I turned off force hyper setting and it burned ok
!!burn xgd3 to any dvd+r dl!! not my tut!!
I must admit to being sceptical as to whether the Verbatim discs would be that much different than the Aone Gold plus and Infiniti discs I've used for ages without any problems pre 124b drive and CFW. But after having only one successfully burnt disc with the 124b drive and CFW I ordered some MKM-003-00 Verbatims which arrived today. I've burned and 100% verified two different ISOs so far at 4x using all the suggested settings. Both installed to HDD no problem. So I'm convinced that it's not worth bothering with other discs. Whilst some may have success using Aone and other discs and it may be that my drive is fussy I'm just going to stick with Verbatims in future.Comment
I have the same problem with Aones. Burn verifies ok using the tut but then won't install or play, just "play game".I get 100% sucessful on burn with verb and 124b drive but when I put in drive i get play game but no piccy, if i click on play game then screen goes black and then returns to dash. I have tried burning with and without this tut and still the same probs, I know my liteon drive in the box is reading backups caus i put backup of black ops in and it comes up fine.
Any ideas
I'm trying burning at 2.4x after using MCSE. Will report back to the community although it's perplexing that you have the same problem with Verbs. My verbs are still on order so can't test them yet.
Brand new burner + phat Liteon Xbox here.Comment
Funny you should say that
In the new fw pack i downloaded the old LT+1.1 is in there aswell as the LTPLUS-025-v2.0 and JF autoloaded it so i flashed it with the flash i already had on there DOH!!!! - spotted it when i decided to flash again
All working great now thanks
DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
Re-flash it mate and check JF autoloads LTPLUS-025-v2.0 and not what mine did and put LT+1.1 back on
No I think it's the media because I'm playing GOW3 (truncated) and all other AP2.5 games fine.
When I burnt at 2.4x I actually got Ace Combat to work for some time and recognise the disc before it came up with dirty disc error. So I'm certain it's just that my 360 can't handle XGD3 burns on mediocre media. Here's hoping it's just that, anyway.Comment
Neil Francis Lennon: "The only way a title is tainted is if you've won it and you cheated to win it."Comment
Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
Can you please let me know how, as I'm having problems burning
Aone Gold dual-layer disks with liteon Ihas 124B AL0S
tryed with Imgburn everything as mentioned in the tutorial and does seem to workComment
