lite on 74850
  • calhib
    • Sep 2009
    • 236
    lite on 74850
    hi i have a lite on 74850 and i would like to now what i need and how easy it is to flash i have done a benq before but i know lite on are harder to do thanks calhib94
  • snedz1967
    • May 2011
    • 197
    u need probe and ck3 kit to do these benq is easisest
    • cunny
      • 4915
      Have a read here
      • calhib
        • Sep 2009
        • 236
        so if i got this
        Xecuter CK3 Lite + CK3 Probe 2 - ModTraders.co.uk
        would i be good to go
        and is there anywhere i can get this cheaper thanks calhib
        • cunny
          • 4915
          Go with orobe v3 and do you have a compatable chipset? If not. Look at a x360
          Sent from my GT-I9000 using Tapatalk
          • calhib
            • Sep 2009
            • 236
            ye got a compatible chipset cheerz calhib
            • calhib
              • Sep 2009
              • 236
              jst been on the link i posted and it says it comes with a probe 3
              • cunny
                • 4915
                So all you will need is a CK3 and a Probe, the reason i said V3 as this will allow you to retrieve the key again once flashed
                • calhib
                  • Sep 2009
                  • 236
                  whats the difference between the probe 2 and 3 if you dont mind me asking
                  • cunny
                    • 4915
                    Probe 2 was designed for the MRA Hack, has Probe V1 functions. Probe V3 is for phat key method that will dump keys from all phat liteaons.
                    The Probe V2 can be converted to a V3 but, as you dont own 1 i would just buy the V3 straight out
                    • calhib
                      • Sep 2009
                      • 236
                      ok cheers how easy are they to flash once i have bought them 2 items?
                      • cunny
                        • 4915
                        I'd say quite easy, did my own this morning on PMT ( Probe V3 Method) in 15 mins from my laptop )
                        • calhib
                          • Sep 2009
                          • 236
                          ok cheers....
                          • calhib
                            • Sep 2009
                            • 236
                            i dont have a serial port is that going to be a problem
                            • cunny
                              • 4915
                              No but if ever needed use a serial to usb converter
