try using this http://www.digital-kaos.co.uk/forums...-final-104295/
unable to open uloader error message from sd card
ck-ok thanks for all your help mate!
update: neogamma r8 is working fine and has loaded every game i've burnt using imgburn wohoo. EDIT: Just installed neogamma r8 channel too.
uloader never works tho and crashes the console every time with the black screen code dump? im thinking of removing the channel altogether or do I need uloader in the future for something? which app plays dvd movies?Last edited by omar999; 10 April, 2010, 10:22.Comment
if you have uloader as a channel it might be a bad wad install,as for movies try this http://www.digital-kaos.co.uk/forums...49/#post474411 as for uloader try this one if you want it,dont bother with the custom 222 installer you already have that, http://www.digital-kaos.co.uk/forums...-1-pack-89896/ it is auto updateable aswellck-ok thanks for all your help mate!
uloader never works tho and crashes the console every time with the black screen code dump? im thinking of removing the channel altogether or do I need uloader in the future for something? which app plays dvd movies?sigpicComment
cheers iL give installing uloader4.1 a go.
how do I go about uninstalling the uloader channel I already have? do I have to uninstall or undo these steps;
"Run cIOS Installer in Homebrew Channel
Load "Install Shop IOS51". Say Yes to installing IOS51,Yes to patching a fix but leave the Wii Shop Channel.
Load Wad Manager in Homebrew Channel and install forwarder-UMRD.wad and IOS38-64-v3609.wad.
Lastly open homebrew channel, and install cIOS38 (It's listed as cIOS36) USE NETWORK INSTALL"
Now you should have the Uloader channel on the Wii menu.. use this to launch Wii backups
(Press 2 to run games from DVD)"
?Comment
no use wad manager start it select ios 249 then select sd card then navigate to uloader wad and uninstall it then push home button donecheers iL give installing uloader4.1 a go.
?sigpicComment
by the looks of of it you have a uloader forwarder not full channel,a forwarder is a link from main menu too the uloader on the sd card,before you delete the wad try swapping your old uloader in the apps folder for the new one,then try and start it from the main menu,or if you want to uninstall it do the same as you did before navigate to forwarder-umrd.wad and select uninstallLast edited by ck-ok; 10 April, 2010, 18:58.sigpicComment
