USB Loaders do not detect my USB Flashdrive.
  • Gaengphed
    • Sep 2014
    • 13
    #16
    Hi there,
    I know I'm a bit late with modding my Wii. But it seems now is the time to do so ;-)
    I've tried like other people to make USB loaders accept/find my USB drive but they won't find it. It keeps coming up with a message that it at least requires cIOS 222 or 245-250.
    I just did the Sys Check. I'm posting the results here, hoping someone can help me figuring this one out.
    Thanks beforehand.
    Gaengphed.
    sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Drive date: 2007.02.13
    Homebrew Channel 1.1.2 running on IOS58
    HomebrewFilter ist nicht installiert
    Hollywood v0x11
    Console ID: 109041811
    Boot2 v4
    Found 85 titles.
    Found 45 IOS on this console. 16 of them are stub.
    IOS4 (rev 65280): Stub
    IOS9 (rev 1034): No Patches
    IOS10 (rev 768): Stub
    IOS11 (rev 256): Stub
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS16 (rev 512): Stub
    IOS17 (rev 1032): No Patches
    IOS20 (rev 256): Stub
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 2816): Stub
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 3072): Stub
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 5120): Stub
    IOS51 (rev 4864): Stub
    IOS52 (rev 5888): Stub
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 6400): Stub
    IOS61 (rev 5662): No Patches
    IOS70 (rev 6912): Stub
    IOS80 (rev 6944): No Patches
    IOS222 (rev 65280): Stub
    IOS223 (rev 65280): Stub
    IOS249 (rev 65280): Stub
    IOS250 (rev 65280): Stub
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 2014/09/22.
    • Keithuk
      • 2264
      #17
      As you may have read on here that's a typical sysCheck of a Wii that's only been softmodded as you have 16 IOS's that are Stub. You need to reduce that 16 down to 4 or 5.
      Download ModMii6.3.1 and run ModMii.exe from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
      ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and put these in the wad folder on the SD card, install all 7 wads when you install the other wads.
      Put the SD card back in the Wii and run Homebrew. Run IOS236 Installer v5 Mod first before you install any other wads. Multi Mod Manager (MMM) should be the first app listed select it and load it. Once running scroll down to WAD Manager and press 'A' that will default to all wads in the wad folder. If you want to install all wads shown just press 1 that will list all wads you want to install press 'A' again to install them all.
      Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
      Download PriiLoader 0.7 add it to the SD card and run it from Homebrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
      If you have to update to 4.3 then the Shopping Channel may not work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21
      Do another sysCheck to make sure everything installed correctly and post that.
      Then you just have a to find a compatible mains powered USB hard drive to add your games onto and download USB Loader GX 3.0 to run them.
      Keith
      2010 Golf GTD (170)
      • Gaengphed
        • Sep 2014
        • 13
        #18
        Hi Keith,
        Thanks for your reply. Going to try things out tonight and keep you posted if it worked out.
        Best,
        Gaengphed.
        • Gaengphed
          • Sep 2014
          • 13
          #19
          Hi Keith,
          Just arrived back home ;-)
          Can you tell me if I need to remove 'stubs' first manually:
          "...as you have 16 IOS's that are Stub. You need to reduce that 16 down to 4 or 5."
          or is that done by using the modMii631-file?
          I've run the ModMii631 and all downloads have been done. Extracted d2x v8 Final wad pack to the sd card\wad .
          Placed the sd card in the wii, but I don't see IOS236 Installer v5 Mod when opening HBC.
          Let me know how to proceed. Thanks again!
          Gaengphed.
          • Keithuk
            • 2264
            #20
            No you don't remove Stubs you install the wads for the IOS's that are Stub, you need to reduce those 16 Stubs down to 4 or 5.
            If you have used ModMii that should have given you IOS236 Installer v5 Mod which is in the apps folder on the SD card. If you don't have it download COPY_TO_SD and copy all files and folders to the SD card, that's what ModMii should have given you.
            As I've said you also need to download and install PriiLoader 0.7 add it to the SD card and run it from Homebrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
            Keith
            2010 Golf GTD (170)
            • Gaengphed
              • Sep 2014
              • 13
              #21
              Thanks for bearing with a nono like me ;-)
              Going to try this out. This version of Copy-To-SD does have the IOS236 installer!
              Keep you posted!
              Gaengphed.
              • Gaengphed
                • Sep 2014
                • 13
                #22
                Just tried the IOS236 Installer v5 and it comes up with an error:
                About to install IOS236
                Getting IOS36 revision 3351...
                Could not open file: sd:/IOS36-64-v3351.wad
                Could not open file: sd:/IOS36-64-v3351.wad.out.wad
                Error reading IOS into memory
                IOS236 Install failed. Press any button to exit...
                Bad SD-card naybe?
                • Keithuk
                  • 2264
                  #23
                  IOS36-64-v3351.wad produced by ModMii is the only wad that goes root on the SD card. Even though its named IOS36 its used to install IOS236.
                  Do a full format of the SD card to FAT32 that will check for any bad sectors. Then add all files and folders from my
                  He is my sysCheck yours should look the same. sysCheck #MKWDueNa
                  If you want to remove IOS16 Stub add cIOS16-v257 this wad to the wad folder and install it with Multi Mod Manager (MMM) it won't help your Wii only install this wad to remove the Stub.
                  Then post a new sysCheck.
                  Keith
                  2010 Golf GTD (170)
                  • Gaengphed
                    • Sep 2014
                    • 13
                    #24
                    Hi Keith,
                    Well I did manage to get the IOS36-64-v3351.wad installed after formatting the SD-card.
                    Then I tried to remove the IOS16 stub by adding the cIOS16-v257 through MMM but after I select the wad-file and press A to install it says the following:
                    * Installing 1/1: cIOS16-v257.wad - Title (-2011)
                    [#] Final Status - 1 did not complete.
                    Press any...
                    Then I tried to install all wads in a batch, but only 1 of 30 gets an OK! message. Too bad that one just goes out of vision, it's no 20/30 and it has the name: IOS62-64-v6430.wad
                    I also tried to remove stubbed IOSs by MMM, when selecting 1 it says it can't remove them. Hmmm.
                    Now IOS236 is installed I can load it with the last option of the menu: Load another IOS. Current now is IOS58. After loading 236 I can remove the stubbed IOSs. Didn't expect this, but the're gone now (used option1 : IOS222, 223, 249, 250)
                    New SysCheck:
                    Region: PAL
                    Priiloader installed
                    Hollywood v0x11
                    Boot2 v4
                    Found 84 titles.
                    Found 43 IOS on this console. 12 of them are stub.
                    IOS62 (rev 6430): No Patches
                    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
                    BC v6
                    MIOS v10
                    Report generated on 2014/09/24.
                    Hope to hear from you soon again.
                    Best,
                    Gaengphed
                    • Keithuk
                      • 2264
                      #25
                      Never uninstall an IOS unless you know what your doing as it could brick your Wii.
                      Ok I see IOS236 is installed but you still have 12 IOS's that are Stub. You need install IOS11, IOS20, IOS30, IOS40, IOS50, IOS52, IOS220, IOS223, IOS224 to install them from my COPY_TO_SD.rar. Plus you need to add all 7 wads from d2x v8 Final wad pack and put these in the wad folder on the SD card and install all 7 of them.
                      Pressing 'A' in Multi Mod Manager (MMM) installs all wads in the wad folder you can select individual wads but scrolling down with the big + button and press the + button that will put a green tick next to that IOS. If you make a mistake you can press the - button and that will remove the green tick. Scroll down and put a tick next to all IOS's I listed above then press 'A' to see that wads name listed in the next window then press 'A' to install then all, watch the OK message after each one is installed.
                      I see you've installed PriiLoader, have you blocked disc and online updates?
                      Keith
                      2010 Golf GTD (170)
                      • Gaengphed
                        • Sep 2014
                        • 13
                        #26
                        Hi Keith,
                        Will try that tonight again. But for IOS236 I had to use the IOS236 Installer v5 and place the wad-file on the root of the SD-card. Is there a separate installer for these IOSs and do I need to place the wad-files on the root of the SD-card?
                        If I need to place all wad-files in the wad-folder and use batch install/one-by-one installation (using -/+), tried that before but didn't work out. Okay...that was before formatting the SD-card. So maybe this time it works, but not sure.
                        Thanks again.
                        Gaengphed.
                        • Keithuk
                          • 2264
                          #27
                          I assure you batch install/one-by-one installation (using -/+) does work try it again.
                          If you have just softmodded this Wii did you do a NAND backup straight afterwards? That puts keys.bin, nand.bin and the bootmii folder in the SD car with armboot.bin, bootmii.ini, ppcboot.elf in there.
                          Keith
                          2010 Golf GTD (170)
                          • Gaengphed
                            • Sep 2014
                            • 13
                            #28
                            Uhhhh? NAND backup? :-/ Is that on the Windows Home, Options, Memory etc and seeing the green blocks appear? That I did do according to the instructions in the package yes. Need to do something with those files? I moved the contents of the SD Card to my laptop before formatting. It's possible that they're still there.
                            Ok, so regardless if batch install says fails and separate installs fails just keep trying for a few times then. Didn't do this.
                            • Gaengphed
                              • Sep 2014
                              • 13
                              #29
                              Hi Keith,
                              I indeed have the armboot.bin, bootmii.ini, ppcboot.elf on a back-up of the SD card. Going to try to install the wad-files again...
                              • Gaengphed
                                • Sep 2014
                                • 13
                                #30
                                I've tried to install the wads again, but only one gets installed: IOS62-64-v6430.wad. I've repeatedly tried the first 14/15 wads separately, each 3 or 4 times but no success. Then did the batch and only one gets installed.
