PS3 Jailbreak Guide
  • freck
    • 1076
    PS3 Jailbreak Guide
    Step 1: Power off your console and make sure that there isn?t any disc in the Blu-ray drive.
    For the SLIM Model: Remove the power cord before plugging in the USB.
    For the FAT model: Turn off the power switch found at the backside of the console.
    Step 2: Now insert the USB based Modchip to any USB port of your choice on the console. Once the USB is in place, Power ON the console and immediately press the ?Eject? button. If the dongle is working properly, within a few seconds the LED light on the USB turns green, you are good to go as the dongle has been successfully loaded.
    If the LED does not stay green, then it means that the USB Modchip didn?t load successfully. This usually happens when the Power and Eject button sequence wasn?t performed properly. Start from Step 1 again, unplug/turn off etc.
    Step 3: Once the console has finished booting up with the USBBREAK Modchip green, plug-in the external USB storage device which has the "Backup Manager" setup to the console?s second USB port.
    Step 4: Now navigate to the "Game Menu" and select the option "Install Package Files" and then select "manager.pkg" file. This will basically install the ?Backup Manager? application that you download, to your hard drive.
    Step 5: When the "manager.pkg" file is done loading, scroll all the way down in the ?Game Menu? and there you should see a new application called "Backup Manager", run it.
    Step 6: Now we?re in the Backup Manager app. Insert the game in the console?s optical drive which you want to backup. Press ?O? and you will be asked where to make the backup, on the internal HDD or the external storage source connected via USB. External HDD are to be formatted to FAT32. NTFS should be supported soon.
    Step 7: In order to play the backup you just made, or any other backups stored on the HDD's, insert any original game disc into your console (To emulate the loading process), run "Backup Manager" in the "Game Menu". Press ?X? to play the selected backup game.
    Step 8: Now you will be taken back to the main menu. In the "Game Menu" you will see the game which you have selected/backed up. Now you can select the game, and run it without having or reading the exact same game disc in the console?s drive.
    Oh and you must make sure that the USB Modchip is connected to your console at all the times when you are playing the games via backups.
  • akhlaq768
    • 196
    you got my vote as a stickey...
    which mod chip are you using?
    • freck
      • 1076
      Using PSBreak and Usb Break..both working well with 1tb HDD.
      Freck
      • KenshinPT
        • Mar 2010
        • 408
        I want one.
        But I am affraid about the PSN Ban
        Did it help? Push Thanks below
        • HoTTDubbER
          • 778
          Originally posted by KenshinPT
          I want one.
          you cant get banned because you cant go online it only works with FW 3.41, thats out dated fw and to go online you have to update to 3.50 and thats a jailbreak killing fw unfortunately , once updated past 3.41 its curtans for you jailbreak and end of the road for modding your ps3
          Qualified Jedi Master
          Virgin VBox
          x2 PS3 JB FW 3.55
          X2 Wii 4.2E soft modded
          4x DM500S + JADE PLI
          Openbox HD S9 & S10
          DM800 PVR + BLACKHOLE
          Dedicated Linux Debian Server
          1.2M Dish Sky UK, Viasat, Sky IT ,JSC ,Tring+ Cards
          90cm Fortec Star Motorized Dish
          Virgin 50mb Fibre Optic Broadband
          Xbox 360 Samsung LT 2.0.1 No AP25 + Liton LT 2.0
          Microsoft Approved and Certified OEM System Builder
          Subaru Impreza GB270 Owner
          http://online-console.com
          • freck
            • 1076
            For the moment....its early days yet fo the ps3.
            Freck
            • HoTTDubbER
              • 778
              yeah hopefully soon there will be cfw that can emulate the fw hence opening the door again
              fingers crossed
              Virgin VBox
              x2 PS3 JB FW 3.55
              Openbox HD S9 & S10
              • akhlaq768
                • 196
                Freck
                ive got the hard-drive ready...
                where can i get a PSBreak and USB Break from?
                • freck
                  • 1076
                  heres one PS3Break - PS Jailbreak - PS3 Break is USB PS3 Dongle
                  Dealextreme and priceangels also do em
                  Freck
                  • masur123
                    • Aug 2009
                    • 674
                    PS3 Hacks
                    This site will help you a lot!
                    • janobi
                      • 1624
                      From me
                      • cablefreejunkie
                        • 1717
                        is it possible after updating to software 3.50 to downgrade back to previous software ?
                        The control of information is the consolidation of power
                        ?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
                        IF I HELPED HIT THE THANKS BUTTON
                        • HoTTDubbER
                          • 778
                          no
                          however the official jailbreak team has been putting out rumors that's the hack will work on 3.50 soon , this is just rumar no evidence as of yet
                          Virgin VBox
                          x2 PS3 JB FW 3.55
                          Openbox HD S9 & S10
                          • cablefreejunkie
                            • 1717
                            just my luck,,,the kids updated it last week so they could go online,tried it once and said it aint worth it !!!!
                            • akhlaq768
                              • 196
                              Hi Freck
                              You have a nice little thread... looks very straight forward but I seem to have problems with my Minimus AVRUSB Development Board - I followed a tutorial on www.ps3-hacks.com/ which I updated the device drivers on the AVR, loaded the hex file and added backup manager on the PS3…
                              I loaded over 4 different games on the external drive… but non have ever worked….
                              Can you help me out please?
