!!burn xgd3 to any dvd+r dl!! not my tut!!
  • kr1s77
    • Mar 2009
    • 161
    #31
    I turned off force hyper setting and it burned ok
    • maddy7
      • 54
      #32
      I must admit to being sceptical as to whether the Verbatim discs would be that much different than the Aone Gold plus and Infiniti discs I've used for ages without any problems pre 124b drive and CFW. But after having only one successfully burnt disc with the 124b drive and CFW I ordered some MKM-003-00 Verbatims which arrived today. I've burned and 100% verified two different ISOs so far at 4x using all the suggested settings. Both installed to HDD no problem. So I'm convinced that it's not worth bothering with other discs. Whilst some may have success using Aone and other discs and it may be that my drive is fussy I'm just going to stick with Verbatims in future.
      • Hawkk
        • Oct 2011
        • 4
        #33
        Originally posted by m9g
        I get 100% sucessful on burn with verb and 124b drive but when I put in drive i get play game but no piccy, if i click on play game then screen goes black and then returns to dash. I have tried burning with and without this tut and still the same probs, I know my liteon drive in the box is reading backups caus i put backup of black ops in and it comes up fine.
        Any ideas
        I have the same problem with Aones. Burn verifies ok using the tut but then won't install or play, just "play game".
        I'm trying burning at 2.4x after using MCSE. Will report back to the community although it's perplexing that you have the same problem with Verbs. My verbs are still on order so can't test them yet.
        Brand new burner + phat Liteon Xbox here.
        • m9g
          • 704
          #34
          Originally posted by nathan2007
          m9g is it flashed with lt 2.0???????????
          Funny you should say that
          In the new fw pack i downloaded the old LT+1.1 is in there aswell as the LTPLUS-025-v2.0 and JF autoloaded it so i flashed it with the flash i already had on there DOH!!!! - spotted it when i decided to flash again
          All working great now thanks
          DONT FORGET TO CLICK THE THANKS BUTTON IN THE BOTTOM LEFT CORNER OF THE POST IF ANYONE HELPED YOU
          • m9g
            • 704
            #35
            Re-flash it mate and check JF autoloads LTPLUS-025-v2.0 and not what mine did and put LT+1.1 back on
            • Hawkk
              • Oct 2011
              • 4
              #36
              No I think it's the media because I'm playing GOW3 (truncated) and all other AP2.5 games fine.
              When I burnt at 2.4x I actually got Ace Combat to work for some time and recognise the disc before it came up with dirty disc error. So I'm certain it's just that my 360 can't handle XGD3 burns on mediocre media. Here's hoping it's just that, anyway.
              • Hawkk
                • Oct 2011
                • 4
                #37
                Well, there is the answer. Verb delivery arrived this morning, and, unsurprisingly, all XGD3 games are burning, installing and playing 100% on them.
                • cunny
                  • 4915
                  #38
                  Is anyone trying to verify thier burns in imgburn after a write?
                  I am getting failures verifying using aone discs
                  • KDC
                    • Sep 2009
                    • 177
                    #39
                    My burns were failing verification at 49% with imgburn before this tutorial. Every burn since has verified 100%, i'm still using aone's.
                    Neil Francis Lennon: "The only way a title is tainted is if you've won it and you cheated to win it."
                    • cunny
                      • 4915
                      #40
                      Looking like i dint save the changes in advanced tab.
                      • saj1985
                        • 785
                        #41
                        cunny you had any luck mate?
                        i find that with imgburn when i 'run as admin',
                        i get 100% verification, with aone gold plus discs!
                        try that if all else fails mate.
                        Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
                        • KDC
                          • Sep 2009
                          • 177
                          #42
                          No problem mate, reckon thats where a few folks are going wrong. Save changes in advance tab is a must! Haven't had a single fail since.
                          • cunny
                            • 4915
                            #43
                            They are passing now, will run a few through Kprobe to test quality.
                            • Plutonian78
                              • Jan 2012
                              Originally posted by KDC
                              Sorry to hear you're having problems with infiniti discs mate but every burn i've had since using this tutorial has been successful, all burned and verified 100%. I'm using aone gold dl discs which are most likely the cheapest on the market, perhaps you could try them?
                              Can you please let me know how, as I'm having problems burning
                              Aone Gold dual-layer disks with liteon Ihas 124B AL0S
                              tryed with Imgburn everything as mentioned in the tutorial and does seem to work
                              • dragazar
                                • Apr 2011
                                • 59
                                #45
                                aone gold edition works ok for me also
                                Click thanks if i helped by asking a good question or helped
