Right can anyone offer some advise in the way of some instructions/advise to help me downgrade my software modded 4.3e Wii.
Ive got the homebrew channel on whats next
theres a couple of ways to downgrade try reading here We Hack Wii / Firmware make sure you have your nand backup sorted with preloader installed as downgrading is one of the most common causes of bricked wiis,dont try and do this if all the wads on the 4.3 tut didn't load without error.
good luck
downgrading is useful if you have a chip fitted as it gives you back multi region playback again
If he has followed the 4.3 mod tut then he could set region free everything in priiloader anyway. Not that I know that much more than I have asked ck-ok to give advice about anyway.
Thanks alot im down to version 4.1E
Next on my task is usb loader....
Right I have usb loader gx working fine
Im struggling to get Wiiflow working I get the list of games up with my covers etc but the thing is when I select a game it just hangs at please wait, I cant see whats wrong here been on this for hours has anyone got any ideas.
Im using the same working hard drive as usb loader gx
Cheers
How is your HDD formatted and partitioned? Wii flow had some problems with 2 WBFS formatted partitions.
This page will explain how to fix 2 problems at once, both related to the Hackmii installer.
The first one is the So called "No Vulnerable IOS found" error message from the Hackmii installer itself. Whenever the hackmii installer starts, it will check a set list of IOSs it can use. It will not use
