PS3 Jailbreak Guide
  • HoTTDubbER
    • 778
    #16
    1st of all are you running fw 3.41
    it will not work on any others
    second use this payload
    Hermes Custom Payload v3 Released *Updated* | PS3 Hacks :: PS3 Homebrew :: PS3 Downloads
    u will need this hex
    minimus_avr_usb_at90usb162_16Mhz
    when you have programed your minimus with hex
    insert the minimus into the ps3
    if you are using a fat ps3 turn the power off at the back
    if you are using a slim ps3 pull the plug out
    so the redlight is not on
    replug in your ps3 or turn the switch back on with minimus pluged in
    then press power button and then the eject button immediately
    let the ps3 boot
    then you will see a pkg installer
    download open manager from here
    Dashhacks :: PS3-Hacks :: Open Manager v1.16
    put on a usb drive in the root and plug into your ps3
    use the installer to install the pkg file
    then you will see open manager on your dash on games tab
    open it up and you will see the games on your usb harddrive
    make sure your games are in a folder called GAMEZ on the usb drive
    you must do the power cycle everytime you turn your ps3 on
    or the hack wont work enjoy!!
    Qualified Jedi Master
    Virgin VBox
    x2 PS3 JB FW 3.55
    X2 Wii 4.2E soft modded
    4x DM500S + JADE PLI
    Openbox HD S9 & S10
    DM800 PVR + BLACKHOLE
    Dedicated Linux Debian Server
    1.2M Dish Sky UK, Viasat, Sky IT ,JSC ,Tring+ Cards
    90cm Fortec Star Motorized Dish
    Virgin 50mb Fibre Optic Broadband
    Xbox 360 Samsung LT 2.0.1 No AP25 + Liton LT 2.0
    Microsoft Approved and Certified OEM System Builder
    Subaru Impreza GB270 Owner
    http://online-console.com
    • akhlaq768
      • 196
      #17
      Yes I can confirm that I am using fw 3.41
      Thanks for the link to the payload, question why do they call this payload...
      I'll plug the Minimus into the laptop and load FLIP. Do I follow the same instructions as i did to load the new hex file? or is there another process for programming the
      minimus the second time.
      I've been using BackUp Manager... will download the new Open Manager... Thanks :-)
      Will be following your guide this evening and will report back how I get on...
      After doing all this, do i put in a ORIGINAL game before i load up Open Manager or should i do this while OPEN Manager is loaded?
      • reddevil157
        • 1427
        #18
        There's a pdf at the end of " ps3 j/b explained " by Killersla on the second page of this forum, that says you have to press the two button's in sequence, b4 you reflash, take a look at it m8.
        • HoTTDubbER
          • 778
          #19
          yeah just get the chip in programable mode and your good to go same process as first time you flashed it
          also its called a payload as they are the files and code the hex you just programmed into the chip delivers into the ps3 upon boot to execute the hack
          Virgin VBox
          x2 PS3 JB FW 3.55
          Openbox HD S9 & S10
          • reddevil157
            • 1427
            #20
            let the ps3 boot
            HoTTDubber, I've already put at90usb162 for minimus hex on my board, not the one you've got here, can I still use open manager( backup) if I want to with the hex I've got.
            • HoTTDubbER
              • 778
              #21
              ive got all the hexs ,thats the best hex to use hermes v3 as it fixes the controller issues with streetfighter and f1 so upgrade to hermes v3 hex
              Virgin VBox
              x2 PS3 JB FW 3.55
              Openbox HD S9 & S10
              • reddevil157
                • 1427
                #22
                Cheers for that, just waiting for killersla to get back to me bout the buttons on the board.
