4.3e downgrade
  • shagx
    • 50
    4.3e downgrade
    Right can anyone offer some advise in the way of some instructions/advise to help me downgrade my software modded 4.3e Wii.
    Ive got the homebrew channel on whats next
  • ck-ok
    • 2592
    theres a couple of ways to downgrade try reading here We Hack Wii / Firmware make sure you have your nand backup sorted with preloader installed as downgrading is one of the most common causes of bricked wiis,dont try and do this if all the wads on the 4.3 tut didn't load without error.
    good luck
    • MetalKettle
      V.I.P.P.T. Member
      • 797
      Why would you want to downgrade?
      XBMC/KODI Developer
      • ck-ok
        • 2592
        downgrading is useful if you have a chip fitted as it gives you back multi region playback again
        • happy_highlander
          • 3535
          If he has followed the 4.3 mod tut then he could set region free everything in priiloader anyway. Not that I know that much more than I have asked ck-ok to give advice about anyway.
          • shagx
            • 50
            Thanks alot im down to version 4.1E
            Next on my task is usb loader....
            Right I have usb loader gx working fine
            Im struggling to get Wiiflow working I get the list of games up with my covers etc but the thing is when I select a game it just hangs at please wait, I cant see whats wrong here been on this for hours has anyone got any ideas.
            Im using the same working hard drive as usb loader gx
            Cheers
            • MetalKettle
              V.I.P.P.T. Member
              • 797
              Cheers
              How is your HDD formatted and partitioned? Wii flow had some problems with 2 WBFS formatted partitions.
              XBMC/KODI Developer
              • shagx
                • 50
                its just a single formatted drive as WBFS with no partitions
                • MetalKettle
                  V.I.P.P.T. Member
                  • 797
                  Which CIOS are you running and which versions/bases?
                  XBMC/KODI Developer
                  • shagx
                    • 50
                    This is something im not sure on as when i load up hackmii installer i get a screen advising me there is no vulnerable IOS installed on this Wii.
                    I have ran through the procedure here and still no go
                    This page will explain how to fix 2 problems at once, both related to the Hackmii installer. The first one is the So called "No Vulnerable IOS found" error message from the Hackmii installer itself. Whenever the hackmii installer starts, it will check a set list of IOSs it can use. It will not use
                    • ck-ok
                      • 2592
                      http://sites.google.com/site/complet...-stuff/fix-hbc
                      did you follow and install all the wads from 4.3 tut?
                      have you installed darkcorpe?
                      • shagx
                        • 50
                        ?Hi thanks for assisting,
                        I have downgraded from 4.3 to 4.1 and no I havent installed darkcorp (at least i dont think i did being a newbie)
                        Cheers
                        Neil
                        • ck-ok
                          • 2592
                          Cheers
                          Neil
                          did you install all the wads from 4.3 tut?
                          • shagx
                            • 50
                            yes, followed the tutorial all the way through but since then i have been replacing wads trying to get it going
                            • ck-ok
                              • 2592
                              for wiiflow installation try here WiiFloWiki
                              as for non vunerable iso try this
