your shape camera
  • DeaconX
    #46
    Originally posted by ck-ok
    the update is just the camera driver files nothing to worry about,just let it update
    You're a lifesaver. It works fine, nothing bad happened.
    BIG thanks from me & DA wife.
    • rodas_pogpu
      #47
      What cameras have people tried? And what works? Also has anyone had any luck with this through neogamma?
      • ck-ok
        • 2592
        #48
        xbox 360 live works,cams with microphones seem to cause a problem,as for others nobody has said what cam they have used, but logitec seem a no go.give yours a try and let us know,and neogamma wont be a problem.
        • rodas_pogpu
          #49
          mine is a logitech, with a microphone will try but not looking hopeful!
          • llieno
            im sorry to be stupid! but does it work with live vision cam and neo r7 but not usb loader is that right?
            with ios58 installed!
            as i keep getting an error?
            • ck-ok
              • 2592
              #51
              should work with neo r7 what is the error?dont know about the cam
              • sysace
                • Apr 2010
                1st post so I can test IOS 58 for Your Shape
                Hey guys, been searching for a solution to "Your Shape" complaining about the camera not working... hoping the IOS58 will fix my problems... brownie points with the wife for me if it does.
                IOS58 as posted in this thread did not resolve my issue. Loaded, tested, same error. Reloaded via WAD Manager again, rebooted Wii, same error, even if the cam isn't plugged into the console. This is the original white cam that came with the game.
                System is 4.2. Any advice/suggestions would be appreciated!
                Thanks,
                • ck-ok
                  • 2592
                  #53
                  Thanks,
                  have you installed the custom cios 222 Digital Kaos - Downloads - custom cios222v5 installer also try swapping usb ports
                  • gooner69
                    • Apr 2010
                    ios58-64v5918
                    Guys
                    I am about to try this will let u know how/if i get it working.
                    • danieloliva
                      Hello folks!
                      Before I begin CIOS58 install on my 4.2U, is there anything I must be aware?
                      It has homebrew installed and runs USB disk through WiiFlow.
                      • lord wanhoop
                        • Jul 2010
                        thnx
                        I hope that the ios file will fix this problem.
                        I have been searching the whole saturday to fix the problem.
                        My wife will be very pleased if this game works.
                        • emresumengen
                          • Aug 2010
                          I've bought the original game and it just blacks out on me, using the dvd.
                          I've got a 3.2E softmodded wii and will try this IOS58. Let's see if it helps
                          • scannerscars
                            • Apr 2010
                            • 31
                            #58
                            Fantastic, Not it wise
                            • TheArtifice
                              Installing the wad (ios58-64 v5918) with Dop-Mii v12 will do the work?
                              • Longie
                                There's also an auto installer you can use, run it from the homebrew channel and it apparently downloads it from the nintendo servers. I'll try it and cross my fingers
