SD CARD PROBLEM....HELP NEEDED!!
  • H4MST3R
    • Apr 2009
    • 18
    Hii guys........ ok..... am just about to do a softmod on a 4.1e...... got new sd card (2g) and im getting "the device inserted in the sd card cannot be used"
    it's formatted, and i've tried it in another wii (4.2) and it works fine.
    i've also tried the sd card (1g) from the 4.2 into the 4.1 console and i get the same problem.
    is this to do with the 4.1.....im assuming these are ok to use sd cards without problem?
    the 4.1 is almost new by the way, never been modded, and never been online before....
    both cards i'm using are pentasonic micro sd, and work fine on the 4.2 console
    any idea's greatly appreciated ????????
    H4MST3R
  • ck-ok
    • 2592
    H4MST3R
    is it a micro sd in a carrier? if it is your better off getting a standard 2gig sd card with a good name
    • H4MST3R
      • Apr 2009
      • 18
      yes it is....but i cant understand why it works in one, and not the other??????.......id hate to go and get another card, and have the same problem. if i knew it would cure the problem then great...but i dont!
      • barrowmanandrew
        • 3427
        did you format it using a proper formatting tool?
        • H4MST3R
          • Apr 2009
          • 18
          i used the standard windows format on both cards
          • barrowmanandrew
            • 3427
            try using this formatting tool
            Digital Kaos - Downloads - sd formatting tool
            i have had sd cards before that were a bit picky.
            using a proper tool sometimes helps
            • H4MST3R
              • Apr 2009
              • 18
              ive just used the panasonic formatter...still the same...will d/l this one and give it a go......i'll be suprised if it changes things to be honest...surely if it was a format issue it wouldnt work in the 4.2 console....... but will give it a go before i end up bald!!!
              • barrowmanandrew
                • 3427
                , if youve treid one formatter it probably wont.
                i have had cards before that worked in some nds's and not in others.
                by using that formatting tool it solved the problems....
                • H4MST3R
                  • Apr 2009
                  • 18
                  LOL
                  cannot install because a newer version is already installed...
                  so i assume thats the old panasonic formatter.......
                  oh dear back to square 1
                  • barrowmanandrew
                    • 3427
                    ffs,
                    if you get o the bottom of it , let us know...
                    • H4MST3R
                      • Apr 2009
                      • 18
                      yea i will.....thanks again for all suggestions....
                      if anyone else has any idea....feel free !!!!!!! )
                      • ck-ok
                        • 2592
                        as first post wii's can be very perticular with sd cards especially micro sd cards get a proper quality sd card
                        • H4MST3R
                          • Apr 2009
                          • 18
                          ok it seems, that is the last idea......unless anyone has any other suggestions, ill get one tomorrow.
                          will let you know the results...
                          thanks again everyone for their help
                          H4MST3R
                          • reddevil157
                            • 1427
                            as already said, get a standard sd card, no more than 2gb and sandisk are said to be most compatible
                            • H4MST3R
                              • Apr 2009
                              • 18
                              OK..............
                              just got a new Sony class 4 2gb sd card.
                              ive tried formatting to fat, and also fat32.
                              ive tried the standard windows formatter, and also the formatter from this site.
                              i'm still getting "The device inserted in the SD Card slot cannot be used"
                              so now i am well and truly puzzled.... and yes the new sony card works fine in my 4.2 console.
                              any other suggestions please??? (except "throw your wii in the bin" !!!)
                              regards
                              H4MST3R
