try here Bannerbomb - WiiBrew
Cant Install Homebrew Channel
Success! I now have THC. The problem was (I think) that the guides I was following said to access the SD Card via Wii menu->Data Management->Channels->SD Card whereas the guide above says for bannerbomb v2 you should use the SD card icon on the main menu.
So, what do I need to istall now to play backup discs? I will not be usingan external HD - just burned discs.Comment
have you done the whole mod or do you just have the hb channel if you have done the whole mod you will proberly have a backup loader channel called neogamma which is what you use to launch your backupsSuccess! I now have THC. The problem was (I think) that the guides I was following said to access the SD Card via Wii menu->Data Management->Channels->SD Card whereas the guide above says for bannerbomb v2 you should use the SD card icon on the main menu.
So, what do I need to istall now to play backup discs? I will not be usingan external HD - just burned discs.sigpicComment
I tried to do the whole mod following the guide in the 'sticky' but it failed on install and patch ios36 - the error said it was unable to open the file on the sd card. Subsequent steps failed presumably because of that.
I was also confused when it said to run Any Title Deleter - as it did not appear on the HBC menu.
Should I delete the HBC and start again?Comment
UPDATE: I ran the option to install ios236 from the HBC menu and this has enabled me to install priiloader and all 41 wad files (it failed on a number of these before).
When I installed priiloader i got a couple of warnings that title/0000etc... was not deleted. I presume this is becuse Any Title Deleter has not been run - but this still does not appear on the HBC menu?Comment
AnyTitle Deleter - WiiBrew put this in your apps folder and start homebrew channel then delete whatever the tut says,which one are you following?UPDATE: I ran the option to install ios236 from the HBC menu and this has enabled me to install priiloader and all 41 wad files (it failed on a number of these before).
When I installed priiloader i got a couple of warnings that title/0000etc... was not deleted. I presume this is becuse Any Title Deleter has not been run - but this still does not appear on the HBC menu?sigpicComment
Done this and ran it ok. Also copied the uloader files into the apps folder so I have that as well.AnyTitle Deleter - WiiBrew put this in your apps folder and start homebrew channel then delete whatever the tut says,which one are you following?
Loaded Harry Potter back up DVD via uloader ok so all looks good now. Thanks for all your help.Comment
