Coverfloader Latest Version.....
  • ck-ok
    • 2592
    #31
    Originally posted by iverson03_b21
    any updates needed? on 3.4
    update what for?
    • wii-mom
      • Feb 2010
      need help
      I am new to this. Got my kids wii modded and we get this error. Any help with getting covers and fixing this error is greatly appreciated. I don't know how to do it.
      • ck-ok
        • 2592
        #33
        help with covers http://www.digital-kaos.co.uk/forums...floader-93274/ and you dont say what the error is?
        • m9g
          • 704
          #34
          Does this work on 4.2e? also I have uloader channel, will this run with that and does it put a channel on wii menu or does it need to be accessed through HBC?
          Cheers
          M9G
          DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
          • ck-ok
            • 2592
            #35
            Cheers
            M9G
            yes to 4.2e
            you can run uloader and coverfloader
            yes to menu
            • m9g
              • 704
              #36
              Originally posted by ck-ok
              yes to 4.2e
              yes to menu
              Thanks, got it to run but had to access it through HBC - was hoping for the kids that it might put a channel on.
              Also went into settings to download covers, which it did but none of the games have the pictures on just big question mark, any ideas please?
              Also the WAD files do i need to run them in WADmanager? if so what ios do i choose?
              Many thanks
              M9G
              • m9g
                • 704
                #37
                Ah right, got coverfloader channel now, ran wadmanager and chose the coverfloader channel and ios 36 and intalled fine, when i chose coverfloader forwarder i got error 1022, dont know if this matters as coverfloader worked of clicking the channel.
                Its just the pictures now?
                Cheers
                M9G
                • ck-ok
                  • 2592
                  #38
                  Cheers
                  M9G
                  for your covers http://www.digital-kaos.co.uk/forums...floader-93274/
                  and your wad,you should of choose ios 249,you can always uninstall it and start again
                  • m9g
                    • 704
                    #39
                    Hi thanks
                    So should I install both the channel wad and the forwarder wad with ios 249 or channel with 36 and forwarder with 249?
                    Do i create a folder called 3d in the root of the sd card?
                    On the site to get covers, i clicked on search and what the fffff is all that? id number? and all those other box's?
                    Cheers
                    • ck-ok
                      • 2592
                      #40
                      Hi thanks
                      Cheers
                      both needed to be ios 249,but if you have installed the full channel you dont need the forwarder or the coverfloader folder on the sd card
                      there will already be a folder called 3d in usb folder on sd card
                      when you go for your covers click search then title en
                      type game you wont
                      when its found on the righthand side there will be artwork text
                      under that is ccffdd you want f for full cover
                      • m9g
                        • 704
                        #41
                        Got it sorted and working, got all the 3d pictures, from various sites, had to change id on a few of them and had to edit some HQ ones to correct size but got there and looking good.
                        Cheers
                        • m9g
                          • 704
                          #42
                          Oh!!!!
                          All was lovely last night, coverfloader working perfectly, turned it on just now and now i get this error 002 thing.
                          Any ideas how to sort please?
                          Regards
                          M9G
                          • m9g
                            • 704
                            #43
                            Managed to get some of them to work by changing the settings in coverfloader.
                            Dont understand why they all work in uloader but not in coverfloader
                            • ck-ok
                              • 2592
                              #44
                              coverfloader will play your backups you just need to get your setting right for each game and then save them,there is a 002 fix in settings,and some games need to be launched with 222 or 223,bit of a ball ache but once you get it running properly youll be well away,and its so much better looking interface than uloader
                              • m9g
                                • 704
                                #45
                                Oh yeah totally agree it is a better interface than uloader and the ones i have got running yes i agree was a ball ache to setup, keep switching wii off and firing backup again, keep changing the settings until one works.
                                So how do I change to 222 or 223?
                                Cheers
                                M9G
