Wii softmod for Dummies(without zelda)
This topic is closed.
  • akyboo
    • 83
    this soft mod uses the bannerbomb crack read the pdf file and follow the instructions and all should be fine. I have not tested this on version 4 but feedback would be welcome. Print out the pdf. file before you do anything read it twice and follow the instructions precisely step by step.
    For those downloading the games use the Patcher to convert all the games burn at slow speed( i burn at 4x using nero) use verbatim - (not +)discs. This is for versions 3 wii's.Please do not use this thread for first post, the thread is to help those that need help and advice.
    New members please read here first http://www.digital-kaos.co.uk/forums...-posting-1129/
    Please go HERE for the same file sorry for the inconvenience
  • Smokey85
    • Jun 2009
    Has anyone tried this with version 4
    • partyzone
      • 160
      hi thx
      but when i get to wad batch installer says cios249 not found press a
      i press a and get error (ret = -1035)
      help thx
      daz
      tried and tried but cant run
      any 1 got step by step with files?
      thx
      • alexh
        • 225
        You haven't needed Zelda for a "long" time.
        Bannerbomb is now the new tried and trusted technique.
        Get the details on how to use it straight from the horses mouth:
        Bannerbomb - WiiBrew
        • alexh
          • 225
          The guide doesn't discuss the most important discover for the Wii so far : USB Loader..
          Connecting a USB hard drive and playing all games from there. No more burning discs. No more swapping discs.
          It turns the Wii into the most amazing hacked console since XBOX1
          • partyzone
            • 160
            works fine, can i just attach hd to wii now i have banner bomb installed? or need other software? thx
            • akyboo
              • 83
              Originally posted by partyzone
              hi thx
              help thx
              daz
              thx
              Re format your card and try again new cards should be formatted just to be sure as well
              • KrakaJap
                • Jun 2009
                Is there any way to revert back after this softmod?
                • akyboo
                  • 83
                  connect your hard drive to your wii use the iso dumper to load your games on the hard drive and no more scratched discs
                  • akyboo
                    • 83
                    just go to data management and delete the channels
                    • funkyduck79
                      • Jun 2009
                      Going try this tonight, will let you guys know what happens... Hope it doesn't brick.
                      • karlosfandango
                        • Jun 2009
                        • 9
                        What size SD card are you useing. Only a 2gb is recommended
                        • ceryus
                          • Jun 2009
                          thanks a lot akyboo! im just preppin to buy a wii and i wanted to see if i could unlock my wii to play backups etc instead of actually using a modchip since i dont want to mess with the hardware side..thanks again!
                          Even a broken clock is right twice a day!
                          • kr1664uk
                            • Jun 2009
                            will this work on version 2.3 or shall i update the wii
                            • kr1664uk
                              • Jun 2009
                              will this work with version 4.0.i was on 2.3 but someone updated it earlier .but i cant get past the first bit where it kicks in the boot. bit it looks for 2 files and then says i have to restart even tho it not found what it want s and then its not working.thanks
