black wii 4.2e softmod
  • gazlyn
    • 6
    i used the attatched files and insructions to softmod a number of black 4.2e wii's acouple of months ago and all went great and all wii's still running perfect
    the homebrew channel and usb hd loader are all included
    all i can remember is im sure i got them fro this site so im just returning someone elses work to thank them
  • calibrator007
    • May 2010
    thanks man
    i appreciate you doing this man, i am trading my white wii in for a black one at gamestop for 49.99. I dont want to lose anything but i have a black 360 and ps3 so I had to get this. Here goes nothing.
    • hnnkiwi
      • May 2010
      Prob a pretty basic question, but will this also work on version 4.2U? From what I've gathered, the letter is simply the region code, right?
      • Timmaa
        • 88
        As I understood it ALL black wii's have the new DVD drive that will not play backups. Is this wrong?
        Regardless I'm running [ame="http://www.amazon.co.uk/gp/product/B001XLX1SI/ref=oss_product"]this little beauty[/ame] and it works like a charm.
        • ck-ok
          • 2592
          Regardless I'm running this little beauty and it works like a charm.
          no your not wrong,but its a bit pricey argos are knocking 500gig seagates out for ?50
          • lfc1970
            • May 2010
            mm??
            New here, where on earth do io start
            • mickydibble
              • 2166
              Lol it's all in the sticky threads take a look
              • karakuza
                • May 2010
                I have a problem with softmod.
                i can't softmodding my black wii. In 2nd point. If you can help my please reply.
                • ck-ok
                  • 2592
                  what is it you cant do?
                  • nintendog
                    • May 2010
                    • 116
                    usb not working
                    hi guys im after the usb loader that enables you to transfer games from disc to usb on the wii also do the usb on wii need to be configured as ive trid loader gx and tells me to wait 30 sec and says no usb found
                    aslo casn any body point me in the direction of the wiiflow as im told this is great for running from usb and getting covers thanks for the info guys
                    • ck-ok
                      • 2592
                      Digital Kaos - Downloads - wiiflow 1.1a format your drive with this Digital Kaos - Downloads - wbfs manager 3 and try swapping usb ports
                      • vish28
                        • Jun 2009
                        • 9
                        Hey, thanks for tutorial.
                        Done steps 1 and 2 on version 4.2e black. Bootmii installed as IOS only.
                        Step 3 requires the launch of Bootmii from HBC. When I press the home key and try to launch Bootmii the screen goes black and the dvd drive flashes blue. The only thing I can now do is turn off the wii and restart to get to the main menu. I have tried leaving the bootmii folder from step 2 on the sd card; this stops the blue flashing drive when trying to launch bootmii, however now I just get a black screen that hangs.
                        Even worse, when putting wii sports resort original disc in, the wii requires update. I am not sure I should do this as I have not got far enough to install priiloader and make a NAND backup. (I have only deleted the 4 .wad files listed in step 2 and no others) Wii Sports original will play without update.
                        Any suggestions as to why I cannot launch bootmii? Should I do the update? and if I do will it stop me soft modding again or worse will it cause a brick?
                        • ck-ok
                          • 2592
                          dont panic wii sports resort is ok to update
                          reinstall homebrew channel and bootmii again with a quality sd card like verbatim 2gig bootmii is very picky about sd cards
                          • mahf51
                            • Jun 2009
                            • 114
                            hi will this soft mod work on white wii? or is it just for the black wii running 4.2e
                            • vish28
                              • Jun 2009
                              • 9
                              thanks ck-ok
                              used a sandisk 2gb but will get a verbatim ordered. Will post the result here in a few days.
                              The other thing is the version of HBC that gets installed is 1.0.5. When starting up it recommends upgrading to 1.0.6.
                              Should I do this?
