thanks for the links!
Wii v4.3u (cIOS 58) - usb loader gx requires at least cios 222 or 245-250
Welcome to DK guys.
The main thing you need to download is sysCheck19 as instructed in that link that will tell me more thats what is missing rather than guessing.Keith
2010 Golf GTD (170)Comment
so by downloading one the cios in this pack, i should be set?Comment
Welcome to DK.
reddevil157 didn't post that in this thread.so by downloading one the cios in this pack, i should be set?
Maybe but we need to see a sysCheck report to be sure.
The main thing you need to download is sysCheck19 and post report as instructed in that link that will tell me more thats what is missing rather than guessing.Keith
sysCheck v2.1.0b19 by Double_A and R2-D2199, NanoWelcome to DK.
...runs on IOS58 (rev 6176).
Region: NTSC-U
System Menu 4.3U (v513)
Drive date: 2006.09.07
Homebrew Channel 1.1.0 running on IOS58
HomebrewFilter ist nicht installiert
Hollywood v0x11
Console ID: 44444481
Boot2 v4
Found 77 titles.
Found 45 IOS on this console. 16 of them are stub.
IOS4 (rev 65280): Stub
IOS9 (rev 1034): No Patches
IOS10 (rev 768): Stub
IOS11 (rev 256): Stub
IOS12 (rev 526): No Patches
IOS13 (rev 1032): No Patches
IOS14 (rev 1032): No Patches
IOS15 (rev 1032): No Patches
IOS16 (rev 512): Stub
IOS17 (rev 1032): No Patches
IOS20 (rev 256): Stub
IOS21 (rev 1039): No Patches
IOS22 (rev 1294): No Patches
IOS28 (rev 1807): No Patches
IOS30 (rev 2816): Stub
IOS31 (rev 3608): No Patches
IOS33 (rev 3608): No Patches
IOS34 (rev 3608): No Patches
IOS35 (rev 3608): No Patches
IOS36 (rev 3608): No Patches
IOS37 (rev 5663): No Patches
IOS38 (rev 4124): No Patches
IOS40 (rev 3072): Stub
IOS41 (rev 3607): No Patches
IOS43 (rev 3607): No Patches
IOS45 (rev 3607): No Patches
IOS46 (rev 3607): No Patches
IOS48 (rev 4124): No Patches
IOS50 (rev 5120): Stub
IOS51 (rev 4864): Stub
IOS52 (rev 5888): Stub
IOS53 (rev 5663): No Patches
IOS55 (rev 5663): No Patches
IOS56 (rev 5662): No Patches
IOS57 (rev 5919): No Patches
IOS58 (rev 6176): USB 2.0
IOS60 (rev 6400): Stub
IOS61 (rev 5662): No Patches
IOS70 (rev 6912): Stub
IOS80 (rev 6944): No Patches
IOS222 (rev 65280): Stub
IOS223 (rev 65280): Stub
IOS249 (rev 65280): Stub
IOS250 (rev 65280): Stub
IOS254 (rev 65281): BootMii
BC v6
MIOS v10
Report generated on 2013/02/25.
sysCheck #sRLb4TgEComment
Well your sysCheck is a typical Wii thats only been softmodded with 16 stubs which you have to knock down to about 5.
You need to download ModMii6.2.6 and run it from Windows. Now you have the sysCheck.csv file from the sysCheck which will be on the root of the SD card you can choose the SU option from the main menu. Type in the location of sysCheck.csv.
This will download all files into COPY_TO_SD sub folder. Add all files and folders to your SD card and run Homebrew with the SD card inserted. ModMii only adds 2 d2x v8.0 wads so install all 7 wads from d2x v8.0 final wad pack after you've added them to the wad folder on the SD card.
Run IOS236 installer from Homebrew first to install IOS36 into IOS236, you must do this before you install any other wads. Come back out then run Multi-Mod Manager and select WAD Manager and install all wads in that folder. I've posted this method in many threads on here if you read them.
You can run sysCheck again and post a new sysCheck report afterward installing all the wads.
You will need PriiLoader 0.7 installing to block online and disc updates.
If the sysCheck is ok then you need to decided which USB Loader your going to use. The best one in my opinion is USB Loader GX. So download USBLoader_GX_V3_0_AllinOnePackage_IOS249.zip and add all files and folders to the SD card. You may as well download the Forwarder to you have the USB Loader GX channel on the Wii menu. USB Loader GX-UNEO_Forwarder_5_1_AHBPROT.wad add that wad to the wad folder on the SD card and install it with MMM.
The only thing left is to find a suitable mains powered USB hard drive to add the games onto. There are various ways to do this just ask?Keith
I'm in the same boat.
Here's my syscheck.
Region: NTSC-U
Drive date: 2007.02.13
Hollywood v0x11
Console ID: 76377088
Boot2 v4
Found 100 titles.
Found 48 IOS on this console. 16 of them are stub.
IOS62 (rev 6430): No Patches
IOS202 (rev 3092): Trucha Bug, USB 2.0
IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
BC v6
MIOS v10Comment
Welcome to DK.
As I've said before thats a sysCheck of a Wii thats only been softmodded. As you see you have 16 stubbed IOS's which you have to reduce to about 5.
You also need to install PriiLoader 0.7 installed to block online and disc updates.Keith
First off, thank you Keith.
Ok, so I went through the whole process as you said, and now USB Loader isn't saying anything about missing IOS, but I can't get it to recognize my drive, which is formatted with 2 partitions, 1 fat32 and the other WBFS. I have about 10 games properly loaded on the WBFS partition, and I've tried changing the loader settings to make it work, still with no luck. I also tried cfg loader, with the same results.
Here's my current sysCheck:
Region: NTSC-U
Priiloader installed
Hollywood v0x11
Boot2 v4
Found 107 titles.
Found 54 IOS on this console. 4 of them are stub.
IOS11 (rev 16174): Trucha Bug, NAND Access
IOS20 (rev 16174): Trucha Bug, NAND Access
IOS30 (rev 16174): Trucha Bug, NAND Access
IOS36 (rev 65535): Trucha Bug, ES Identify, NAND Access
IOS40 (rev 16174): Trucha Bug, NAND Access
IOS50 (rev 16174): Trucha Bug, NAND Access
IOS52 (rev 16174): Trucha Bug, NAND Access
IOS60 (rev 16174): Trucha Bug, NAND Access
IOS70 (rev 16174): Trucha Bug, NAND Access
IOS80 (rev 16174): Trucha Bug, NAND Access
IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
BC v6
MIOS v10Comment
The USB Loaders won't say there are missing IOS's because IOS222, IOS249 and IOS250 are there. I don't see anything else missing from that sysCheck.First off, thank you Keith.
In the USB Loader GX settings you select which drive format your using so I don't know why the drive has 2 partitions FAT32 and WBFS? I would have thought it would only read the format selected.
You are using the USB port nearest the edge?
If your using the latest USB Loaders you can format the drive NTFS. Make an wbfs folder on it and add a game or two with the filename must be the Wii game ID number and try that.Keith
