hey peeps, need help pls...
  • cunny
    • 4915
    #16
    is it right stock fw?
    Whats date on top lid and version of stock ur using
    • saj1985
      • 785
      #17
      i've flashed to stock twice, tried to update dash with usb
      but keep getting this error : 351f-3524-1380-0702-c000-0099
      its fine sorted now,
      when i went onto stock i got the above error,
      i then flashed lt+2.0 again and did the update, it finished the update.
      got the latest dash now
      Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
      • cunny
        • 4915
        #18
        and lt2.0?
        • saj1985
          • 785
          #19
          and lt2.0?
          yea sorry bud, i meant that i've got lt2.0 with the latest dash from today,
          so mr cunny thank you very much for all your help!
          p.s i really think we gonna rip into liverpool on saturday well im hoping!
          you should be a mod for this xbox360 section
          • cunny
            • 4915
            #20
            Glad its sorted mate, remember to check drive properties now on all drives they change after dash updates for XDG3
            • saj1985
              • 785
              #21
              hey mate, i got rage which is fw 0800 rip,
              am i right in thinkin i can just burn it with imgburn or clonecd, following the tuts?
              or has abgx been updated for me to run the game through it?
              • cunny
                • 4915
                #22
                Download latest imgburn. When you click burn select truncate
                • saj1985
                  • 785
                  #23
                  i normally use imgburn,
                  but i thought i'd try clondecd, works a treat!
                  • saj1985
                    • 785
                    #24
                    hey peeps, i need a little help,
                    thought i'd post on this old thread instead of making a new one,
                    anyways i've got lt 2.0 on my liteon xbox 360 phat drive,
                    i need to flash it,
                    its been a bit of time,
                    so i was wondering whats the latest lt i need to flash on the console?
                    how to burn the games now?
                    i have a quick browse, seems to be a matter of going through abgx then use imgburn to burn the game with my ihas124b drive, is that right?
                    also whats the latest version dash at the moment i have to update to?
                    is there a list of the 'backups' that need to burned again?
                    is there anything else i need to do? or anything that is missing?
                    • cunny
                      • 4915
                      #25
                      What you will need to do is:
                      Return drive to stock fw.
                      Update dash either via live or downloading it from ms to usb or cd/dvd
                      Update drive fw to LT3.0
                      As your on 2.0 its more than likely none of your backups will be patched with topology data, so then, all AP2.5 active games will need to be reburnt (the orignal 6 and all xdg3's)
                      You will need a new burner and flash with buner max fw. Ihas version B which are now discontinued but there are burners that can be crossflashed. Lish can be found here
                      c4eva Speaks! | automated irc logs, updated instantly whenever and wherever c4eva speaks
                      Cunny
                      • saj1985
                        • 785
                        #26
                        Cunny
                        ok so i flash to stock, update dash then flash to lt 3.0, i understand that no problems...
                        yea i've got the ihas124b burner already flashed that when they first come out, so no problems with that too...
                        sorry to sound thick
                        but i dont get the bit about the games,
                        do i have to reburn all my backups again?
                        or just the ap2.5 and xgd3 backups?
                        if so, which backups are the ap2.5 and xgd3 ones?
                        is there a list?
                        on xbox website i downloaded the latest dashboard update the folder is called 'SystemUpdate_15574_USB',
                        that the right one?
                        • cunny
                          • 4915
                          #27
                          Just the Ap2.5 active games. The challenges from the dae.bin changes from dash to dash and ms can now do it on the fly. So if your backups dont have topology data then yes, ap2.5 games will need reburning
                          All XDG3 titles
                          assassins creed brotherhood
                          hot persuit
                          fable 3
                          mw2
                          black ops
                          halo reach <--- are the original 6 that are XDG2
                          • saj1985
                            • 785
                            #28
                            All XDG3 titles
                            hot persuit
                            fable 3
                            mw2
                            black ops
                            again sorry to sound thick
                            ok, so i need to reburn all the xgd3 backups, no problem...
                            which backups are the ap2.5 that need reburning?
                            is it only those 6 games?
                            is it only ap2.5 active games that need reburning yea?
                            sorry im a bit confused
                            • cunny
                              • 4915
                              #29
                              Find your backups here
                              abgx360 - Verified
                              See if they are XDG3 or not, if not, are they 1 of these?
                              hot persuit
                              fable 3
                              mw2
                              black ops
                              halo reach
                              If not, they wont need reburning, if yes to either list, then will need reburn
                              Also read
                              https://spreadsheets.google.com/pub?...F9JSWs3VmhBNXc
                              AP25 FAQ by Defosho *UPDATED 4th October 2011* - Team Xecuter
                              • saj1985
                                • 785
                                #30
                                abgx360 - Verified
                                hot persuit
                                fable 3
                                mw2
                                black ops
                                halo reach
                                Also read
                                thanks a lot mate,
                                i was a bit baffled
                                ok, so what's topology data about?
                                once i have a backup that i want to burn, how do i patch with topology data?
                                or do i run it through abgx and it automatically does it?
