kamizolo
        • Jan 2013
        #48
        hey I'm trying to get my usb loader to work but have no idea what to do :/
        i at least did a syscheck so i hope somebody can help me out
        sysCheck v2.1.0b17 by Double_A and R2-D2199
        ...runs on IOS58 (rev 6176).
        Region: PAL
        System Menu 4.3E (v514)
        Drive date: 2009.11.21
        Homebrew Channel 1.0.0 running on IOS0
        Hollywood v0x21
        Console ID: 153695924
        Boot2 v4
        Found 69 titles.
        Found 46 IOS on this console. 17 of them are stub.
        IOS3 (rev 65280): Stub
        IOS4 (rev 65280): Stub
        IOS9 (rev 1034): No Patches
        IOS10 (rev 768): Stub
        IOS11 (rev 256): Stub
        IOS12 (rev 526): No Patches
        IOS13 (rev 1032): No Patches
        IOS14 (rev 1032): No Patches
        IOS15 (rev 1032): No Patches
        IOS16 (rev 512): Stub
        IOS17 (rev 1032): No Patches
        IOS20 (rev 256): Stub
        IOS21 (rev 1039): No Patches
        IOS22 (rev 1294): No Patches
        IOS28 (rev 1807): No Patches
        IOS30 (rev 2816): Stub
        IOS31 (rev 3608): No Patches
        IOS33 (rev 3608): No Patches
        IOS34 (rev 3608): No Patches
        IOS35 (rev 3608): No Patches
        IOS36 (rev 3608): No Patches
        IOS37 (rev 5663): No Patches
        IOS38 (rev 4124): No Patches
        IOS40 (rev 3072): Stub
        IOS41 (rev 3607): No Patches
        IOS43 (rev 3607): No Patches
        IOS45 (rev 3607): No Patches
        IOS46 (rev 3607): No Patches
        IOS48 (rev 4124): No Patches
        IOS50 (rev 5120): Stub
        IOS51 (rev 4864): Stub
        IOS52 (rev 5888): Stub
        IOS53 (rev 5663): No Patches
        IOS55 (rev 5663): No Patches
        IOS56 (rev 5662): No Patches
        IOS57 (rev 5919): No Patches
        IOS58 (rev 6176): USB 2.0
        IOS60 (rev 6400): Stub
        IOS61 (rev 5662): No Patches
        IOS70 (rev 6912): Stub
        IOS80 (rev 6944): No Patches
        IOS222 (rev 65280): Stub
        IOS223 (rev 65280): Stub
        IOS249 (rev 65280): Stub
        IOS250 (rev 65280): Stub
        IOS254 (rev 65281): BootMii
        BC v6
        MIOS v10
        Report generated on 2013/01/07.
        • Keithuk
          • 2264
          #49
          Welcome to DK.
          As I've said before thats a sysCheck of a Wii thats only been softmodded. As you see you have 17 stubbed IOS's which you have to reduce to about 5.
          There is a newer sysCheckb19 out now. Its strange Homebrew Channel 1.0.0 running on IOS0?
          You need to download ModMii 2.4 and run it from Windows. Now you have the sysCheck.csv file from the sysCheck which will be on the root of the SD card you can choose the SU option from the main menu. Type in the location of sysCheck.csv.
          Keith
          2010 Golf GTD (170)
          • kamizolo
            • Jan 2013
            #50
            thank you for for helping
            i think i did it all correctly so now it looks like this
            sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
            Region: PAL
            Homebrew Channel 1.1.2 running on IOS58
            HomebrewFilter ist nicht installiert
            Hollywood v0x21
            Boot2 v4
            Found 78 titles.
            Found 55 IOS on this console. 5 of them are stub.
            IOS11 (rev 16174): Trucha Bug, NAND Access
            IOS20 (rev 16174): Trucha Bug, NAND Access
            IOS30 (rev 16174): Trucha Bug, NAND Access
            IOS40 (rev 16174): Trucha Bug, NAND Access
            IOS50 (rev 16174): Trucha Bug, NAND Access
            IOS52 (rev 16174): Trucha Bug, NAND Access
            IOS60 (rev 16174): Trucha Bug, NAND Access
            IOS62 (rev 6430): No Patches
            IOS70 (rev 16174): Trucha Bug, NAND Access
            IOS80 (rev 16174): Trucha Bug, NAND Access
            IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
            IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
            IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
            IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
            IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
            IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
            IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
            IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
            IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
            IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
            IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
            IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
            BC v6
            MIOS v10
            Report generated on 2013/01/08.
            • Keithuk
              • 2264
              #51
              That looks ok now, can you see the differences between your first sysCheck and this one?
              So you need to find a suitable mains powered external USB hard drive thats compatible then load your games on to it.
              Oh I see you don't have PriiLoader 0.7 installed to block online and disc updates. Sorry I missed that before as I was more concerned about the IOS's.
              Keith
              2010 Golf GTD (170)
              • kamizolo
                • Jan 2013
                #52
                ok thanks you where a big help jupp a big difference :P
                i have that, managed to play a game just now
                ok i'll download that now.
                • WiiU
                  • Jan 2013
                  #53
                  Getting the feeling after reading this things have changed since sposa03 posted awhile ago.
                  My console has the November 2012 update that came with Wii U transfer menu app, this may have an affected on anything, I can't be sure?
                  The system software still reports 4.3E
                  Just found out my version is slightly new than some people may have 4.3E (v513) mine says it is 4.3E (v514)
                  Man things have changed when I lasted soft modded my Wii 3 years ago, can't even remember how I did it. This time I am trying to get rid of the menu at power up and just run HB channel without all the other crap.
                  Region: PAL (original region: AUS)
                  Drive date: 2008.12.18
                  Homebrew Channel 1.1.0 running on IOS58
                  Hollywood v0x21
                  Console ID: 140441442
                  Boot2 v4
                  Found 71 titles.
                  Found 47 IOS on this console. 17 of them are stub.
                  BC v6
                  MIOS v10
                  Report generated on 2013/01/24.
                  • Keithuk
                    • 2264
                    #54
                    Welcome to DK.
                    Are you sure it a Wii and not a Wii U as your name suggests, and what you use to softmod it?
                    If you read my replies in here you will see whats needed. If it is a Wii you need to:
                    Well your sysCheck is a typical Wii thats only been softmodded with 17 stubs which you have to knock down to about 5.
                    You will need PriiLoader 0.7 installing to block online and disc updates.
                    Keith
                    2010 Golf GTD (170)
                    • WiiU
                      • Jan 2013
                      #55
                      Hi thanks for the reply, WiiU is my latest console, I have moved all my WiiU games to the WiiU using the system transfer. Now it is time to mod the normal black Wii
                      I used the syscheck.csv file and modmii, it downloaded everything I needed, I forgot the move the files to the card afterwards but figured that out when it wouldn't work, thus moving the files.
                      After that I was able to add 236 and fix it. Install upgrade all the other ISO's. Appears that it add gx loader to the channels.
                      Everything work pretty well. It is a lot nicer not having any menu system during power up (with my old mod), just having the channels instead.
                      I don't have Priiloader yet, but might have to put that on there (I am already on the latest November 2012, wondering if Nintendo will bother with anymore updated as this stage)?
                      I am wondering if I should update my older Wii (white) console in the lounge area, as the mod is 3 years old, think some stuff will not run on it. I don't like the kids being able access the menu at power up in case they break something or brick it
                      Let me know if there is anything else you would recommend adding at this stage, I would appreciate it.
                      • Keithuk
                        • 2264
                        #56
                        Well to me your talking of a new system Wii U which I know nothing about as they are money wasted at ?250.
                        If your now talking about softmodding your black Wii and thats the syCheck from it then I've already told you what to do.
                        That sysCheck doesn't show PriiLoader installed fix it.
                        Then your talking about updating your older white Wii please don't confuse the issues you have. Run a syscheck of your older white Wii so we can see whats missing?
                        Keith
                        2010 Golf GTD (170)
                        • dergsatt
                          • Dec 2012
                          • 5
                          #57
                          i got in red cios 222 and 2223 missing when i tried to open uoader ,i deleted them from sd card then got them from another site i think i googled them .then put them on the root of the ds card and in the folder where i deleted them from , i then opened mmm .and installed the two file from there , think it was cios2222 install got loads of like dos writing then ok installed, somthing like that then the same for cios 2223 ,it was my first attempt at soft modding and didnt seem hard, when i tried opening u loader ,this time it opened my 16 gig usb stick and presto ,worked hope this might help . i didnt mind fidelling .your nearlly there , took me a few attempts . dont know is this is any use to you but worked for me, the 4.2 soft mod was from this site and workd brill great instructions , only prob was the 22223 2222, errors wich i cured , great instructions, from this site,
                          • dergsatt
                            • Dec 2012
                            • 5
                            #58
                            my wii was, white , v. 3.4u.. if that helps,,
                            • Keithuk
                              • 2264
                              #59
                              Welcome to DK.
                              You could have downloaded the Full cios wad pack from here.
                              Now if your Wii is up and running and loading games from your punny 16GB USB stick it would be nice to see a sysCheck19 as instructed in that link so I can see that you've installed all the necessary IOS's.
                              Keith
                              2010 Golf GTD (170)
                              • Booge134
                                • Feb 2013
                                I have the same problem
