4.3E Helllllppp
  • Frogger
    • Oct 2012
    • 422
    #16
    Sys check
    Heres the output file for the system check which was named META in the SD_CARD>apps>syscheck folder. Ive been offline and online due to router probs.
    • Frogger
      • Oct 2012
      • 422
      #17
      @Keithuk......
      Im now playing FIFA13 on the WII which I just downloaded of tinternet.
      So I guess the Wii is now working, unless there are some games that work and some that dont etc.
      Many Many Thanks for your patience fella. Fair play to you for the help and directions.
      Remember, if theres anytime your stuck with cable or sat or anything else, I owe you one. Gentleman. Much Appreciated!!!
      Regards
      Frogger
      • Keithuk
        • Aug 2010
        • 2264
        #18
        You need to post the sysCheck report as instructed in that link not the txt file that comes with the app.
        Keith
        2010 Golf GTD (170)
        • Frogger
          • Oct 2012
          • 422
          #19
          Please enlighten me as I have run syscheck a few times and it says press A to upload report, which I have done. Do I run it on Wii or on PC?
          What exactly do you mean?
          (Remember I am new to this, so I know you may be frustrated)
          • Keithuk
            • Aug 2010
            • 2264
            #20
            You may have run the sysCheck a few times but you've never posted a full report.
            When you run sysCheck in Homebrew you press 'A' to scan IOS's. After you press 'A' again to see the results. If your Wii is web connected it will say upload your Wii's details to a site. If you press 'A' again you will see the report. I added IOS16 a couple of weeks ago and it posted this report to.
            sysCheck #IYKmJfDM
            You can open that web link and right-click it and use Select All then right-click on the highlighted text and select Copy then Paste it into a reply.
            Or you can open sysCheck.csv file of the root of the SD card with WordPad and copy and paste the contents into a thread.
            Keith
            2010 Golf GTD (170)
            • Frogger
              • Oct 2012
              • 422
              #21
              sysCheck #IYKmJfDM
              I didnt have the Wii connected to the net at any stage of softmod so I now know what you mean.
              Will do that shortly Keith.
              Keith for mod on here me thinks!!!!
              • Keithuk
                • Aug 2010
                • 2264
                #22
                You don't need to have the Wii web connected to softmod unless your using LetterBomb which needs to send the red envelope message.
                When you run sysCheck sometimes it doesn't say uploading results but if it shows the web link at the bottom of the sysCheck results then it did do.
                Thanks for suggesting I should be a mod on here but moderating properly takes up alot of time. I'm already a mod on 4 forums and an admin on another.
                Keith
                2010 Golf GTD (170)
                • Frogger
                  • Oct 2012
                  • 422
                  #23
                  I can tell your hands are full and your a great helper with patience. Hard to get nowadays.
                  My mod appraisal shout was a message of support and gratitude @ you, but it would be more than appropriate if you could make it.
                  PS I took a pic of every step I did when modding the Wii if you ever need em. Errors n all.
