Hi guys, trying to softmod a v4.2e and i cant even get it to read the sd card. Any ideas. Grateful for help. I have the wii softmodding for dummies package.
v4.2e softmod
Format the card first.
This does it all for you, Click the install batch file and type the location of your sd card on the pc and this will set the card up ready to go.Attached Filessigpic
Patience is a virtue. -
im having the nothing but trouble with a wii that has never been softmoded, updated to 4.2e but it hangs just after the boot from SD, its on the screen where i choose what IOS i want to use, nothing happens, tried various different packages that suppose to work, will try the one posted above, but i needed to post first, i will give my results once i have tried this one. thx guys u rock!Comment
let's see if I understood well.
So place all the files on SD card and boot on it.
If I remove/format the SD card the Wii will still be as just opened from the box ?Comment
tried this as well as other soft mods which have worked but somthing has gone wrong.
tried this version when it asks where sd card located in pc i put in the letter then pc says copying files but noting gets copied
if i drag files on or from this software or one of the other software mods just get question mark in sd of wii section
thx
dazComment
Daz you still at this m8, you've been at this for months m8,tried this as well as other soft mods which have worked but somthing has gone wrong.
thx
daz
no m8 i was doing my uncles but was using newee software, when i tried uncles out found software was better (new stuff)
so swapped mine over, then when playing on mine discovered ghostbustes had blue screen so when i tried to sort it out somehow totally mesed mine up and system updated itself ,
that stopped me using the newer firmware.
but looks like its sorted now until i add somthing but mess up again
thx m8Comment
