Wii 4.3E/U softmod - Using Indiana Jones - Original Adventures
  • rudidudi
    • Jul 2011
    • 61
    #226
    even easier wth letterbomb, no need for disk
    • Kalsta
      • Aug 2011
      #227
      4.3e Unable to install Priiloader
      Hi there,
      Just bought my first Wii on Friday, replaced the disc drive and installed the WODE Jukebox then use the Indiana Hack to install Homebrew. I am currently unable to install Priiloader (I get a cIOS036 cIOS036 isn't ES_Identify patched error -1017 when I try), so I am hoping that by following this tutorial I can fix the issue.
      My sysCheck results are as follows:
      sysCheck v2.1.0b12 by Double_A and R2-D2199
      ...runs on IOS58 (rev 6176).
      Region: PAL
      System Menu 4.3E (v514)
      Homebrew Channel 1.0.8 running on IOS58
      Hollywood v0x21
      Console ID: 146369387 Boot2 v4
      Found 85 titles.
      Found 46 IOS on this console. 17 of them are stub.
      IOS3 (rev 65280): Stub
      IOS4 (rev 65280): Stub
      IOS9 (rev 1034): No Patches
      IOS10 (rev 768): Stub
      IOS11 (rev 256): Stub
      IOS12 (rev 526): No Patches
      IOS13 (rev 1032): No Patches
      IOS14 (rev 1032): No Patches
      IOS15 (rev 1032): No Patches
      IOS16 (rev 512): Stub
      IOS17 (rev 1032): No Patches
      IOS20 (rev 256): Stub
      IOS21 (rev 1039): No Patches
      IOS22 (rev 1294): No Patches
      IOS28 (rev 1807): No Patches
      IOS30 (rev 2816): Stub
      IOS31 (rev 3608): No Patches
      IOS33 (rev 3608): No Patches
      IOS34 (rev 3608): No Patches
      IOS35 (rev 3608): No Patches
      IOS36 (rev 3608): No Patches
      IOS37 (rev 5663): No Patches
      IOS38 (rev 4124): No Patches
      IOS40 (rev 3072): Stub
      IOS41 (rev 3607): No Patches
      IOS43 (rev 3607): No Patches
      IOS45 (rev 3607): No Patches
      IOS46 (rev 3607): No Patches
      IOS48 (rev 4124): No Patches
      IOS50 (rev 5120): Stub
      IOS51 (rev 4864): Stub
      IOS52 (rev 5888): Stub
      IOS53 (rev 5663): No Patches
      IOS55 (rev 5663): No Patches
      IOS56 (rev 5662): No Patches
      IOS57 (rev 5919): No Patches
      IOS58 (rev 6176): USB 2.0
      IOS60 (rev 6400): Stub
      IOS61 (rev 5662): No Patches
      IOS70 (rev 6912): Stub
      IOS80 (rev 6944): No Patches
      IOS222 (rev 65280): Stub
      IOS223 (rev 65280): Stub
      IOS249 (rev 65280): Stub
      IOS250 (rev 65280): Stub
      IOS254 (rev 65281): BootMii
      BC v6
      MIOS v10
      Report generated on 2011/08/27.
      Thanks in advance,
      Kal
      Worked a treat, thank you I now have Priiloader installed (upgraded to v0.7 of course). Only thing I need to figure out now is how to restore my Bootmii?
      Cheers,
      Kal
      • Keithuk
        • 2264
        #228
        You generally only restore the NAND from BootMii if you have bricked your Wii do you have a problem?
        To operate PriiLoader you just press the Reset button and that will show a menu with BootMii select that. You then click the Power, Power, Power, Reset on the next screen Reset again to save your NAND to the SD card or Power then Reset to restore your NAND.
        Now saving your NAND is the first job you do after installing Homebrew and BootMii in the IOS. You should have selected Prepare SD card that will put the [BootMii] folder on the SD card. If BootMii can't see this folder it won't work.
        Keith
        2010 Golf GTD (170)
        • Kalsta
          • Aug 2011
          #229
          Hi Keith,
          Thanks for the prompt response!
          My original problem was that the initial tutorial I used (WWW.WODEJUKEBOX.ORG • View topic - WodeFlow 4.3 Video install guide), didn't mention anything about BootMii, so although it was installed as an IOS I hadn't setup the SD.
          The only problem I had after using this tutorial was that if I selected BootMii I got MMM instead, I fixed that by copying a backup of my BootMii folder to my SD and am now I'm all sorted.
          Thank you so much, great tutorial and much appreciated followup comments!
          Regards,
          Kal
          • shyster
            • Aug 2011
            4.3e help
            does anybody know if this works on a wii,that has updated online from a 4.1 soft mod
            • stephenmartin67
              • Sep 2011
              do i fully format the sd card, i.e uncheck the quick format button?
              • Keithuk
                • 2264
                #232
                Welcome to the forum.
                Not really a quick format will do or just delete all files and folders?
                Keith
                2010 Golf GTD (170)
                • oogie619
                  • Sep 2011
                  #233
                  smash bros
                  hi does this work with super smash bor's
                  • zeroonetwo
                    • Sep 2011
                    • 4
                    #234
                    stuck at backing up NANDS
                    All worked fine and the homebrew channel is installed but now I am at the backing up NANDS thing and when I click launch boomii the screen disappear and I do not understand what to do with the following instruction
                    "Using your Wii Console to the control the selection, you need select the 4th icon across (settings, picture of two cogs) To move across to this press, POWER, POWER, POWER & then hit RESET."
                    could you please help?
                    WII 4.3E
                    • Keithuk
                      • 2264
                      #235
                      Originally posted by zeroonetwo
                      All worked fine and the homebrew channel is installed but now I am at the backing up NANDS thing and when I click launch boomii the screen disappear and I do not understand what to do with the following instruction.
                      As you installed HBC you had 3 options
                      1. Install Homebrew
                      2. Install BootMii in IOS
                      3. Prepare SD card which puts the [bootmii] folder with a few files on the SD card else when you choose BootMii from Homebrew it will do nothing.
                      You have the instructions how to navigate the BootMii icons.
                      POWER, POWER, POWER & then hit RESET then on the next screen press RESET again to backup your NAND to the SD card.
                      After its backed up to the SD card remove the SD card from the Wii and put it in your computer and copy the [bootmii] folder and keys.bin and nand.bin of the cards root into a safe folder as if these get deleted of the SD card for some reason you are stuffed for restorng it back into the Wii. Backup your NAND before you install anything else?
                      Now that you have installed Homebrew the next job is to install PriiLoader 0.7 as this will block any updates that Nintendo send out along with any updates of discs you may use. You can do a few more tweaks with PriiLoader as well.
                      The next job will be to install USB Loaders there are 5 to choose from I think, there are examples on here so you can play downloaded games of an external HDD.
                      Keith
                      2010 Golf GTD (170)
                      • zeroonetwo
                        • Sep 2011
                        • 4
                        #236
                        Keith
                        Thanks a lot for a quick response. However, the problem is not resolved. I prepared sd card but When for backing up NANDS I click on "launch bootmii" after pressing home from the homebrew channel, the screen disappears (turns blank) and it doesn't show "4th icon across (settings, picture of two cogs)"
                        With blank screen I pressed power,power,power from wii console and then reset which restarts the console and take me to the main wii screen and doesn't show green icon to back up sd card.
                        I have checked sd card on my laptop and it has bootmii folder with 3 files in it so can't understand what is wrong here.
                        Any help will be highly appreciated.
                        1. Install Homebrew
                        • Keithuk
                          • 2264
                          #237
                          Well that is strange as it appears you have followed the correct procedure and sequence. There should be armboot.bin, bootmii.ini and ppcboot.elf in the [bootmii] folder.
                          Keith
                          2010 Golf GTD (170)
                          • Keithuk
                            • 2264
                            #238
                            Now I've just had a read on another forum Hackmii Installer - FIX
                            This guide should fix:
                            Hackmii- No Vulnerable Ios Found- suck it
                            Hackmii- Black Screen
                            Hackmii- Scam Screen Freeze
                            You will probably have to join this forum before you can download anything or read Spoilers.
                            Keith
                            2010 Golf GTD (170)
                            • ck-ok
                              • 2592
                              #239
                              WII 4.3E
                              what size and type of sd card are you using?
                              • zeroonetwo
                                • Sep 2011
                                • 4
                                #240
                                I am using Kingston 2GB SD Card. I will try the forum Keith mentione din his earlier post this evening when I go back home and report if it resolves the issue.
