softmodded wii help
  • tazzystu
    softmodded wii help
    will already softmodded but not working properly so i am thinking of upgrading and totaly unsure how.
    do i have to remove the existing softmod and run on a virgin console
    or is their a way to to update safely overwriting softmod
    or must i do a full nand backup?
    then remove then update
    looked in the forums to much information carnt see the best way to proceed any help thanks.
  • d1y31
    as i can see, maybe u are talking about wii or psp,on any case , make a nand backup is always the best, DN?T remove the old softmod and just make the update or reinstall of the softmod maybe can solve ur problem...please give us more details..
    • opsmonkey
      • 5379
      ask your questions in the right section.. there is a dedicated gaming section for questions like this..
      also your first posts should be in the introduction section, as per your welcome email..
      try to read the rules also
      • Dreamer
        • 2020
        As ops has already said. You're post was in the wrong section. It has now been moved in here where you are more likely to get some help and you may also find other posts in this section which will help you
        The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
        • ck-ok
          • 2592
          firtsly update your cios with this http://www.digital-kaos.co.uk/forums...s38-r17-85849/ then you need to update your loader,but untill you tell us which one you use i can't help anymore.
