Wii 4.3E/U softmod - Using Indiana Jones - Original Adventures
  • dingledaly
    • 4
    #46
    I am using the normal disk channel.
    I used Maxwell DVD-R disks
    I used imgBurn to burn the dvds at 4.0 speed.
    Thank you for taking the time to try and figure this out.
    • ck-ok
      • 2592
      #47
      try using the backup channel that came with the mod might be called backup channel or neogamma
      • dingledaly
        • 4
        #48
        I used the neogamma channel and it worked fine. Is this the normal way that the backup disks works or can you usually use the normal disk channel?
        Eitherway a big thanks to stanny2k/manonamissionblue/janobi for the original tutorialsand to ck-ok for the help.
        • ck-ok
          • 2592
          #49
          yes you use neogamma to play your backups you can also use the usb loadergx channel click the dvd icon in top r/h corner
          • joske smoske
            #50
            trouble bij loading from the SD-card
            Hello,
            I bought Indiana jones lego and copied de files to an SD-card. So far so good, but when I choose the switch to option in the artroom (after changing the savedgame). I get the following problem. "SD card not found (-1056964604)
            USBGecko not found
            No code found to load, hanging."
            Is there something I forgot or what can be the reason of this problem.
            regards,
            Joske
            • andy91
              • Aug 2010
              • 3583
              #51
              Originally posted by joske smoske
              Hello,
              USBGecko not found
              regards,
              Joske
              Have you checked what version your Wii is on mate??
              This hack is for the latest 4.3e,format your card and start again.
              Andy.
              • smicer07
                #52
                Quick question. Once hacked can you:
                a) play games that are burnt to a DVD
                b) play games via a USB hard drive?
                cheers.
                • happy_highlander
                  • Aug 2010
                  • 3535
                  #53
                  cheers.
                  a) depends on what drive is in your wii. If it is a red or black wii then no and the newier white wii's also have the same drive.
                  b) Yes all wii's can use external usb hdd once modded. This method is also much more compatible with games as it runs them at the proper speed. A wii can only read a DVD-R at half the speed an original disk runs at.
                  • tockh1
                    wii 4.3e
                    does anyone know where i can get software needed for indiana jones softmod
                    • ck-ok
                      • 2592
                      #55
                      yeah just go too the first post in this thread
                      • wimmo
                        unexpected end of file
                        I tried to download the wii Hacks, but both times i get an error, saying "unexpected end of file", what should i do now?
                        • ck-ok
                          • 2592
                          #57
                          keep trying might be a server error
                          Digital Kaos - Downloads - 4.3 hack files
                          • parley
                            • 106
                            #58
                            hi guys foloowed tut on a mates 4.3 wii that was already chipped, seemed to go okay but when i try to play a disc through neogamma, drive sounds clunky and i'm getting error message, DVD read error(1328) any ideas please.
                            • ck-ok
                              • 2592
                              #59
                              if its a new wii then it cant play dvd backups
                              • parley
                                • 106
                                #60
                                thanks for the quick reply, the wii was previously hardchipped and played back up dvds apparently, could it be thats its not a virgin wii that the hack hasnt worked?
                                thansk
