unable to open uloader error message from sd card
  • omar999
    • Apr 2010
    • 16
    i followed this guide http://www.digital-kaos.co.uk/forums...like-me-20545/ step by step for my wii 3.4e console.
    by the looks of things everything went well and installed as I have the homebrew channel, uloader & I downgraded my firmware to version 3.2 - but now when i try to play a backup game via u loader i get the following error;
    cannot open: sd:apps/uloader/boot.dol
    and yes the sd card is in my wii with everything on it.
    can anyone help - do I have to uninstall everything i've done so far or ? is there a step I could have gone wrong on?
  • ck-ok
    • 2592
    Originally posted by omar999
    i followed this guide step by step for my wii 3.4e console.
    by the looks of things everything went well and installed as I have the homebrew channel, uloader & I downgraded my firmware to version 3.2 - but now when i try to play a backup game via u loader i get the unable to open uloader error message from sd card? and yes the sd card is in my wii with everything on it.
    make sure uloader is in the apps folder,and make sure the uloader folder is not inside another folder uloader folder
    • omar999
      • Apr 2010
      • 16
      thanks for the quick reply ck-ok.
      just double checked the sd card and uloader file is in the following directory;
      E:\apps\9. Uloader\boot.dol
      so i renamed the 9. Uloader folder to "uloader" making the directory to;
      E:\apps\uloader\boot.dol
      and wala uloader loads up. but now getting a different error;
      dvd error -1 cIOS249
      and theres a spanish flag on the disc image?
      thanks in advance.
      Omar.
      • ck-ok
        • 2592
        thanks in advance.
        Omar.
        the spanish flag is normal,butit sounds like you might have a incorrectly installed cios 249 try installing this
        http://www.digital-kaos.co.uk/forums...s38-r17-85849/ and what discs are you using and what burning program?
        • omar999
          • Apr 2010
          • 16
          im using verbatim dvd-r discs alongside nero burning rom [burning iso on slowest speed possible]
          gonna give the cios38r17 a go now...
          • ck-ok
            • 2592
            do a google search for imgburn its free and much better for wii iso's
            • omar999
              • Apr 2010
              • 16
              just tried to install cios38r17 and have an error.
              screen reads >> installing title...ERROR! (ret = -1017)?
              • ck-ok
                • 2592
                is the wad for cios38r17 on the root of your sd card?
                • omar999
                  • Apr 2010
                  • 16
                  i removed it from the root and put it in the wad folder because i couldnt access the wad that way.
                  im probably just being a newb...how do you access the wad from the root?
                  • ck-ok
                    • 2592
                    when you start the installer select wad installation and if the wad is in the root of your sd card it will find it automaticly
                    • omar999
                      • Apr 2010
                      • 16
                      still getting an error
                      failed -1017
                      install returned -1
                      • ck-ok
                        • 2592
                        failed -1017
                        install returned -1
                        did you miss these two steps
                        Load Wad Manager in Homebrew Channel and install IOS16-64-v257-prod.wad
                        Load Custom WM in Homebrew Channel and install cios_fix.wad
                        • omar999
                          • Apr 2010
                          • 16
                          im pretty sure i havent missed those steps. anyway iv reinstalled both IOS16-64-v257-prod.wad & cios_fix.wad and now this time cios38r17 has managed to install fine from installer.
                          went to uloader - hit 2 to boot game and have got a black screen with loads of mumble jumble text
                          exception dsi occured!?
                          • ck-ok
                            • 2592
                            reboot the wii and try uloader again
                            • omar999
                              • Apr 2010
                              • 16
                              rebooted twice & same error...
