Wii USB HD Loader
  • DiddyDave
    • 213
    #16
    Originally posted by hornydevil
    Is there a maximum size HD the Wii can handle? Looking at getting this if it's any good....
    Buffalo Drivestation 500GB USB 2.0 External Hard Drive: Amazon.co.uk: Electronics & Photo
    Cheers
    Don't go above that as there is a limit of 500gb at the mome
    • thewebguy
      • Apr 2009
      #17
      If i play Raw smackdown 09 on Gamma loader it works fine same with MLB 2k9
      Now if I try and use them with the USB loader MLB2k9 when it gets to screen that says loading it just stays there loading..and Raw smak loads only in black and white...
      thoughts
      • DiddyDave
        • 213
        #18
        thoughts
        The USB HD Loader is still work in progress just bare with us..
        • DiddyDave
          • 213
          #19
          thoughts
          1 more thing are you using the v1 or v1.1..? of the USB HD Loader
          • thewebguy
            • Apr 2009
            #20
            any thoughts on why this would happen...the raw is a patch of some sort cause the game is PAL and I have ntsc system
            • DiddyDave
              • 213
              #21
              Are you using the USB Loader 1 or 1.1 ..?
              • thewebguy
                • Apr 2009
                #22
                1.1 i am using the raw is a PAL disk is there a USB NTSC force?
                • middlewingnut
                  • 55
                  #23
                  This works great! Zelda TP took 6 minutes to back up and then plays beautifully from teh USB hd. Thanks!
                  • johny48
                    • 50
                    #24
                    going to have a go at this just got 16gb pen drive
                    cheers and thanks for the info and hard work put into this
                    cheers johny48
                    • Shah200sx
                      • Mar 2009
                      • 9
                      #25
                      is it possible to use 4gb flash drive for HD loader (will a game fit on 4gb)
                      Cheers.
                      • DiddyDave
                        • 213
                        #26
                        Cheers.
                        It depends on the game I have managed to get 3 crappy games on to a 2 gb stick. Most games dont execeed the 3.5gb mark as the disk is split in to 3 parts 1 the game 2 the updates if any and then the dummy file to make it up to the 4.3gb point.
                        • Shah200sx
                          • Mar 2009
                          • 9
                          #27
                          i downloaded the hd loader and file is PHP how do i extract it.
                          • hornydevil
                            • 30
                            #28
                            I am trying to burn the saved games onto disc but everytime I plug the HDD into my laptop I am getting 'You need to format the disc in drive F: before you can use it'
                            Obviously I don't want to do that cos it'll delete all the games!
                            Any ideas on sorting it? I am using Vista by the way....
                            Cheers
                            • hornydevil
                              • 30
                              #29
                              Oops - sorted it!
                              Needed to us WBFS Manager to extract the iso!
                              • Yumraaj
                                • 306
                                #30
                                There's another version of usb loader that will force the game to start in full colour regarding of what region your wii is set on. It's called Ultimate Usb loader and it is very easy to configure and modifies. If you set the app on to patch mode, it will either force NTSC into Pal or vice versa. It also has ocarina function too!!!
                                So if you wana try it just click on this link and see for yourself.
                                The goal of this project is to make a stable USB-Loader, based on the official one from Waninkoko, with many Features like Cheating, Language Selecting, and much more... . It's Open-Source, so everybody can try to contribute something. The Thanks goes to waninkoko, kwiirk, Hungyip84, fishears...
                                Hope this help you.
