USB Loader requires at least cIOS 222 or 245-250
  • kib0r
    • Sep 2013
    i'm getting the same error here , my syscheck is:
    sysCheck v2.1.0b17 by Double_A and R2-D2199
    ...runs on IOS58 (rev 6176).
    Region: NTSC-U
    System Menu 4.3U (v513)
    Drive date: 2008.12.18
    Homebrew Channel 1.0.0 running on IOS0
    Hollywood v0x21
    Console ID: 152451674
    Boot2 v4
    Found 154 titles.
    Found 49 IOS on this console. 17 of them are stub.
    IOS3 (rev 65280): Stub
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 2816): Stub
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 5120): Stub
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 6400): Stub
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 6912): Stub
    IOS80 (rev 6944): No Patches
    IOS202[57] (rev 65535, Info: hermes-v5.0): Trucha Bug, NAND Access, USB 2.0
    IOS222 (rev 65280): Stub
    IOS223 (rev 65280): Stub
    IOS236 (rev 54321): Trucha Bug, ES Identify, NAND Access
    IOS249 (rev 65280): Stub
    IOS250 (rev 65280): Stub
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2013/06/05.
    ur can help me?
    • Keithuk
      • 2264
      #77
      Welcome to DK.
      Thats a typical Wii thats only been softmodded with 17 IOS's that are Stub that you have to reduce to 4 or 5.
      I have posted this solution many times on here if you browse?
      Now you have sysCheck.csv on the root of the SD card from your sysCheck.
      Download ModMii6.2.7 and run it from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
      ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and install all 7 wads when you install the other wads.
      Put the SD card back in the Wii and run Homebrew. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
      Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
      Download PriiLoader 0.7 add it to the SD card and run it from Homewbrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
      If you have to update to 4.3 then the Shopping Channel may work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21 with Multi Mod Manager.
      Do another sysCheck to make sure everything installed correctly and post that.
      Keith
      2010 Golf GTD (170)
      • davidpatrick
        • Nov 2014
        Unable to download file..Will try in some time. I am noob here.
        Not sure i am doing right things here but i was able to load my Wii using USBLoader Gx earlier.. but now it says some like this
        "Go figure out using 222 v4 ...."
        I am going to try what says below but do let me know if i am doing something totally wrong.
        Thx in advance.
        Originally posted by sposa03
        Hi Maplelea
        I had the same problem but now I have sorted it.
        Follow these instructions and see if it works for you.
        Firstly goto Usbloader gx 2.3 r1128 and d2x v7 with mmm 13.4 - Downloads - Digital Kaos and download the file then follow these instructions.
        Extract the the wads and apps folders to a clean sd card.
        Make sure you have deleted all usbloader gx channels or forwarders from the wii . To do this you goto the wii options bottom left of the main page, select data management, then wii channels. Select any gx channels you have and delete.
        Put the SD card that you have just extracted the the two folders to in the wii, and goto homebrew channel.
        Select Multi Mod Manager and load it.
        Reload to IOS236 (reload to another ios is at the bottom of the list) click it and select 236.
        Navigate down to wad manager with wiimote (third one down) and press A on wiimote to select.
        Press 1 on wiimote to select all wads for batch install, then press A to install.
        That's it you are all done.
        You now have two options. You can use this sd card to load gx from or you can copy the usbloader gx folder to wherever you normally have your apps folder for your other loaders and apps.
        Enjoy this version of usbloader gx. The techy info for it is that this is USBLOADER GX 2.3 r1128 that runs on ios249 as default and has just been updated on 19-11-11 to run full nand emulation for game saves and channels.
        This worked perfect for me and no everythin is running fine.
        Hope this helps.
        • Keithuk
          • 2264
          #79
          You need Full Cios wad pack - Downloads - Digital Kaos plus read other posts I've made.
          Keith
          2010 Golf GTD (170)
          • yhtufzal
            • Dec 2014
            Hi friends,
            I am experiencing the same issue with IOS222, and don't know how to do a syscheck.
            i am a total beginner so sorry in advance for that.
            I hope someone can help please!!!
            • Keithuk
              • 2264
              #81
              Instructions are given in sysCheck19 report as instructed I that link.
              Keith
              2010 Golf GTD (170)
              • ANolasco
                • Jan 2018
                #82
                Hello, folks. Sorry for ressurrecting this post, but I am not able to make the USB loader to run, it is giving me the "USB Loader requires at least cIOS 222 or 245" error everytime I run it.
                BTW Im am trying to run WII game from an External HD.
                I`ve followed the #14 post guidelines but I am still not able make things to work.
                PS: I got a wierd Ticket 2011 error when installing the WADs, dont know why
                EDIT: Looks like the stubs that appered in my system check are there because the wads could not be installed. throwing a Ticket - 2011 error. How can I solve it?
                Here goes my syscheck:
                SysCheck HDE v2.4.0 HacksDen Edition por JoostinOnline, Double_A, R2-D2199, y Nano
                ...ejecutado en IOS58 (rev 6176).
                Region: NTSC-U
                Menu de Sistema 4.3U (v513)
                Priiloader instalado
                Fecha de la unidad: 14.07.2008
                Canal Homebrew 1.1.2 ejecutandose en IOS58
                Hollywood v0x11
                ID de consola: 70731267
                Tipo de consola: Wii
                Pais del Canal Tienda: Brazil (16)
                Boot2 v4
                67 titulos encontrados.
                Se encontraron 46 IOS en esta consola. 17 de ellos son stubs.
                IOS9 (rev 1034): Sin Parches
                IOS12 (rev 526): Sin Parches
                IOS13 (rev 1032): Sin Parches
                IOS14 (rev 1032): Sin Parches
                IOS15 (rev 1032): Sin Parches
                IOS17 (rev 1032): Sin Parches
                IOS21 (rev 1039): Sin Parches
                IOS22 (rev 1294): Sin Parches
                IOS28 (rev 1807): Sin Parches
                IOS31 (rev 3608): Sin Parches
                IOS33 (rev 3608): Sin Parches
                IOS34 (rev 3608): Sin Parches
                IOS35 (rev 3608): Sin Parches
                IOS36 (rev 3608): Sin Parches
                IOS37 (rev 5663): Sin Parches
                IOS38 (rev 4124): Sin Parches
                IOS41 (rev 3607): Sin Parches
                IOS43 (rev 3607): Sin Parches
                IOS45 (rev 3607): Sin Parches
                IOS46 (rev 3607): Sin Parches
                IOS48 (rev 4124): Sin Parches
                IOS53 (rev 5663): Sin Parches
                IOS55 (rev 5663): Sin Parches
                IOS56 (rev 5662): Sin Parches
                IOS57 (rev 5919): Sin Parches
                IOS61 (rev 5662): Sin Parches
                IOS62 (rev 6430): Sin Parches
                IOS80 (rev 6944): Sin Parches
                IOS254 (rev 65280): Stub
                BC v6
                MIOS v10
                Reporte generado el 07/01/2018.
                Thanks =)
                • ANolasco
                  • Jan 2018
                  #83
                  Region: NTSC-U
                  Hollywood v0x11
                  Boot2 v4
                  BC v6
                  MIOS v10
                  Thanks =)
                  Well, I managed to solve it!
                  Only the YAWMM managed to install the missing wads..
                  Thanks everyone!
