Uloader formatting ext SATA HD
  • stucatz
    • Apr 2010
    • 86
    Hi Guys,
    Just a quick question. I have connected an 80GB hitachi sata drive to the wii to format it to wfbs via Uloader, but its been going about 10-15 minutes. I can hear the drive working, and the wii disc slot flashes blue (goes on & off), but just wondered is it actually formatting it or not? Its taking a long time, not sure how long and the screen is frozen on the screen that says Format WFBS, are you sure you can format? Yes in bottom right, no bottom left. I selected yes, then drive and its currently stuck?
    Do i let it continue?
    Or do I disconnect it and format it via WFBS manager?
    Many thanks
  • ck-ok
    • 2592
    Originally posted by stucatz
    Hi Guys,
    Many thanks
    format with Digital Kaos - Downloads - wbfs manager 3
    • stucatz
      • Apr 2010
      • 86
      hi ck, do I just switch it off at the mains or disconnect it whilst its in its frozen stage? I dont want to damage hard drive.
      • ck-ok
        • 2592
        switch off at mains
        • stucatz
          • Apr 2010
          • 86
          thanks ck, ok i formatted it via WFBS manager and it said that it had done it successfully, but when I plug it into wii and then start uloader the main screen doesnt give me option to run disc or run HD. Any ideas?
          • ck-ok
            • 2592
            have you got any games on it
            • stucatz
              • Apr 2010
              • 86
              no i havent, i just formatted it first via wfbs manager. I had a game in the wii that i was about to copy via uloader, but it didnt let me do that. Seems like its not picking up the HD on the wii.
              • ck-ok
                • 2592
                start uloader and push the home button and select add game
                • stucatz
                  • Apr 2010
                  • 86
                  hi ck, the main issue is when i load uloader via HB channel, it loads up then straight away it flashes a very quick message (I saw something like CIOS) but then it just shows main screen and doesnt give me any option to either run from disc mode, or anything. I press home button but nothing works.
                  • ck-ok
                    • 2592
                    put hdd in other usb port and try again
                    • stucatz
                      • Apr 2010
                      • 86
                      still nothing mate. It just flashes up this CISO message, but its so quick i cant read it then it freezes. also i noticed when i checked the disc properties on windows xp it said NTFS as apparently you cant format anything bigger than 32gb to FAT32, which is maybe what the drive needs to be formatted to before the wii or wfbs manager creates the wfbs partition. Could this be the problem?
                      • ck-ok
                        • 2592
                        without knowing the error i cant say what it is thats wrong
                        could be that you didnt install the cios 222/223 installer
                        try coverfloader http://www.digital-kaos.co.uk/forums...er-1-2a-91685/ to see if your usb is working
                        • stucatz
                          • Apr 2010
                          • 86
                          hey ck im sure i installed the cios 222/223 installer as i formatted a 2gb usb stick through uloader & copied wiiplay through uloader & it worked fine so must be a problem with formatting the drive even though its been done via wfbs manager.
                          what does coverfloader do? could i reinstall the cios 222/223 installer? but if it were a problem wouldn't the usb stick work?
                          • ck-ok
                            • 2592
                            coverfloader is just another usb launcher,if uloader gave you the option to format your drive then it has detected it, try reinstalling this Digital Kaos - Downloads - custom cios222v5 installer and try coverfloader,and is the hdd in a caddy case?
                            • stucatz
                              • Apr 2010
                              • 86
                              yes it is in a HD caddy, and is being connected via USB.
                              I have reformatted to FAT32 and now insert it into wii, load uloader and it says no WFBS partition found and then i try to format it, so letting it try but it looks like its doing the same thing as last night where it basically seems to just carry on trying to format it, takes a long time and doesnt seem like itsmaking any progress.
                              I also checked the CIOS 222/223 and when i try to install it via multi mod, it says ret 1 = error.
