here is the LT MAX burner firmware
  • martiboy
    • 541
    There you go folks enjoy
    Samsung LT2.01 fw
    Hotfile.com: One click file hosting: Latest_iXtreme_and_Stock_Firmware_Pack.rar
    Jungleflasher 1.89B
    Hotfile.com: One click file hosting: JungleFlasher.0.1.89.Beta(284).rar
  • KDC
    • Sep 2009
    • 177
    Magic! Cheers mate!
    Neil Francis Lennon: "The only way a title is tainted is if you've won it and you cheated to win it."
    • samlen27
      • 168
      i do everything the tutorial says but when i click write to drive i click yes and it comes up with error writing to flash failed
      • martiboy
        • 541
        What drive do you have and what fw you trying to wright
        • xXJediXx
          • Oct 2010
          • 214
          Whats the score with this burning firmware mate.
          Do ya need it to burn xdg3 0800's.? Have got access to one of the new burners
          • saj1985
            • 785
            Originally posted by martiboy
            hey marti, was a 2 min job to flash it,
            traight forward!
            by the way LT2.01 out for those with samsung drives!
            Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
            • samlen27
              • 168
              i have the 124b but ive sorted it now took it off my onboard sata and put it on my via card and worked no probs thanks
              • roryson
                • Mar 2009
                • 694
                i have the IHAS124-19 but instaed of the drive in my tower its in a USB caddy. would i be able to flash the drive in the caddy or should i put it in my tower. i tried the program without the drive on and it said no match drive detected. with the drive on it says, THIS FLASH UTILITY ONLY SUPPORTS ATAPI iHAS124 B drive. do u wish to continue?
                is it ok to proceed..??
                • martiboy
                  • 541
                  traight forward!
                  Thanks mate. I seen that the samsung fw was out but was in to much of a hurry to burn forza. Fixed the op now thanks
                  • martiboy
                    • 541
                    You should be able to flash in the caddy no probs. Just make sure when flashing it shows up eeprom and flash utility
                    • roryson
                      • Mar 2009
                      • 694
                      my drive shows in eprom and flash utilities, should i use the flash tool which is in the folder for my drive or the toolz in the main iXtreme Burner Max folder.??
                      • martiboy
                        • 541
                        The only thing that should be in your drive folder is new stock firmware that should be flashed first and the new custom firmware that should be flashed last. You need to use the 2 programs that are in the main folder to flash both firmwares. As long as your drive shows up in the 2 programs your good to go
                        • roryson
                          • Mar 2009
                          • 694
                          cheers bud
                          • saj1985
                            • 785
                            hey marti is the forza (pal) by complex a 0800 rip?
                            that the one you got?
                            • roryson
                              • Mar 2009
                              • 694
                              in the guide, it says reboot the computer. im my case its in a usb caddy. should i reboot the caddy..??
