then there is one last thing you can do but its kinda risky i tied it a couple of times on different xbox's this only worked sometimes or even kiled an xbox
1st get a hair dryer and heat your xbox with that you will get 3 lights(rrod) then you can check the error code and check what the website tells you to do NOTE:I TAKE NO RESPONCIBILITY IF YOUR XBOX 360 GETS DAMAGED
tryed heat gun and towel trick still nothing, turns on ok but no pic
