hi guys im picking up an xbox that cannot read discs i have a spare drive sitting here what would be the best and easiest option for me to get it working and not get banned from xbox live?
no just get a replacement for the drive in question, you will only need to get key if you change drive
the drive thats in the xbox is a samsung the spare one i have looks like its a samsung too the label is missing off it but it has the red wire if u know wot i mean.
I'll tell you how I fixed the same problem, but I really don't suggest you try it, since it could break the drive. My drive was trying to eject, and the motor engaged but was unable to open. In my case, the mechanism was out of whack slightly. I solved it by pressing eject (on an xecuter connectivity kit) and grabbing the tray and yanking it fully out. This 'reset' the mechanism. It didn't sound too healthy as I pulled it out, but it worked.
I advise you tap it rather hard where the drive is over the case 4 - 5 times, Then lean on where the drive is quite hard with one knee and open the disk tray.. Was recommended this by a guy in the trade, works every time.
Regards.
Sat Boxes
Dreambox 500s.
