trouble with just dance
  • ck-ok
    • 2592
    #16
    Originally posted by gercekdiler
    ı tried it install cios 38 v17 and usb loader 4.1.Again ı have the same problem ı pushed the start button the game is loaded the remote control screen is loaded and then the black screen appears and wii stuckes.Do you have any idea for that. I'm going to break my wee at last.
    what region is your wii?
    have you tried playing the game with 002 fix on?
    have you tried using cios 222 and 223?
    • gercekdiler
      • Feb 2010
      • 12
      #17
      its PAL and I download several times PAL versions. before I installed cios 222 v4 at that time when I started the game the remore controller screen did not appear but I didnt try cios 223 have you got a link for cios 223 installer. also if I need to install 223 do I need to uninstall the cios 38 rev 17. still I havent understood the logic of these cios and ios's
      • ck-ok
        • 2592
        #18
        no you dont need to uninstall cios38 rev 17,when you install and update uloader there is also a hermes cios installer,use that to give you 222/223,make sure 002 fix is turned on http://www.digital-kaos.co.uk/forums...-1-pack-89896/
        • gercekdiler
          • Feb 2010
          • 12
          #19
          i did it I install 222 then 223 and 202 by different times and try to load but everything is the same. also there is no where to turn on the 002 at uloader. do you have any idea for that. everything is the same with the previous ios's
          • m9g
            • 704
            #20
            I was going to ask, where is the oo2 fix in uloader? I have looked through all the settings i can find and see nothing, I have uloader 4.9a by hermes.
            Regards
            M9G
            DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
            • ck-ok
              • 2592
              #21
              Regards
              M9G
              on up to date versions 002 fix is built in
              • ck-ok
                • 2592
                #22
                can you play any games?
                • gercekdiler
                  • Feb 2010
                  • 12
                  #23
                  yes i can play some games for example carnival games and world sports party etc.And i have some scrubbed games just i couldn't play with those.İf you have any info please help but just dance is main important game for me to play.
                  • ck-ok
                    • 2592
                    #24
                    try installing these ios's put in wad manager and install with wad manager
                    • gercekdiler
                      • Feb 2010
                      • 12
                      #25
                      thank you but i did and nothing has changed. really Im going mad.........I can see the remote controller screen but then everythings gone black and stucked........
                      do you have any other options
                      • ck-ok
                        • 2592
                        #26
                        with all the software you have installed you should be able to play just about any game,seems it could be your games your downloading,try getting them from another source or see if you can borrow it from someone and copy it yourself
                        • gercekdiler
                          • Feb 2010
                          • 12
                          #27
                          thank you very much I will try to find the game. do you have any information to play compressed(I think they are compressed with Wiiscrubber) games. because when I try to play them tehre is an error like "ID is not valid" or Error 1209. I try to find them but I couldnt find any details. Is there any special software to play with these kind of games or else?
                          • m9g
                            • 704
                            #28
                            I softmodded a wii for a friend with exactly the same software as I have on mine and installed exactly the same way, he couldnt play some of the games that i could play on mine. He changed the hard drive and all played fine.
                            Just an idea
                            M9G
                            • rigga
                              • Sep 2009
                              • 102
                              #29
                              my just dance works fine on 4.2 softmod boots from disc channel
                              • capth
                                • Apr 2010
                                i've been having similar issues, some of the advice here should help...thanks
