Wii Softmod not working
  • lee2014
    • Mar 2014
    • 12
    #16
    SOLVED:
    Keithuk, you are a GENIUS!!!!!! Thank you IT work, sigh of re-leaf.
    Much of it was me as my brain was in study mode 99% of the time as I'm training to be a doctor {don't laugh} (3yrs left).
    Your instructions came clear when I got my head in gear.
    So thank you keithuk you saved a Wii from the scrap yard .
    Now have loads of playing time to catch up on.
    All is running ok.
    Let me know if it looks ok plz.
    Latest syscheck:
    SysCheck v2.2.0 HD Edition by Double_A and R2-D2199, JoostinOnline, Nano
    ...runs on IOS58 (rev 6176).
    Region: PAL
    System Menu 4.3E (v514)
    Priiloader installed
    Drive date: 12.18.2008
    Homebrew Channel 1.1.2 running on IOS58
    Hollywood v0x21
    Console ID: 149229430
    Console Type: Wii
    Shop Channel Country: United Kingdom (110)
    Boot2 v4
    Found 88 titles.
    Found 50 IOS on this console. 0 of them are stub.
    IOS9 (rev 1034): No Patches
    IOS11 (rev 16174): Trucha Bug, NAND Access
    IOS12 (rev 526): No Patches
    IOS13 (rev 1032): No Patches
    IOS14 (rev 1032): No Patches
    IOS15 (rev 1032): No Patches
    IOS17 (rev 1032): No Patches
    IOS20 (rev 16174): Trucha Bug, NAND Access
    IOS21 (rev 1039): No Patches
    IOS22 (rev 1294): No Patches
    IOS28 (rev 1807): No Patches
    IOS30 (rev 16174): Trucha Bug, NAND Access
    IOS31 (rev 3608): No Patches
    IOS33 (rev 3608): No Patches
    IOS34 (rev 3608): No Patches
    IOS35 (rev 3608): No Patches
    IOS36 (rev 3608): No Patches
    IOS37 (rev 5663): No Patches
    IOS38 (rev 4124): No Patches
    IOS40 (rev 16174): Trucha Bug, NAND Access
    IOS41 (rev 3607): No Patches
    IOS43 (rev 3607): No Patches
    IOS45 (rev 3607): No Patches
    IOS46 (rev 3607): No Patches
    IOS48 (rev 4124): No Patches
    IOS50 (rev 16174): Trucha Bug, NAND Access
    IOS52 (rev 16174): Trucha Bug, NAND Access
    IOS53 (rev 5663): No Patches
    IOS55 (rev 5663): No Patches
    IOS56 (rev 5662): No Patches
    IOS57 (rev 5919): No Patches
    IOS58 (rev 6176): USB 2.0
    IOS60 (rev 16174): Trucha Bug, NAND Access
    IOS61 (rev 5662): No Patches
    IOS62 (rev 6430): No Patches
    IOS70 (rev 16174): Trucha Bug, NAND Access
    IOS80 (rev 16174): Trucha Bug, NAND Access
    IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
    IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
    IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
    IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
    IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
    IOS254 (rev 65281): BootMii
    BC v6
    MIOS v10
    Report generated on 03/06/2014.
    Kindest Regards Lee
    • lee2014
      • Mar 2014
      • 12
      #17
      SOLVED:
      Hi there Keithuk, Well its done thanks for the advice and direction and don't forget Patience It all now works as it should and I'm happy now.
      Most of it was me missing things out and being so tired (I'm training to be a doctor in my 3rd term) "don't laugh"
      Updated and un edited syscheck:
      Region: PAL
      Hollywood v0x21
      Console Type: Wii
      Boot2 v4
      Found 88 titles.
      BC v6
      MIOS v10
      If there's anything else that needs Adding/Removing then let me know.
      Many thank you's Keithuk you saved a Wii from going to the scrap heap, you are a saint.
      Kindest Regards
      Lee
      • Keithuk
        • Aug 2010
        • 2264
        #18
        Now your in gear that sysCheck looks ok.
        Its strange you don't have an IOS16 when all other Wii's have seen does.
        Your Drive date: 12.18.2008
        My Drive date: 12.18.2088
        You don't have an IOS3, IOS4, IOS10, IOS51 I do and they are all Stub, that's why you have no Stubs.
        If my help was useful please click the Thanks button on the left on my post that was useful not the Like button as Likes aren't registered? I used t have 450+ Thanks but this new forum put it back to 0.
        All you need to do now is find a compatible mains powered USB hard drive to add your games onto and download USB Loader GX 3.0 to run them.
        Oh does your Shopping Channel still work, it not install my RVL-Shopping-21.wad in post #7.
        Keith
        2010 Golf GTD (170)
        • lee2014
          • Mar 2014
          • 12
          #19
          Hi there Keithuk, Glad to get it sorted a last .
          The shopping channel works fine loads up and can make purchases as normal.
          With IOS3, IOS4, IOS10, IOS51 not installed will that cause any problems?, I'm happy on not doing anything else apart from adding USB harddrive.
          Regards Lee
          • Keithuk
            • Aug 2010
            • 2264
            #20
            You should be ok with those IOS3, IOS4, IOS10, IOS51 aren't really used now. If you run Multi Mod Manager (MMM) and click on IOS Manager you will see all the IOS numbers listed and if you over each one it tells what they are used for.
            IOS3 - Stub no other version found
            IOS4 - Stub since v3.4
            IOS10 - Mothballed
            IOS11 - Mothballed, only used by 2.0 & 2.1
            IOS51 - Mothballed, used by Shopping Channel 3.4 only
            Keith
            2010 Golf GTD (170)
